Started by orkney, June 21, 2013, 02:28:12 PM
Many thanks for finding that Niklas. Interesting that the photo was taken 9/2011.
Thanks also for the CL60.
flygfantast
Not populating 4242D1 c/s FB0
According to Mode-S forum it's VP-BOQ.
VP-BOQ, Boeing 767-304, c/n 28042, Nordwind Airlines
Niklas
Cable: Ecoflex-10 (10m+1m)
Kenny
I believe the Diamond HEX is the hex out of factory and HS owner hasn't recode to TH hex.  I think we should get that as VARIOUS and hope that owner of BAJ will recode it some day.
For the serial, I didn't know that there was an agreed format on which to choose.  Just in my common sense to use Serial instead of RTAF serial (Lxx-yy/zz)  since the serial is painted in Arabic number and easily seen from afar while RTAF serial always paint in Thai number not more than 5cm tall.  And I think both are legitimate (please see the pdf link of s/n and RTAF s/n).
http://www.malaysianwings.net/forum/index.php?showtopic=11401  Try to find an RTAF Serial
http://www.thai-aviation.net/files/Air_Force_Detail.pdf
I don't want to customized my db since it will be replaced every months anyway.  Probably this feature will be available on 4.04.
Quote from: Runway 31 on June 22, 2013, 09:06:53 AM
Hi Kenny,
44019F  is the allocated hex of OE-UHK Hoffman HK-36TC Super Dimona, I would suggest you update your d/b to the miscode or alternatively I will update the registration to read as VARIOUS and add the details of the aircraft using the hex code in the CO field.  This is an unfortunate consequence of miscoding aircraft.
We use the allocated serial for each aircraft.  I would suggest that it you prefer to use the tail number/fleet number instead of the allocated serial that you update your own database accordingly.  881C63 is in the d/b as L16-03/52 and 881C62 has now been added as L16-04/52
Following consultation with forum members when we started out on the database excercise we have standardised on using the country - service for military aircraft worldwide for the CO field i.e UK - Air Force instead of UK - Royal Air Force.  As before if you prefer to change from our agreed standardisation I would suggest you update your own database accordingly.
Many thanks for the route updates
ANRB 3km north of VTBD
paul tricker
508188 UR-DND  B735 WFU Stored, is now UR-GBC with Ukraine International & in service into LGW (EGKK) last night.
Also CN-RNP used 020000 on its outbound leg from Heathrow last night, but unsure if a one-off or a long term mis-code
Paul
Hi Paul,
Thanks again, noted 020000 on mode-s, will keep an eye on it to make sure its not a one off although the hex was first seen on the network 27/01/11.
Hi Niklas,
Caused a bit of confusion that one as it was reported as NTU by Nordwind so I guess they have sorted their problems.
#21
Hi Kenny,
Although the document you linked gives the numbers you are refering to as its serial, i.e. 60101, it is in fact its squadron code. Mostly a five-digit number is used in which the first three digits indicate the squadron the aircraft is flying for and the last two indicate a unique number within the squadron.  This code is not unique for a single aircraft.  The unique identifier for the aircraft is the one detailed as RTAF serial and as you state the unique serial is written in the Thai language although in publications such as databases, the digits are written Roman style.
Kenny
I see   thanks
Kenny
Quote from: Runway 31 on June 23, 2013, 10:25:28 AM
Hi Kenny,
The numbers you are refering to such as 60101 is its squadron code. Mostly a five-digit number is used in which the first three digits indicate the squadron the aircraft is flying for and the last two indicate a unique number within the squadron.  This code is not unique for a single aircraft.
mikek
A bunch more from the last week:
71C26B
A82F7D   N6264T
718934   HL1134
71C263
718932   HL1132
718885
718971   HL1171
A8213C   N62288
71CA91
71AA38
71FC02   ALLIED 1
719035
71AA31
AE1824
Mike
Hi Mike,
You are gettng around1
71C26B unknown to me
A82F7D decodes to N6264T which became HL1142 Cessna 172S Skyhawk SP c/n 172S10732
718934 HL1134 Cessna 172S Skyhawk SP  c/n 172S10076
71C263 HL8263 Boeing 737-82R c/n 30658/1325 Jeju Air
718932 HL1132 Cessna 172S Skyhawk SP c/n 172S10968
718885 HL1085 Antonov An-2 c/n AN02005 Republic of Korea - Air Force
718971 HL1171 Cessna 172S Skyhawk SP c/n 172S11237
A8213C decodes to N62288 became HL1158 Cessna 172S Skyhawk SP c/n 172S10696
71CA91 unknown to me
71AA38 unknown to me
71FC02 65-327 Boeing 737-7ES Peace Eye c/n 35327/3071 Republic of Korea - Air Force
719035 unknown to me
71AA31 unknown to me
AE1824 unknown to me
Many thanks again
GreekSpy2001
some more new ones
* 121BD7                                                              2013/06/22 14:15:11
* 3E175A                                                              2013/06/22 16:20:33
* 40083D                                                              2013/06/23 08:21:36
* 484CB2                                                              2013/06/23 10:01:21
* E48E43  PRCRG                                                       2013/06/23 08:53:35
Graham
Hi Graham,
121BD7  unknown to me
3E175A  decodes to D-IAAS, 4 previous with the registration but am unware of a current allocation
40083D decodes to G-TBIC now brocken up
484CB2 decodes to PH-TUL a balloon now cancelled
E48E43  PR-CRG Embraer ERJ 135BJ Legacy 650 c/n 14501169 Construtora Estutural
X
    00BD09                                                              2013/06/23 11:22:12
    4005B2  IRM4578                                                2013/06/23 11:47:05
* 468663  RAB304   OAKB-OMSJ                             2013/06/23 19:06:41
Most likely last one is SX-ASC Boeing 747-21AC(SCD)   23652/669   Rayyan Air
X
#28
Hi X
00BD09 decodes to ZS-XCI unknown to me
4005B2  decodes to G-BSNR became UR-CJJ now EP-MOG B463 c/n decoding its old Air UK hex instead of 7335E7
468663  as you state SX-ASC
X
4005B2 till wearing UR-CJJ as of yesterday
X
