Started by orkney, November 07, 2013, 02:30:03 PM
Hi Keith,  I noted it earlier and I have put a blocker on it to try and stop them but this requires some updating to the server side software to be completely sure that it works.
Thanks again.
Thanks Alan,
I assume you will add to d/b when the c/n becomes available.
I added it in without the c/n Ian
jacobite
Hi Alan, received today at 1350, OB-1770 4841E6 any ideas please.
Hi Ian,
It is in the database, 4841E6 OB-1770-T F50 c/n 20280 routing EHBK-EGPC returning to Aero Transportes miscoding its former test hex.
Northern Watch
Hi Alan
Another problem with a photo, this time with KLM Cityhopper Embraer PH-EZZ.  It has populated as the old Fokker 70, of the same registration.
Keith
Kenny
Unpopulated
* 61BD64        2014/01/16 23:17:37
* 881004  B   P                                                          2014/01/16 16:32:19
ANRB 3km north of VTBD
Thanks Keith, blocker in place until Airliners get a shot of the E190.  You will need to delete the photo from your photo folder as the software looks there first before going to the net.
Sorry Kenny, nothing on either of those.
tommyg
Alan.
A route problem BCS776 shows EGKK-VOGO, this flight I believe operates ex EGLL to somewhere in Europe either Paris or Milan
tommyg
Tommyg
Hi Tommy,
Its out of EGLL and in the descent for LFPG at this time.
Hi Alan
ADBA21 - N984BH is showing as the Learjet 45 that it is, but with an aircraft code of ZZZZ
#1572
Hi Rod,
While the FAA has it as a Learjet 45, it is actually a Learjet 75 and it is in the database as such.  The Learjet 75 is not contained within ICAO8643 therefore I have allocated it ZZZZ until ICAO decide on its allocation.  For info on the Learjet 75 please see http://en.wikipedia.org/wiki/Learjet_70/75.
We have 4 LJ75's in the d/b with the first customer delivery in the d/b C-FMGL added last night
CYYZGUY
UAL1636
No Route
regards,
Jason
40" LED Monitor
40" LED Monitor
Hi Jason,
UAL1636 KDEN-KBOS
