Not Locking Onto Planes Problem
Started by jaskel, March 30, 2013, 02:00:16 AM
Jaskel,
I cannot see from your screenshot, what version of the RB software did you use when you installed on your new computer.  Did you use the CD which came with the box or did you download and install the latest 3.13 or 4.03 version.
If you have not  installed the latest version download and install it, that may make a difference.
jaskel
4.03 downloaded from site.
Wird thing is when I run PC in safe mode it locks heaps of planes, when i start in normal mode back to only a few locked!@
#17
I am sure that what you have told us about the safe mode and normal mode will mean something to someone who knows about computers but It has me stumped.
Again grasping at straws, does your USB cable run direct from the box to the computer or do you go via a USB hub.  If via a hud try going direct and see if it makes a difference.
jaskel
nah direct from box to PC. I run same cable to laptop and it tracks 20-30 flights locked.
jaskel
still no luck, made sure folder pemissions are granted, made sure everything is ok and still poor lock %
im now at a loss...might have to retire the RB....no point running it if it wont work on my PC.
If it works fine on one computer but not the other and all the settings both in Airnav and Windows and its services such as anti-virus etc are the same it can only point to something specific to that computer that needs sorting but I dont have a clue where to point you to.
jaskel
yeah I agree.....the PC where the problem is was working fine until I upgraded the mobo/cpu and reinstalled windows 7....
I still think it is a file permissions thing....but ill keep searching for a few more days and if no joy then away it goes....really dont want to but it isnt working so there is no point.
jaskel
ok i have uninstalled ANRB and deleted all items in the registry.
Im now installing into the default directory, leaving everything default and see what happens
jaskel
well done and NO DIFFERENCE...30 flights, 3 tracked and locked
I dont know where it was installed to previously but note that you installed to the default program files location.  Have you installed to somewhere like C:\Airnav instead previously?.
I suppose you have looked at your anti-virus and other security setting although why some can lock and not others I dont know
jaskel
well i uninstalled everything including antivirus, reinstalled and it fixed itself...really weird!
tHANKS FOR THE  help guys
screen shot attached...now that looks better! Do you think I would gain more tracked flights by adding an amp?? will it make any difference??
"screen shot attached...now that looks better! Do you think I would gain more tracked flights by adding an amp?? will it make any difference??"
How long is your downlead from antenna to RB?   If less than 10M, unlikeley to make an appreciable difference.
jaskel
i have 12m of coax and it is as thick as my thumb too
You may notice a marginal improvement, but it won't be very much - how desperate are you for another couple of aircraft?
jaskel
not much...just want to get them lower....im timing out at 800'
