Why the need for encryption of DB3 database?
Started by Bell 407, November 06, 2013, 05:29:12 AM
0 Members and 12 Guests are viewing this topic.
Marpleman
Can I throw this into the mix gents?
I use Aerodata as my main spotting software repository.
With their database, it is not possible to download the data in its entirity or in part, for other people/organisations to benefit from, but it is possible to add information to records and add unused empty fields for individual users unique benefit.
To my best understanding, this isn't a million miles away from the options with v5?
It's not unusual therefore for database providers to guard their work?
John Racars
Yes, I totaly agree but it does not help, I am afraid.
They will not come back on their desission.
Maybe after 10 years from now when they reconsider the situation about RadarBox 5..........................
and rolout a "new" version 6.. based on 4.03 like 5 now
13 NM East of EHAM
ANRB:
Version: 3D - 5.00.072
PC: Windows 7 SP 1 - 64 bit
RadarBox24 station: EHAM4
Bell 407
It really is good to see the debate continuing.
Netcop
Yes, it's nothing wrong if database providers to guard their work. But I presume that Aerodata established these rules from the very beginning, but not after several years of collecting the users  base  as AirNav. In this case Aerodata's approach is "million miles away" from AirNav's
P.S.  Tried to post using the Quote button but that is not working. Support, Ń€lease check
Greetings from Russia, Moscow
20.54 nm NWN of UUDD
Amp: Wimo AS-1090
RadarBox24 station: Netcop
Netcop,
The 'quote' button hasn't worked for months !
Not sure where it is on the 'too be fixed list'.
If the failure of the "quote" function is not already on the beta buglist,  please add now!!!!
It's an absolute pain on a forum not to be able to quote!!
The quote issue is not written by our code. The forum code is written by a company called Simple Machines SMF and its a bug in the version of the forum we are using. We will be upgrading the forum soon which will resolve this issue.
Chris11
Not good to use us to build a database then encrypt it.
John Racars
A reaction from out my hart. Top Chris!!!!!!!!!!!!
13 NM East of EHAM
ANRB:
Chris,
To state why use us to build a database and then encrypt it couldnt be further from the truth.  While I am very appreciative of users like yourself who kindly take the time to send details of unknowns, as I stated above these are minimal and the vast majority have been provided by updaters like myself sitting for hours on end scouring the internet, national registers etc to add to the database.  From your own country of South Africa I would imagine over 99.5% of the database entries came from my graft in searching for this info.
#25
Terry,
Some of it is as some tie ups came from the database that I pay for same as yourself and the database you use and subscribe to.  I wouldnt imagine the contects of it are available for anyone just to grab and use out with the application, as the producers of the database are protective of its contents, whats the difference with Airnav doing the same?
Whats double standards about that.  The double standards is where it is suggested it is OK for somethings and then where it doesnt suit its not.
shouriken
What do you think about AirNav creating a standalone application to edit navdata.db3 using SQL?
The application would be available only for RB users (i.e. using the same data to log in into it as in ANRB.exe).
Liviu
A.net JetPhotos.Net
RadarBox
It sounds good Liviu only thing is these things leak out and we would soon be back the way we were.
I would like to see something which could allow the data to be unencrypted within the application allowing it to be worked on and then saved back encrypted.  I dont know whether that would be possible though.
shouriken
Quote from: Runway 31I would like to see something which could allow the data to be unencrypted within the application allowing it to be worked on and then saved back encrypted.
That is the way ANRB.exe works now (I suppose).
Allowing to run the application using a login with user/password like ANRB does, would ensure the database could not be used for other purposes.
Liviu
A.net JetPhotos.Net
RadarBox
