Started by orkney, June 21, 2013, 02:28:12 PM
X
Got to page six of a Google search for TC-HEE and gave up,  also used the search facility on Rotorspot and got nothing.
Kenny,
AD2E32 N9487E Cessna T240 Corvalis c/n T24002009 Cessna Aircraft
42418D was last allocated to VP-CDY DHC7 which crashed into a hillside in 1998, must have been reallocated.
paul tricker
Alan/X
found this on
http://www.dgualdo.it/prod-ab139-06.htm
but still no c/n....
C/N      Registration   Owner / Operator      Date      Remarks
  ??      TC-HEE            Eren             07.2013     delivered 23.07.2013
Paul
Thanks Paul, noted on network for first time on 23/7
Evening Alan,
Unfortunately, the 'quote' function would appear to still not be working but regarding reply #958/959, Ryanair's EI-EKR has finally returned {incidentally as RYR01G for which I have no route details} but confirmed as using correct hex code of 4CA811.
Cheers Ian.  RYR1G = LEBL-LEMG added last night
mikek
Didn't populate from a few days ago:
C820EA, ZK-DAE, Diamond DA40, 40.606, Aeromotice Leasing Limited
Thanks,
Mike
X
#1147
TC-HCT still not populating as per your post yesterday
4BA074  TC-HCT Bell 407GX c/n 54349 Aloha Textile/Skyline
Also 1059DB claiming to be Russian on the ground 500 miles away!
X
X
This decodes to TC-AAK.....Pegasus pig c/n 35094/2195???
* 4B842B                                                              2013/09/22 12:02:04
X
#1150
Hi Mike,
I dont recall your post so presumably I missed it, however its added now.
Hi X,
Sorry added it in incorrectly, now amended and should be OK now.
4B842B decodes to TC-AAK however this is now with Nok Air as HS-DBG.  Either a miscode or a decoding error and no flight ID would suggest a decode error or a corrupt packet picked up and decoded.  How many messages did you receive for it?
Evening Alan,
JAF9FB in d/b as LEPA-EGPH. It should be EBCI-LEAM. These JAF flights are a real pain as their flight ID's are very different from their actual ID's and change often and prove difficult to reconcile !
Tell me about it Ian, I have nearly given up on them.
Alan,
On now as RAM1010 is TF-AME B747-300 c/n 23072 currently in d/b as wfu/stored.
