Started by orkney, November 07, 2013, 02:30:03 PM
#1005
If you give me a clue with the hex code Niklas it will probably be another lease in.
SWG27 KPIE-CYYZ
Alan,
Have just an update. The system showed that 210022 aircraft were downloaded. Upon doing a restart the aircraft table is showing a total of 211410 and EC-ICS is still present.
CYYZGUY
#1007
FDX1790
FDX1778
No Route
regards,
Jason
40" LED Monitor
40" LED Monitor
#1008
Hi Ian,
The database holds 210022 aircraft records as you state and thats what my d/b has after downloading this morning.  EC-ICS isnt in the Navdata or on the server having been removed in November.  For some reason you have an extre 1300 records and I have not got a clue why but some other users appear to have this as well, may well be that for some reasons some records are not being deleted if EC-ICS is in your Navdata.  It will probably date back to the first beta upgrade.  When you download the Navdata update do you go for Update all Records (overwrite the local databse with the server databse)?  If not try doing that.
I cannot manage to come over this side of the New Year as there is a steak and sausage pie waiting on me here with my name on it. :-))
Hi Jason,
I cannot find anything on FDX1790
FDX1778 KIND-KEWR
anorak
424577 /SOV2992 nothing on airframes.
Thanks   Dave.
Dave. Exmoor, North Devon.
Hi Dave,
424577 VQ-BRY Embraer 190-200AR-195AR c/n 19000157 Saratov Airlines out of Exeter on delivery
BOM1
Alan,
First contribution for a long time, just arrived AMS
485065 PH-EZZ E190  - 19000654  -  KLM Cityhopper
Steve
Michel
Alan,
LCO1501 EHAM-EDDF-SBKP iso SCEL-EHAM-EDDF.
Michel.
CYYZGUY
40" LED Monitor
40" LED Monitor
Alan,
I have done as you suggested and 'updated all records'. The total aircraft in the table is now showing 210022 and not 211410 as before and EC-ICS is no longer in the database therefore that seems to have done the trick.
In future when doing updates via d/b explorer would you suggest this option as I always used the 'do not update manually changed records' as the option particularly as this would appear to be the default.
I do have some individual records marked as 'N' to updating. Is that therefore sufficient ?
Hi Steve,
Nice to hear from you, thanks for that.
It should be OK now Ian, to update using Do Not update  manually changed records.
CYYZGUY
40" LED Monitor
40" LED Monitor
