Started by orkney, June 21, 2013, 02:28:12 PM
0 Members and 6 Guests are viewing this topic.
Thanks Ian (Jacobite)  DAL15 routes EDDF-KATL-KSLC
#1788
John/Michel,
The Malta International Airport website gives AMC395 as arriving from Amsterdam and Brussels.
Thanks for the route info John
Michel
Alan/John,
AMC394/395 is flying a triangle LMML-EHAM-EBBR-LMML. Could be passengers board AMC395 at EHAM outbound for LMML, but the flight actually operates as AMC394 from EHAM to EBBR. So it's still the inbound leg. At EBBR flightnumber changes to AMC395.
Michel.
John Racars
#1790
Quote from: Michelbut the flight actually operates as AMC394 from EHAM to EBBR
Michel,
I saw that on my screen as well. Maybe the cockpitcrew forgot to change the flightid at EHAM?
This happens more I think........
13 NM East of EHAM
ANRB:
Version: 3D - 5.00.072
PC: Windows 7 SP 1 - 64 bit
RadarBox24 station: EHAM4
John Racars
Hi Allen,
an other QTR:
FN--------   NO--   ND--
New:
QTR3   OTBD   EGLL
13 NM East of EHAM
ANRB:
John Racars
and an other new TRA:
FN--------   NO--   ND--   NV--
New:
TRA61N   EHAM   GCLP   GCRR
13 NM East of EHAM
ANRB:
Quote from: MichelOne question; is there a simple way to empty your personal database? Can't imagine the only way to do so, is to delete each record manually.
Unless you kept a copy of Navdata pre-encryption, then no, the only way is to delete each record manually.  No need to do it really, AUTOUPDATE will update aircraft and routes.  I do it just to keep a small Navdata for performance reasons.
John Racars
Alan,
New:
TRA277   EHAM   GCLP
TRA278   GCLP   EHAM
13 NM East of EHAM
ANRB:
Kenny
Just flew on HS-GBE and came back to check with RB log.  It was hex 284705.
Saab SF34 340B cn 340B-426  ex SE-B26, N426XJ  op Nok Mini Airlines
I notice you mark HS-GBH as 'Nok Mini' while the rest of SF34 leased from SGA you put 'Nok Mini Airlines' in AC field.  I think all should be 'Nok Mini Airlines'
ANRB 3km north of VTBD
Many thanks Kenny and HS-GBH amended
