Started by orkney, November 07, 2013, 02:30:03 PM
John Racars
Alan give me some explanation because  I do not understand anymore,
- when I edit a route and put this line "N" in auto-update the route-info was allready updated with the information from the AirNav database the next second; so my edit is overwritten immediately.
- when I untick in preference "autopulate routes" this will not happen; BUT: other flight-id's do not give route info any more longer.
Is this a bug in the software or so? May be I follow a wrong procedure; can you please tell me what to do (step by step) when I want to edit a route and this will not to be overwrite with the old AirNav info again and all other routes gives there info as before with a ticked box in "preferences". I Presume there is going something wrong.
I am RB user from the beginning; al those years there where problems with the routes. When comes the time they will be solved. Sorry, Alan, you can not doing about this but all this to tired of being.
13 NM East of EHAM
ANRB:
Version: 3D - 5.00.072
PC: Windows 7 SP 1 - 64 bit
RadarBox24 station: EHAM4
flygfantast
Not populating 46788C, c/s FNF302. 1086 msgs received
Niklas
Cable: Ecoflex-10 (10m+1m)
Presumably it is a new Finnish military aircraft Niklas bit I can find not details.
Evening, the unknowns from Thursday:
1803C5 (Russia, no flight id, nothing more)
33FE39 (Italy, flight id: IAM1477, IAM: Aeronautica Militare Italiana)
3CC22A (Germany, no flight id, nothing more)
3CED66 (Germany, no flight id, decodes to D-CRFA, nothing on this reg)
3D39E4 (Germany, flight id: DEUEE, D-EUEE Beech 36 Bonanza Mk1EB: http://swag-trip-logs.blogspot.de/2013/08/240813-tannheim.html )
3D3B5F (Germany, flight id: DEUST, D-EUST nothing more)
3E835B (Germany, no flight id, nothing more)
400E31 (UK, no flight id, no active airframe)
440706 (Austria, no flight id, nothing more)
44CDE2 (Belgium, no flight id, nothing more)
471EAF (Hungary, no flight id, http://www.flightradar24.com/data/airplanes/ha-lqd )
473415 (Hungary, no flight id, nothing more)
484FA9 (Netherlands, no flight id, http://www.flightradar24.com/data/airplanes/ph-ebr airframes says reregistered)
4AC8B0(Sweden, no flight id, nothing more)
4B1A44  EZS1468  EKCH-LSGG  confirmed decoding error
4CA731 (Ireland, no flight id, nothing more)
896314 (UAE, no flight id, nothing more)
A01557 ( USA, no flight id, N104UE not asigned by FAA)
AA0E05 (USA, no flight id, N747RC FAA has it as deregistered)
B80000 no allocation
B803C5 same
F000C5 and one more
MIL:
3EB276  GAF914
3EB276  GAF914
3EB281
3F524F  GAMC11
3F524F  GAMC11
3F524F
3F70E3  ATTACK2
3F7549
3F9386  GAF009
3F9386  GAF009
3FA814  BURNER1
3FA816
3FAFC6  GAF767
3FAFC6  GAF767
3FB0E0
3FB42D  AXEMAN
3FB42D  AXEMAN
Have a nice evening and a good start into the weekend!
Regards Ingo
John,
If the info for the route is already in the Navdata database and is wrong, change the details in your Navdata and change the autoupdate option to N and if an aircraft is picked up showing that flight ID, the flight will not sync with the server and your info will stay in place even if Auto-populate route Data is ticked in Preferences/Radarbox.  Also advising me of the required change will see the correct info on the server which would avoid any conflicts.
Similarly when updating the database in its entirety your sync option should be Do Not Update Manually Changed Records
M
Quote from: flygfantastNot populating 46788C, c/s FNF302. 1086 msgs received
Quote from: Runway 31Presumably it is a new Finnish military aircraft Niklas bit I can find not details.
It's Learjet LJ-1. (Returning from maintenance. Had previously mode C transponder, now mode S.)
Thanks for that M, 467889 deleted
John Racars
Quote from: Runway 31If the info for the route is already in the Navdata database and is wrong, change the details in your Navdata and change the autoupdate option to N and if an aircraft is picked up showing that flight ID, the flight will not sync with the server and your info will stay in place even if Auto-populate route Data is ticked in Preferences/Radarbox.
Alan, thank you. I do exactly as you describe. Despite that, the info I edited will be overwrite immadiately by the Original info from AirNav......
When a flight is not on the screen any more (landed or out of my area of reception) the edits I made continue to exist, so I now have found out.
I have the fear that the software in this area is not in order.
Thank you for help until sofar!
13 NM East of EHAM
ANRB:
The main thing John is not to make the change while the aircraft is still in myflights, wait until it is no longer in your reception.
John Racars
QuoteThe main thing John is not to make the change while the aircraft is still in myflights, wait until it is no longer in your reception.
Aha, I never know to do so, but it is clear to me now. Thank you Alan for your explanation!
Have a nice evening and till the next report of new ones!
Kind Regards, John
13 NM East of EHAM
ANRB:
