Author Topic: Database Update Requests  (Read 630354 times)
X
Re: Database Update Requests
« Reply #150 on: July 02, 2013, 04:18:59 PM »
Andrew
This unknown which appeared a couple of days back and tonight is operating Ariana flight AFG401 to sandpit and appears to be an A320 and should have it tied up within the hour.
   09A028  AFG401                                                      2013/07/02 19:44:16
X
« Last Edit: July 02, 2013, 04:20:32 PM by X »
orkney
  • Database Updater Moderator
    • orkney radarbox screenshot
« Reply #151 on: July 02, 2013, 06:45:38 PM »
Hello X
That will be good if you can get it tied up.
Thank you
Andrew
Northern Watch
« Reply #152 on: July 02, 2013, 08:43:53 PM »
Hi Andrew
On holiday in a caravan in the middle of Northumberland at the moment (no where near an airport - Shock/Horror!!!!). Using a dongle to send this but hopefully it will work as I managed to track some more routes:
BMR683V       EGPF - EKCH
BMR1807       EGGD - EGPD
EZE91LK        EGNM - EGPD
KLM1290       EGPH - EHAM
Back to a home hub in a couple of days and back to the real world.
Keith
orkney
« Reply #153 on: July 02, 2013, 09:29:14 PM »
Hello Keith
That is them done. It is indeed a miss not to have any planes to look at. It was bad in the ashes for a few days but then when they were all re routed over us it did more than make up for it!!
Thank you
Andrew
X
« Reply #154 on: July 03, 2013, 03:57:41 AM »
Andrew
09A028 is confirmed as C5-AAR A320 Tarco Air / Ariana Afghan was in storage Khartoum.
X
X
« Reply #155 on: July 03, 2013, 05:43:57 AM »
Andrew
New unknown from Mozambique at 20000
* 006C31                                                              2013/07/03 09:41:19
X
jacobite
« Reply #156 on: July 03, 2013, 08:06:42 AM »
Hi all, can anybody tie up the following flight BMR9411 I have tried to find it's routing but no luck.Thanks
orkney
« Reply #157 on: July 03, 2013, 11:14:45 AM »
Hello X
That is your A320 added but I cannot find anything for the other one.
Thank you
Andrew
X
« Reply #158 on: July 03, 2013, 12:20:34 PM »
Andrew
to complete the d/b C5-AAR is c/n 424 ex G-CRPH
X
Dana
« Reply #159 on: July 03, 2013, 12:22:43 PM »
006039, Reg: YR-1559, IAR IS-29-D2, AS29, Owner :Romanian Airclub
ACW367
« Reply #160 on: July 03, 2013, 02:23:29 PM »
I believe this is used for one off charters and positioning flights.  Therefore it should be discounted.
« Reply #161 on: July 03, 2013, 02:41:07 PM »
With regard to reply 133 :
For anyone in the area, Norwegian Air Shuttle will be using their new B787 during the month of July only from Oslo to Alicante on regular proving flights before moving to long haul destinations.
Alan, told you shouldn't have gone back to Scotland !
« Last Edit: July 03, 2013, 02:45:49 PM by EK01 »
orkney
« Reply #162 on: July 03, 2013, 02:44:16 PM »
Hello X and Dana
X, That is the Cn added. Dana, Thank you for that one, it is now in.
Thank you
Andrew
flygfantast
« Reply #163 on: July 03, 2013, 07:20:20 PM »
8880BA 8983, CASA C212-400MP, c/n 482, Viet-Nam - Marine Police (ex SE-MGZ, de-reged 17/6)
Niklas
Cable: Ecoflex-10 (10m+1m)
Hawkeye
« Reply #164 on: July 03, 2013, 08:00:18 PM »
  " Hi all, can anybody tie up the following flight BMR9411 I have tried to find it's routing but no luck.Thanks
    Ian"
"I believe this is used for one off charters and positioning flights.  Therefore it should be discounted."
They certainly use 94** and 89** ones for ad hoc charters.    Sometimes use 80**ones as well
