Started by orkney, June 21, 2013, 02:28:12 PM
flygfantast
Not populating 502C99 c/s BTI9801. New Dash 8 for Air Baltic ? :)
Niklas
Cable: Ecoflex-10 (10m+1m)
Hi Niklas,
The only aircraft I can see they had on order was another DH8D c/n 4448 which was C-GUTD cancelled on 28th August.  I expect it will be it but dont know its new registration yet but if it follows the sequence should be YL-BBW.
Can you try changing the resolution of your screen to see if that allows you to make the change.
Safe flight.
diddyboy
Hi Alan
Another Ground Transmitter.
* 896E8B  AIR4                                                        2013/09/02 02:20:01
Neil
paul tricker
A0DCCF  N155AN                                                      2013/09/02 03:55:21
N155AN   GV-SP (G550) 5421  WFBN
This was only registered last month, but I have been picking up the hex/flight id for almost a year, so who knows if it was actually N155AN this morning!!
It plotted this am which it has not done before
Paul
Hi Paul,
Thanks again.  The previous N155AN is now N155AD GLF5 c/n 5029 I think since mid July.
Xon
paul tricker
Ah, Ok, when I previously checked the FAA database, it was unallocated.
I must have looked between airframes
Paul
Paul, Just looked in d/b and N155AD c/n 5029 has been there since January.
shouriken
Blue Air routes:
BMS103   LROP   LEMD
BMS104   LEMD   LROP
BMS105   LROP   LFOB
BMS106   LFOB   LROP
BMS107   LROP   LEBL
BMS108   LEBL   LROP
BMS111   LROP   LIME
BMS112   LIME   LROP
BMS113   LROP   LEVC
BMS114   LEVC   LROP
BMS115   LROP   LIRF
BMS116   LIRF   LROP
BMS117   LROP   LIPE
BMS118   LIPE   LROP
BMS1215   LROP   LIRF
BMS1216   LIRF   LROP
BMS123   LROP   EBBR
BMS124   EBBR   LROP
BMS125   LROP   LEMG
BMS126   LEMG   LROP
BMS127   LROP   LPPT
BMS128   LPPT   LROP
BMS129   LROP   EDDS
BMS130   EDDS   LROP
BMS131   LROP   EGGW
BMS132   EGGW   LROP
BMS135   LROP   LIPZ
BMS136   LIPZ   LROP
BMS137   LROP   LCLK
BMS138   LCLK   LROP
BMS143   LROP   LIRN
BMS144   LIRN   LROP
BMS145   LROP   LICC
BMS146   LICC   LROP
BMS149   LROP   LFNM
BMS150   LFNM   LROP
BMS155   LROP   EIDW
BMS156   EIDW   LROP
BMS201B   LRBC   LIMZ
BMS202B   LIMZ   LRBC
BMS205B   LRBC   LFOB
BMS206B   LFOB   LRBC
BMS211B   LRBC   LIME
BMS212B   LIME   LRBC
BMS215B   LRBC   LIRF
BMS216B   LIRF   LRBC
BMS217   LRBC   LIPE
BMS218   LIPE   LRBC
BMS223B   LRBC   EBBR
BMS224B   EBBR   LRBC
BMS231B   LRBC   EGGW
BMS232B   EGGW   LRBC
BMS255B   LRBC   EIDW
BMS256B   EIDW   LRBC
BMS329   LRSB   EDDS
BMS330   EDDS   LRSB
Liviu
A.net JetPhotos.Net
RadarBox
Michel
New Darwin Airline routes:
DWT550 EGSC-EHAM
DWT551 EHAM-EGSC
DWT552 EGSC-EHAM
DWT553 EHAM-EGSC
DWT254 EDDP-EHAM
DWT255 EHAM-EDDP
DWT256 EDDP-EHAM
DWT257 EHAM-EDDP
Update:
TRA772 LMML-EHAM iso LGRP-EHAM
Michel.
Many thanks Liviu, I had been doing them as they came on my screen but your assistance has speeded up the process.
Mark Coles
Hi there,
* 4BA0D5                                                              2013/09/01 13:44:35
from:  http://www.ole-nikolajsen.com/TURKISH%20FORCES%202004/aTHE%20TURKISH%20CIVIL%20Register%20TC-.pdf
TC-HFU     EC.135      04-08-13     Göksar    (no c/n)
hth
Mark
daily or weekly updates for your database
www.dbpop.co.uk
