Started by orkney, June 21, 2013, 02:28:12 PM
John Racars
FN NO ND
New:
TFL721 EHAM LTAI
TFL722 LTAI EHAM
TFL724 LTAI EHAM
TRA182 HEGN EHAM
13 NM East of EHAM
ANRB:
Version: 3D - 5.00.072
PC: Windows 7 SP 1 - 64 bit
RadarBox24 station: EHAM4
Many thanks John, appreciated
Alan,
Is there still a problem with 'via' routes showing up. Currently on screen is Turkish Airlines cargo THY6415. It is showing as LTBA-GMMN but should be LTBA-LEMD-GMMN. I tried to put in the via point myself using d/b explorer but it keeps reverting back to just LTBA-GMMN.
#1939
Hi Ian,
LEMD wasnt on the d/b but I have amended it so should be OK now although I believe the via issue has still to be sorted.  Its a server problem not the software.
Alan,
Thanks for that. Incidentally, just had an Alitalia on with a flight ID of AZ063 with his correct routing of LEMD-LIRF showing. Not sure if it is of help but could it be the case that if a 2 letter flight ID is given followed by a leading '0' that the route details are being given but if a 3 letter flight ID is given followed by a leading '0' the route details do not show. Maybe of some use to the 'techie' department.
John Racars
new ones below with thanks to a "Scramble-friend":
FN NO ND
New:
TRA107C EHEH LEVC
TRA227B EHEH LEMD
TRA309H EHEH LIPE
TRA310K LIPE EHEH
TRA5Q Pos flight
13 NM East of EHAM
ANRB:
Many thanks to you and your scramble friend John
John Racars
Hi Alan, and again with the help of a friend:
FN NO ND
New:
TRA9KV EHRD LEBL
13 NM East of EHAM
ANRB:
Thanks to you and your friend John
John Racars
#1946
FN NO ND
New:
FIN1916 GMAA EFHK
KLM43H EHAM ENAL
TFL451 EHAM GBYD
TFL452 GBYD EHAM
13 NM East of EHAM
ANRB:
John Racars
FN NO ND NV NO ND NV
Correction:
SWR40C EGLC LSZH i.s.o. EGPC LSZH ?
13 NM East of EHAM
ANRB:
John Racars
FN NO ND NV
New:
TRA460 GCLP EHRD GCTS
13 NM East of EHAM
ANRB:
John Racars
FN NO ND
New:
TRA608N LPFR EHEH
13 NM East of EHAM
ANRB:
