Started by orkney, December 04, 2012, 09:11:12 PM
Hi Keith
Thanks, also heading the same way is A2E456 N286AS ex HZ-APR
Northern Watch
Hi Alan
You beat me to it, was just looking it up on the FAA site before posting.
Keith
X
#1067
on leaving Male at 0900 saw DA7X registered M-DTBP Believe it to be the following
43EC95   M-DTBP   DA7X   MLE 10/2/13   Executive   c/n 168
X
Hi X
Nearly the hex is 43E985 of TAG Aviation Asia c/n 168
Chers and nice to have you back
Northern Watch
Hi Alan
One that did not populate:
EZY195B  EGPE - EGGD
Keith
Evening Alan,
Here's one for you to rush out to the airport to see (I don't think). Air Berlin  BER597V in the d/b as routing EGPF to EGLL. It should be showing the route as LEMG to EDDM as it has just flown over me.
Morning, the unknowns from Sunday:
3FF1A5 (Germany, flight id: DMEEO, still no luck with the details)
3FF1B1 (Germany, flight id: MDRW, D-MDRW ALSL Airlony Skylane Private CN:? Mk1EB: http://jetphotos.net/viewphoto.php?id=7498236&nseq=0 )
3FF1C2 (Germany, flight id: DMSRL, D-MSRL GOLF Tecnam P-96 Golf Private CN:? source: http://www.aviationfanatic.com/ent_show.php?ent=5&AC_Regno=D-MSRL )
3FF1C9 (Germany, flight id: DMKKY, still no luck with the details)
40078D (UK, no flight id, nothing more)
diddyboy
Hi Alan
One unknown Spanish from yesterday.
* 34155A                                                              2013/02/10 16:00:25
Neil
Hi Neil,
Nothing on your Spaniard
Thanks Ian,
Thats sorted.  The automatics got it from Libhomeradar!!
Hi Ingo,
3FF1A5 D-MEEO, unknown to me
3FF1C2 D-MSRL c/n 027
3FF1C9 D-MKKY, unknown to me
40078D (decodes to G-HLAB which is now XA-TWQ so I assume a decoding error or miscode
GreekSpy2001
Quote from: Runway 31 on February 05, 2013, 10:39:20 AM
Graham,
As far as I am aware AE0160 is still the K35R.  There are 5 C-20B running from AE0166 - AE016A.  Unless there is a new aircraft it looks like a miscode.
Another Forum has quoted that this was C20/Gulf 3 86-0203 with a miscoded SMode box.  It should be transmitting as AE0168
Graham
Thanks Graham, hope they get it sorted quick, causes all sorts of confusion
X
These should be the two new B737's of Shaheen AP-BJQ and AP-BJV respectively
* 760951                                                              2013/02/11 13:48:08
* 760956                                                              2013/02/11 02:11:43
X
Spot on X
760951 AP-BJQ, Boeing 737-4H6 c/n 26449/2491
760956 AP-BHV, Boeing 737-4H6 c/n 27190/2568
