Started by orkney, June 21, 2013, 02:28:12 PM
Michel
Hi John,
SQC7369 isn't an aroud the globe flight. Incomming flight to EHAM is SQC7370 (comlete routing is WSSS-VOBL-OMSJ-EHAM), outbound is SQC7369. But I think the incomming routing is a bit too difficult for the d/b ;)
In that case, what about SQC7419? It's complete routing is: DNMM-HKJK-EHAM-EKCH-OMSJ-WSSS.
Michel
#452
John/Michel,
Due to limitations in this version we can only have a maximum of 3 points in each route which causes us problems at times.  Where there is more than 3 I add in the org and dest and usually leave off the via point(s) which dont have any RB coverage and hope that the look up routine is OK with it.  SQC7419 gets left blank as the routine cannot cope with it, no matter what combination I entered and would delete it every time.
flygfantast
479A5C LN-TBG, Tecnam P2002-JF, c/n 222, Tønsberg Flyveklubb
Niklas
Cable: Ecoflex-10 (10m+1m)
John Racars
Alan / Michel,
Sorry for the confusion. The one I meant was SQC7343 of last Monday.
13 NM East of EHAM
ANRB:
Version: 3D - 5.00.072
PC: Windows 7 SP 1 - 64 bit
RadarBox24 station: EHAM4
Many thanks again Niklas
No worries John, WSSS,WSSS,EHAM, is cool
Xon
48D82E 0224 AN28 c/n AJG004-07 (Delivered: 01.07.2013)
Michel
#458
Picking up right now is AEE4484. Route is showing EGAA-LGRP, but it's flying the other way around. Correct route should be LGRP-EGAA.
Also picking up right now is KLM835, routing EHAM-WSSS-WRRR. In d/b the tag on to WRRR is missing, showing only EHAM-WSSS.
FDX5188/5187 are routed LFPG-EHAM-ENGM / ENGM-EHAM-LFPG, but it looks they have dropped the EHAM-ENGM v.v. section. FDX5188 is now routed LFPG-EHAM and FDX5187 is now routed EHAM-LFPG.
A new one is TRA75R; EHGG-LEPA.
Michel.
paul tricker
#459
non-populator today...
E47E28  0PPCFF                                                      2013/07/24 13:33:13
PP-CFF  Falcon 2000 c/n 110  La Fonte Participacoes SA
Paul
On delivery to UTair is 4242CC VP-BPS Airbus A321-211 c/n 5681
On its first service Istanbul-Leipzig as MNB9948 is 4BB464  TC-MCD  Airbus A300B4-622R(F)  c/n 7??  MNG Airlines
Out of Toulouse as TAM9396 is E48E47  PR-TYB   Airbus A320-214  c/n 5654  TAM Linhas Aereas
Out of Toulouse as CSN999 is 780ADE  B-5928  A330-323E  c/n 1430  China Southern Airlines
Out of Gostomel as CUB1461 and picked up leaving Norwegian airspace bound for KEF 008000  CU-T-1711  Antonov An-158-200  c/n 201-02  Cubana.  Correct hexcode should be 0B06AF
Thanks to John Hargreaves
Many thanks Michel, all noted and actioned
Hi Paul, many thanks again
John Racars
Callsign Org Des Via||Org Des Via
AFR1407=DUS-CDG-||EDDL-LFPG-
BAW975H=HAM-LHR-||EDDH-EGLL-
BCY131=BVE-AMS-||LFBV-EHAM-
BCY5196=AMS-LCY-||EHAM-EGLC-
BEL45D=VNO-BRU-||EYVI-EBBR-
BER492=DUS-TXL-||EDDL-EDDT-
BER515=DUS-HAM-||EDDL-EDDH-
BER536=MUC-DUS-||EDDM-EDDL-
BER8693=NAP-DUS-||LIRN-EDDL-
DLH2UV=HAM-DUS-||EDDH-EDDL-
DLH2WY=FRA-AMS-||EDDF-EHAM-
DLH2XA=TXL-DUS-||EDDT-EDDL-
*DLH3PN=FRA-EDI-||EDDF-EGPH-
DLH3UT=DUS-LHR-||EDDL-EGLL-
DLH3VJ=MUC-DUS-||EDDM-EDDL-
DLH64U=HAM-CDG-||EDDH-LFPG-
DLH84=FRA-DUS-||EDDF-EDDL-
DLH8VY=DUS-TXL-||EDDL-EDDT-
EXS448=ZTH-LBA-||LGZA-EGNM-
EZY10SM=AMS-BRS-||EHAM-EGGD-
GMI4264=DUS-PMI-||EDDL-LEPA-
GWI7643=FAO-HAM-||LPFR-EDDH-
IBS3620=MAD-DUS-||LEMD-EDDL-
JAT362=BEG-DUS-||LYBE-EDDL-
JTG406=LPA-AAL-||GCLP-EKYT-
JTG569=BLL-AHO-||EKBI-LIEA-
JTG768=LPA-OSL-||GCLP-ENGM-
KLM1535=AMS-MME-||EHAM-EGNV-
KLM1621=AMS-LIN-||EHAM-LIML-
PRI412=LPA-BLL-||GCLP-EKBI-
RYR54HY=NRN-MAD-||EDLV-LEMD-
RYR8CW=MMX-STN-||ESMS-EGSS-
TFL1057=AMS-FAO-AGP||EHAM-LPFR-LEMG
TFL584=MAH-AMS-||LEMH-EHAM-
TFL611=AMS-PMI-||EHAM-LEPA-
TRA1484=PMI-AMS-||LEPA-EHAM-
TRA1836=PMI-AMS-||LEPA-EHAM-
TRA2853=AMS-ASR-||EHAM-LTAU-
TRA5084=EGC-RTM-||LFBE-EHRD-
TRA6286=TLN-RTM-||LTFH-EHRD-
*=Corr.
13 NM East of EHAM
ANRB:
