Started by orkney, November 07, 2013, 02:30:03 PM
Jason,
AAL956 KORD-KDCA-KORD
John Racars
Thank you verry much Alan.
Have a nice day!
13 NM East of EHAM
ANRB:
Version: 3D - 5.00.072
PC: Windows 7 SP 1 - 64 bit
RadarBox24 station: EHAM4
shouriken
Quote from: Runway 31Replace the D008.dat file in the data folder with this one attached.
Thanks Alan.
Mine was from 2013/05.
Liviu
A.net JetPhotos.Net
RadarBox
Thats me been through the posts and caught the ones I missed John.  Fortunately Orkney has more sense than me and did them correctly.
John Racars
Alan, thanks again, no problem. Here some from this afternoon that flew over my area of reception.
Bussy at GMAD....... .......and you do not need to scroll this time.......
FN NO ND NV NO ND NV REMARKS
New:
EZY58JH ENBR EGKK
EZY86KY EDDB GMAD
NAX19A ENGM GMAD
NAX21Q ESSA GMAD
TRA191 EHAM GCTS
Correction(s):
TRA192 GCTS EHAM i.s.o. EHAM EHAM GCFV
13 NM East of EHAM
ANRB:
Thanks John, the mad dash to the sun!!
Chris11
Alan - confirm you would like detail of miscodes.
eg Z-BAM is still on A2C629
Yes Chris, I will add them in as long as it doesnt conflict with the correct one in which case it will go in as Various.
Z-BAM is in the database.
Afternoon Alan,
Regarding D008.dat file. If you remember I have on my system ANRB and ANRB2011 which we tried to uninstall but for some reason couldn't. I checked under data in ANRB and the D008.dat file was dated 19/09/2009 whereas the same file in ANRB2011 was dated 15/05/2013. I clicked on it and dragged it over to ANRB and it has replaced the old file. Three questions :
Was this the correct thing to do ?
Is this file dated 15/05/2013 the same one you have kindly put in reply #261 ?
How can I tell if it has worked ok other than waiting for another Manx registered aircraft to come over ?
If that was not the right thing to do I have checked and Easyjet Winter schedule flights from Glasgow to Alicante are on Mon/Wed/Fri and Sunday. I will pick you up at the airport !
On another subject. Incorrect photos.
Hex code E483AD registration '7305' P3 Orion has come onto 'My Flights' but the accompanying photo is of a Chinook also registered '7305'.
First of all Ian, you should get Marie to do the technical stuff, thats everything after pressing the button to turn the computer on.
The one I attached today is very similar to the one from April with the only difference being changes to some military flags noted during the beta process but other than that it is the same and should show the Isle of Man flag.  You will have to wait until you next pick up an Isle of Man registered aircraft.
Re 7305, incorrect photos deleted and blocker in place to stop them being downloaded again,  Airliners dont have any of the Orion.  Delete the Chinook ones from your photo folder and next time you pick it up you should see Photo Not Available.
Thanks for that Alan. Probably something to do with the computer expert that was over here not transferring things properly !
Will wait for the next Manx registered to come over to see what happens.
Chinook pictures deleted.
John Racars
New:
AFR198D LKPR LFPG
BCS771 EHAM EGLL
EZY57LG EKCH EGKK
EZY62HJ EDDL EGKK
EZY82RP LFSB EGKK
EZY94UV EGNT LMML
GMI700 EDDL EGKK
GWI320 EINN EDDK
GWI5065 GCFV EDDV
NAX34B EKCH GMAD
NAX9690 GCTS EFHK
NAX9824 GCLP ENTO
SAS7742 GCTS EKBI
TOM8113 LOWW EGKK
WZZ2PJ EGGW LJLJ
WZZ3KH LFOB EPKT
Correction(s):
BAW787 LSGG EGLL i.s.o. KPAE EGLL
DLH33K EDDM LFPG i.s.o. EDDH LFPG
13 NM East of EHAM
ANRB:
