Started by orkney, December 04, 2012, 09:11:12 PM
mikek
Not populating:
C81D56. This is either ZK-MOR or ZK-KIW.
Both are the same type, AutoGyro Europe MT03 Eagle. ZK-KIW is c/n NZ009 while ZK-MOR is NZ006.
Just to confuse matters, the aircraft was displaying c/s ZKKIW, however using the hex of ZK-MOR...
To add to the confusion ZK-MOR (NZ006) was also registered as ZK-KIW in a previous life, then re-registered ZK-MOR. Another AutoGyro was then registered ZK-KIW (NZ009)!
My suspicion is that it is ZK-MOR just with its old c/s displaying. This would also fit it passing my location as it is based in Tauranga and would likely be returning from an Autogyro AGM up north last week. ZK-KIW is based up north near where the AGM was held so would unlikely be heading my way.
Hope that is of some use...!
Mike
Mike,
I have added them as follows
C81D56 ZK-MOR, AutoGyro MT-03, NZ006, Michael Terrence O'Rourke, Tauranga
C81E18, ZK-KIW, AutoGyro MT-03,NZ009, B C J A Russell,Tikipunga
Morning Ingo,
0CA19B probable miscode.decode error
3C7200 unknown to me
749EE4 unknown to me, probable miscode.decode error
Have a good one yourself
flygfantast
#964
4AE1A8 SE-XMH, Saab MFI-15-200A, c/n 847-824, Mikko E Suojanen
Route update:
MON8505 LEMG-ENGM
MON9117 LEMG-ENGM
Niklas
Cable: Ecoflex-10 (10m+1m)
54901 - Jim
Hello, Alan!  Updates for you ...
AB381D / N82182 - One Eight Two Leasing LLC
AA12DB / N74815 - J & T Flying Service Inc
A6BF62 / N534B - Designer Programs Inc
A38FC2 / N329AC - Henry C Dean
A4458A / N37439 - B & B Aviation LLC
A35AF7 / N315SC - International Skychase Corp
A315B3 / N2981F - Tarrant County College District
A13F7D / N18MY - Elisa Inc Trustee
Thanks!
KOSH - Oshkosh, Wisconsin USA
Morning, the unknowns from Sunday:
3C4DD3 (Germany, no flight id, decodes to D-ACNS, but nothing on an airframe using this reg. So I presume a decoding error)
3E21DC (Germany, no flight id, nothing more)
750294 (Malaysia, no flight id, might be a decoding error of 750290)
Xon
43E80D M-YFLY GLEX c/n 9136 prev reg M-YAAA
43E80E G-MRAP CL30 c/n 20023 prev reg M-YFLY
Thanks Xon
G-MRAP is allocated 4066AF if you have noted it recently using the Manx code it is a miscode.
Hi Ingo,
3E21DC decodes to D-IEAE not unknown to me
GreekSpy2001
New Danish code over London
45948F  OYEDO                                                       2013/02/04 10:59:39
Graham
I cant find anything on a current OY-EDO Graham
Morning Alan,
Libhomeradar has the above as :
Mode S : 45948F
Registration : OY-EDO
Boeing 737-548  c/n 25738
Operator : Business Flight
