Started by orkney, December 04, 2012, 09:11:12 PM
#1545
Hi Ingo,
40058F was G-OZBA now VP-BEQ otherwise no info
445566 unknown to me
48411A was previously used by P4-MAF H25B.  However Skyliner reports that Astana new E190 was on delivery 15-17mar13 SJK-REC-LPA-HAJ-AKX.  I wonder if it could be it re-using the hex, I have not seen any reports on it.  Also saw it noted in a report from  the Netherlands.
4CA2A3 was EI-DKG now 6V-AIJ but no info other wise.
Many thanks again Niklas
X
This should be GLF5 c/n 570
* AB318C  N820HB                                                      2013/03/17 18:15:02
X
It is X, ex N521HN
Seems that 48411A with flight id KZR1372 has left EDDV (HAJ) at 7:25UTC today morning.
Ingo,
Its looking more than likely its the new E190 but have had no confirmation yet
flygfantast
On screen right now not populating: 4AE258 SE-XRX
4AE258 SE-XRX, Shaw Europa, c/n 300-1037, Stefan Ingemarsson
Niklas
Cable: Ecoflex-10 (10m+1m)
#1553
Hi Ingo,
Confirmation received via John Hargreaves
48411A, P4-KCI, Embraer 190-100LR, c/n 19000604, Air Astana
Kenny
AIQ2541 VMMC VTBD
AIQ3008 VTSP VTBD
AIQ3351 VTUD VTBD
AIQ3206 VTCT VTBD
AIQ3244 VTCT VTBD
AIQ3441 VTBD VTCC
JSA514 VTBS WSSS
SIA976 WSSS VTBS
SIA981 VTBS WSSS
CAL5884 WSSS VTBS
ANRB 3km north of VTBD
#1555
48411A  KZR1372 has populated as P4-KCI  E190  Air Astana, but you had have stated it as P4-KCA. Which one is correct?
Thanks!
Sorry Ingo, populated correctly P4-KCI it is, I have changed my previous posting to avoid confusion
54901 - Jim
One more update ...
AD77FE / N967UW / E190 / Embraer ERJ190-100 IGW / US Airways / 19000211
Thanks!
KOSH - Oshkosh, Wisconsin USA
X
This decodes to RA-78765 but that is is/was EW-78765 of Trans Avia Export, but is on Aviacon Zitotrans flight no. It appears to have gone to FJR so will let you know asap.
* 1533AD  AZS3004                                                     2013/03/18 13:09:50
X
