Your experience upgrading to 5.00.044
Started by Kenny, October 19, 2013, 07:05:58 AM
Hi Clive,
Unfortunately the photos would be for your eyes only.
You would require to make them size 200x134 and name them the registration.jpg and place them in the data/photo folder.  A second phot would be registration,2.jpg
They should then should show next time you pick them up.  You may also have to add the registration in the PTTN/PTTN2 field via d/b explorer,
Dana
After upgrade I noticed less airplane on the map then before. Or on Flight list are ADS-B airplanes but not shown on the map. Also range has diminished in some areas. I also noticed that if I set the time out flight less than 4 sec. all airplanes on the map looks like time out flights.
Thanks for testing tarbat. Maybe I'll look for an SSL free mail provider. On the other hand, if sending by using the airnav server is working with a much higher reliability as in V4, I won't need a custom mail...
MikeK
Regarding your issue with Office10, please see PM sent
anorak
Just getting things back to the way I had before V5, but can`t remember how to set up auto start on Vista please.
Dave.
Dave. Exmoor, North Devon.
Copy link into autostart folder.
right mouse click on link, go to an click on "eigenschaften"
select submenu "Verknüpfung"
Under target (Ziel) enter this "C:\Eigene Programme\AirNav Systems\AirNav RadarBox\ANRB.exe" /connect
tommyg
Alan/support.
Have downloaded 5044 and 47 with no problems, however tonight after my box had been running just under 4 hours I  got an 'access violation with anrb.exe' error and the box shut down. I have restarted it and it is working normally again. so no idea what caused the fault.
tommyg
Tommyg
KB1CHU
I like that you can go directly to RadarBox24 from the software. I do find myself going back and forth sometimes. Steve KB1CHU
Well, with some help from Alan, Tommy and others asking questions, I've now got V.5 installed and running - but with apparently 20% or so less A/C showing than normal, but could this be due to the lovely weather we're experiencing at the moment.   It has taken several days, and multiple deletions and installs, but slowly getting there.
However, I still have one major problem, although I've gone through the updating Database process, I've still only got 80317 A/C loading in the D/B - any suggestions please.................
Quote from: CoastGuardJon although I've gone through the updating Database process, I've still only got 80317 A/C loading in the D/B - any suggestions please.................
Firstly, did you use the Database Update option in Database Explorer?  Secondly, did you follow the instructions to restart Radarbox?
Michel
I might have overlooked it, but I've got one question about the database:
In the database what does the autoupdate (Y) mean? Does it mean, the big online Airnav database can overrule my personal database? Let's say I got flight XYZ1234. Official routing is AAAA-BBBB-CCCC-DDDD, but I want the route displayed as BBBB-CCCC-DDDD. In the online Airnav database the routing is displayed as AAAA-CCCC-DDDD.  When I thick Y in autoupdate, does the online database changes the routing to AAAA-CCCC-DDDD iso the route I want to show it? So when I thick N at autoupdate, the online database won't correct my personal database and leaves it as BBBB-CCCC-DDDD?
Michel.
Michel, correct.  Set AUTOUPDATE to N to stop your manually changed record from being updated by the system.
Michel
Thanks Tarbat. In that case I have to change a lot of Y in N ;-)
Alternatively Michel, advise me what needs changed and I can update the database.
Michel, or turn off Route Auto-populate in preferences.
