Started by orkney, November 07, 2013, 02:30:03 PM
John Racars
#45
Alan,
any reaction / comment on my post #35 about the RYR7654 and ANA205?
And may be it is an idea to delete flights below from the Routedatabase. They are presumably coming from previous timetable seasons and all days coming over my area of reception. Flightid's may be correct but the info can not be correct. So better NO information than WRONG information:
FN NO ND
DLH1EK LIRF EDDF
DLH1HU EDDF LROP
DLH2FL LROP EDDF
DLH2NF LGAV EDDM
DLH2VR LIRF EDDM
DLH2YX LIRF EDDM
DLH32K LPPT EDDM
DLH3CK LROP EDDF
DLH3FP EPWA EDDM
DLH3RL LSGG EDDM
DLH3VT ETSE LIRP
DLH4JV LBSF EDDF
DLH4KX EDDS EDDT
DLH4LX LYBE EDDM
DLH5MA LQSA EDDM
DLH5XC EDDT EDDS
DLH5XV LROP EDDM
DLH6KK EDDM LIRF
DLH6KV EDDH ESSA
DLH6PF LIRF EDDF
DLH73A LOWW EDDH
DLH7TT EDDM EDDW
DLH88H LEMD EDDM
DLH8ER LIRQ EDDF
DLH8FW EDDM EDDF
DLH8LC ETSE LIRF
DLH8PH EDDM LDZA
DLH99K LFMN EDDM
DLH9JE EDDH LYBE
DLH9VA EDDM LFSB
13 NM East of EHAM
ANRB:
Version: 3D - 5.00.072
PC: Windows 7 SP 1 - 64 bit
RadarBox24 station: EHAM4
Michel
Some more updates/corrections:
BAW11 EGLL-WSSS
BLX660 GCRR-EFHK
JTG706 GCLP-ESGJ
PRI638 GCRR-ESSA
Michel.
Many thanks Xon, it has been great getting the Polish updates
John Racars
in the hope you read and will answer my postings I sent before and where was no reaction on until this time:
FN NO ND
New:
TAY31W EIDW EBLG
TAY38C LEMD EBLG
TFL758 LTAI EHAM
TRA85B EHAM GCRR
13 NM East of EHAM
ANRB:
John, the ones that didnt show are as you state in the database.  Can you advise how many messages were received for each one as it may be the error checking in process.
Please be advised that i dont spend all day at the computer as I have other things to do.
#50
Thanks for the routes John.  I will check the DLH routes to see if they have been amended since the start of the winter schedule and if need be delete the routes applied.  A good number of the DLH flights have already been updated.
Please note that i will not be doing so tonight as it is nearly 0100 and I am going to bed.
CYYZGUY
Hi Alan
UAL1668 No Route
regards,
40" LED Monitor
40" LED Monitor
John Racars
Quote from: Runway 31Please be advised that i dont spend all day at the computer as I have other things to do.
Oops Alan,
I am verry sorry to hear that and must be wrong informed. I thougt you are 12 hours a day working on our requests and believed databases...........
Pity. My questions about RYR and ANA does not anything to do with "leading 0" but does not give info while normal in the d/b.
Problems like this never where in my old situation. I think you know what I mean with that.
Please take your time, I will still reporting to you and understand that you have other things to do. Verry sorry! It was not my meaning to get you in stress!
Good night and sleep well!
13 NM East of EHAM
ANRB:
Xon
Quote from: Runway 31 on November 08, 2013, 09:57:07 PM
Thx and n/p :)
So some more new hexs from Poland
488194 SP-AMW C414 c/n 414A0810
48A42B SP-KBL BE58 c/n 479
#55
Thanks Xon
Please note the full info for SP-KBL
48A42B SP-KBL Beech 58P Pressurized Baron c/n TJ-532 Karor-Bis
Hi John,
Had a good nights sleep and am very relaxed thank you.  It takes a lot nowadays to stress me, having had a very stressful job for over 40 years, now that I am retired I dont do stressed any more!!.  I do this on a voluntary basis and while I am usually around the computer for around 12 hours a day, sometimes more, sometimes less depending on other aspects of life, it is not my main priority although sometimes it feels like it and these other priorites are given focus as required.
Error checking is now built in to ensure that the correct flight ID is applied to each flight and while this usually works OK, sometimes for whatever reason this may mean that a route is not applied to the occasional flight and this also applies with other receivers as well.  You may not be aware but there is a filter in Preferences/Radarbox which can be turned off for Callsign and Squawk validation which you may want to turn off to see if it makes any difference.
jacobite
#57
Hi Alan, do you have anything on EZY12DR please I think it's LFPG-EGGP? but that is only a guess.
Ian (jacobite)
John Racars
Goodmorning Alan,
good to read that all looks going well with you! Thank you for your explanation about the RYR and ANA; I will try out your suggestion.
FN NO ND
New:
KLM16V EKCH EHAM
KLM49L EHAM LSZH
KLM55T EHAM LKPR
KLM56T LKPR EHAM
KLM83F EHAM EGBB
KLM84F EGBB EHAM
KLM96H LFBO EHAM
TFL456 GBYD EHAM
TFL510 GCTS EHAM
TFL518 GCLP EHAM
And some incorrect DLH routings to delete:
FN NO ND
DLH1HW EDDF LIRQ
DLH32K LPPT EDDM
DLH3CK LROP EDDF
DLH3RL LSGG EDDM
DLH3VT ETSE LIRP
DLH4JV LBSF EDDF
DLH4KX EDDS EDDT
DLH4MM EDDM EPGD
DLH5MA LQSA EDDM
DLH5XC EDDT EDDS
DLH6KK EDDM LIRF
DLH7ET EDDM LKPR
DLH84U EDDF LOWW
DLH88H LEMD EDDM
DLH8AH LIMF EDDM
DLH8FW EDDM EDDF
DLH8JT LIPE EDDF
DLH8PH EDDM LDZA
DLH96N LFLL EDDF
DLH9JE EDDH LYBE
DLH9VA EDDM LFSB
13 NM East of EHAM
ANRB:
Morning Alan,
EZY24DG  LEAL-EGGP
