Started by orkney, December 04, 2012, 09:11:12 PM
Kenny
Thanks Alan,
Looks like there are several new hex code popping in my report today also.  Probably from hex change not new AC
* 881BE8                                                              2013/02/13 11:25:59
* 881BE9                                                              2013/02/13 14:18:38
* 881BEB                                                              2013/02/13 10:15:20
* 881BED                                                              2013/02/13 11:56:48
* 881BEF                                                              2013/02/13 11:59:49
* 881BF0                                                              2013/02/13 14:16:43
* 881BF4                                                              2013/02/13 11:22:46
* 881BF5                                                              2013/02/13 11:58:48
* 881BF6                                                              2013/02/13 13:56:34
Cheers,
Kenny
Quote from: Runway 31 on February 13, 2013, 09:47:31 AM
Kenny,
I still dont have any answers to your Thai queries from Monday.  However receeived these via Tom Millikan on mode-s
880962– HS-BKB B763
88106E– HS-DCN EC35
8818B2– HS-FER FDCT
881048– HS-DBH B738
881B67– L8-7/33 (coded 60107) C130 – was previously 8805AA
881B6D– L16-01/52 (uncoded) AT75 – was previously 881C61
90419F– HS-LNG C650 (miscode)
888078– VN-B227 AT75
All of the RTAF AT75, C130 & DA42 have had their hex codes changed in
recent weeks.
All now in the d/b
ANRB 3km north of VTBD
Hi Kenny, just had a look at my message, just to confirm, it is only the known ones that now have details in the d/b.  The unknowns still remain unknown
Flieger_NDS
Quote from: Flieger_NDS on February 13, 2013, 11:23:27 AM
Quote from: neroon79 on February 12, 2013, 06:32:27 PM3CE8EE (Germany, flight id: DCPNA, nothing more)
KingAir 350i, FL-795, former N8113Z. Currently undergoing special mission conversion, but I don't know for whom.
I found out who it will operate for: Prefectura Naval Argentina
Evening, the unknowns from today:
43E97D (UK, flight id: MYORK, M-YORK FA7X Dassault Falcon 7X Private/Unknown 545 source Manx Aircraft register) <- posted by xon on February 1st. But has not populated.
47183A (Hungary, flight ids: HAJEO{2x} and DDH740, HA-JEO C650 Cessna 650 Citation III Private/unknown CN:? Source and Mk1EB: http://www.abpic.co.uk/photo/1389429/ )
MILs:
3F70D0  VADER
3F81E9  SRIKE
3F81E9  SRTIKE
3F81E9  STRIKE
3F9A01  LM02
3FA4A2  GAF626
3FA4A2  GAF666   EDDT-BIKF
diddyboy
Hi Alan
One from Yesterday and possibility of being A320 on delivery out of Toulouse.
TS-IMU - Tunisair c/n 5474
* 02A194  TAR9001                                  2013/02/12 17:01:42
Neil
Hi Neil,
Thanks, yes it was a delivery
Hi Ingo,
I hadnt added M-YORK at the time as the c/n was wrong and must have forgot it thereafter, its c/n 042
3FA4A2 was UH1 73+62 previously but must now be a free code if it is in use by the Air Force
Blueboy
Hi Alan, landed at Prestwick today was PC-12 N120MB c/n 751 ex. D-FFMM
J.D
diddyboy
Hi Alan
2 unknowns so far this morning in France. 2nd one is an Airbus test Reg.
   383CFA                                                              2013/02/14 09:42:27
* 38867B  AIB04AD                                             2013/02/14 10:51:24
Neil
Hi Neil,
383CFA decodes to F-WWRP and has been used by 4 SOCATA types in the past so I assume its a SOCATA test registration
38867B is as you state an  Airbus test registration but am unable to decode it.
Neil,
Courtesy Arjen on mode-s
38867B F-WXAD 1350 A330-243F QTR
Hi Alan
MON502 needs correction - it's showing EGCC - BGIN
Should be EGCC - LOWI
Thanks Rod, the automatics for some reason always put LOWI in as BGIN.  I change any I find but they sneek in.  I have asked Airnav to look at this.
