New Navdata.db3 - 20121229
Started by orkney, December 29, 2012, 10:18:23 PM
Blueboy
Hi Andrew, I'm having a problem downloading update. I get the following message :-
502 - web server received an invalid response while acting as a gateway or proxy server.
There is a problem with the page you are looking for, and it cannot be displayed. When the web server (while acting as a gateway or proxy) contacted the upstream content server, it received an invalid response from content server.
I'm not very computer savy so this is all double dutch to me - any suggestions?
J.D
I will contact support for advice
Blueboy
Hi Alan, thanks - just another observation - when downloading previous updates, I just got a small bar at bottom of screen asking if I wanted to run or save the update. This time it appears to be trying to open another window?
J.D
#18
Worked OK for me when I downloaded, I got the bar but if memory serves me correct it usually opens a new window.  I presume this isa server issue.
GreekSpy2001
I'm getting the same 502 error. Timed 14:29 GMT
Graham
AV61
yes same here i am getting the same error message
Everyone will get the message until the defect is fixed
tommyg
guys.
Happy New Year and thanks again for the great service in keeping the database up to date.
Cud I ask that if possible when you release an update that you let us know how many acft we should have in the new file as that would then be a check that the update worked.
Tommyg
Tommyg
Kenny
Trying to download the update and get still get the same error.
Kenny
ANRB 3km north of VTBD
X
I am getting same Web Error response as the others above at 0900UTC
X
Airnav were advised as detailed previously and as advised by them above they are investigating, awaiting a further response from them
Apologies this is related to the server issues we had, the server does not like exe files on the server and things they should be executed rather than downloaded.
We have our team working on this, its affecting all downloads at the moment.
X
Alan/Trevor
Downloaded at 1200UTC successfully with 191524 Aircraft
X
Thanks Support now working again
