Started by orkney, June 21, 2013, 02:28:12 PM
#1590
Hi Liviu, we now carry out parity checking for ADS-B aircraft to ensure that we get the correct ID of the aircraft to minimise the decoding errors we got on previous versions of the software.
For non ADS-B aircraft we carry out checks to ensure that we get two messages with the same hex/callsign combination again for the same reasons.  Aircraft only squit in response to an interogation by ground based radar and we recognise that in some areas the radar coverage is not a great as in others and even to get two consecutive messages with the correct squawk/callsign combination received can be difficult/take some time so we allow the user to decide whether to enable squawk validation or not.
When the aircraft do not populate, how many messages are received and do they populate after a time or not at all.  Are the ones which are not populating ADS-B equipped or not.
CYYZGUY
#1591
Goodmorning Alan
AAL280  No Route
AAL392 No Route
regards,
40" LED Monitor
40" LED Monitor
Morning Jason,
AAL280 KORD-KBOS-KORD
AAL392 KORD-KLGA
John,
Sorry for not being clearer, what I meant regarding DLH LOWW flights is that I received information regarding their new flight ID's and have changed them in the database.  Other DLH flights have changed also but I do not have their new info at this time.
Michel
Alan,
Small correction:
RYR575Q EFTP-LEAL iso ETFP-LEAL
Michel.
CYYZGUY
Hi Alan, they just keep coming this morning..
ROU1851  No Route
40" LED Monitor
40" LED Monitor
John Racars
QuoteSorry for not being clearer
no problem, I understand you now!
Here some new data:
FN--------   NO--   ND--   NV--
New:
CAI707   LTFE   EHAM
ETD9901   EHAM   EDDS
QTR23   OTBD   EGCC
TFL262   LGKO   EHAM
TRA152   LTAI   EHAM
Correction:
CAO1067   ZSPD   EHAM   ZUCK
DAL603   EHAM   KJFK
No route:
RYR929H
Regards, John
13 NM East of EHAM
ANRB:
Version: 3D - 5.00.072
PC: Windows 7 SP 1 - 64 bit
RadarBox24 station: EHAM4
superspotter
Another update from Lafos;
Hexcode 06418B is 5N-BRL Nestoil AW139 ex N90AR, just departed using reg as callsign, regards clive.
Thanks Michel,
I had all the RYR routes in/out of EFTP as ETFP, now corrected
Thanks Clive,
Another one accounted for.
Hi Jason
ROU1851 CYYZ-KLAS
CYYZGUY
Hi Alan
UAL1120
No Route
regards,
40" LED Monitor
40" LED Monitor
Hi John,
Thanks again.  The RYR flights were added to the database last night and I have checked the Navdata downloaded this morning and RYR929H is in as EGSS-EPLL
Hi Jason,
UAL1120 is one of the flight ID's used on different routes dependent on the day of the week so I dont intend adding it to the d/b
Today it routes KEWR-KSFO while tomorrow it routes KSFO-KRDU
John Racars
#1604
QuoteThanks again.  The RYR flights were added to the database last night
THANK YOU!!! Great job to have the RYR flightid's within the first day of the new timetable season available in the database! That is GREAT!!!
Big complements and hope you can keep up the good work.
Kind Regards, John
BTW: What is LIVT in flightid RYR157G? I can't find any data about this ICAO location.
13 NM East of EHAM
ANRB:
