Started by orkney, December 04, 2012, 09:11:12 PM
0 Members and 18 Guests are viewing this topic.
Xon
Thanks for those X.
Re UAE787 and 8, they are in both the server d/b and my d/b OK.  When you give me an ID, I try and obtain the other leg so that both legs are included.
Unfortunately the problem causing the deletions in the routes d/b will not be sorted by the weekend as first thought due to other commitments for Dev.  I have however asked if the routine could be switched off in the meantime to stop further deletions but have had no reply yet.
ACW367
#228
Quote from: Runway 31 on December 08, 2012, 05:57:26 PM
X
Some airlines use the same flight ID for more than one route.  United Airlines domestic flights are good example using the same flight ID for 2 or 3 different routes per week, nightmare stuff.  Some cargo flights operate with the same flight number on diferent routing dependent on the day of the week
The majority of the routes on the server have been provided by a automatic routine on the server and quite often its has been wrong, i.e getting the org/dest the wrong way round, showing only partial routes when there is a via in the routing and just plain wromg etc, hence the reason I took it on myself to update the route data.
Another example of how much of a quagmire this is, especially now with the ACSI data on RB24.  Southwest Airlines, whose crews do not enter the ICAO codes on the FMS, have many multi-multi sector routes that cross the continent in short hops every day.  These are now showing on the RB24 ACSI with the Southwest ICAO.
Here is an example  SWA945 which runs the following sectors every day over the course of around 13 hours:
KPIT-KBWI-KBUF-KMDW-KSTL-KDEN-KSAN-KSJC
Pittsburgh-Baltimore-Buffalo-Chicago-St Louis-Denver-San Diego-San Jose
http://flightaware.com/live/flight/SWA945
Another example
SWA657 - Port Columbus to San Diego with 6 intermediate stops
KCMH-KBWI-KRDU-KBNA-KHOU-KELP-KPHX-KSAN
http://flightaware.com/live/flight/SWA657
ACW367
I dont even bother with them and leave it to the FAA to provide the routing
Northern Watch
Good evening Alan
Correction to my post #156, UAL901 should read EDDF - KSFO.  Sorry, got my Frankfurt Airports wrong.
Keith
No problems Keith I have it in correctly
Northern Watch
Another small batch of routes from today:
HRM2061    ESGG - ORER
HRM2063    EGCC - ESGG
IBS3730      LEMD - EKCH
IBS3943      GCXO - LEMD
Noted heading towards Russia from Toulouse believe it to be on delivery for Aeroflot was AFL5651 / 42429B no other details but could be a new A330?
Also popped up over North Germany was 3D064C / c/s DEAQE one site has this as a DA-20 Katana no other details I am afraid.
Keith
Hi Keith
42429B VP-BDE, Airbus A330-343E, c/n 1371, Aeroflot Russian Airlines
3D064C decodes to D-EAQE but nothing concrete
Xon
#234
72863A YI-AQZ B772 c/n 40993 (Delivery flight callsign IAYIAQZ, Iraqi Airways)
424257 VP-BGB B773 c/n 41679 (First Aeroflot's 777)
Kenny
MDG10 FMMI ZGGG via VTBS
KAC411 OKBK RPLL via VTBS
KAC412 RPLL OKBK via VTBS   (not VTBD)
AXM1412 WMKK VLVT
TGW2102 WSSS VTBS
DRK123 VTBS VQPR via VEGY
CAL65 RCTP EHAM via VTBS  also CAL65U
CAL66 EHAM RCTP via VTBS  also CAL66U
CAL5455 RCTP ELLX via VTBS OMAA  also CAL5455U
CAL5884 WSSS RCTP via VTBS  also CAL5884U
HVN852 VTBS VVTS
AMU885 VTBS VMMC
AFR241 VTBS LFPG
SOO9920 VTBS EDDF via OMDB
QFA1 YSSY EGLL via WSSS
QFA2 (QFA02) EGLL YSSY vis WSSS
nolonger active (VTBD flights)
CPA2758
THA335
THA336
TGW105
GFA158
GFA159
JAZ717
JAZ718
JAZ727
JAZ728
JAZ737
THA457
THA455
TGW109
QFA6142
ETH2609
BAW20
VLK838
ETH8606
BKP126
BKP158
BER7160
HVN853
BKP174
KFR25
NWA341
CSZ9793
ANRB 3km north of VTBD
Thanks again Kenny.  I am not able to take ID's of the d/b yet, am waiting on a route updater from Airnav and once received will remove.
Blueboy
Hi Alan, picked up HEX AE4B01 - I'm taking it by elimination that its the third C-130J YI-304 for the Iraq Air Force passing through Prestwick - as the other two showed up in the database.
J.D
Blueboy
Hi Alan, picking up another HEX 4B37D8 with flight ID HBVDW - looks like its Learjet 45 HB-VDW c/n 438 of TAG Aviation.
J.D
