Started by orkney, November 07, 2013, 02:30:03 PM
#555
John,
I give in its changed back
CYYZGUY
AAL1040 is showing up as a Mig-15.  I have the latest database and is being updated from the server.
Also the Emirates flight, which I have seen before is showing no route.  A6EDB second from top.
Any ideas guys?
See screenshot below.
AAL1040 Mig15 by CYYZGUY, on Flickr
40" LED Monitor
40" LED Monitor
paul tricker
CYYZGUY
I am no expert, but from A6EDB's height, are you picking it up on the ground as they start the systems & before they have input the route details??
Paul
#558
Jason,
It cannot show a route as it is not giving a flight ID other than its registration and the registration does not signify a route.  Did it stay this way or did the crew input the flight ID which then allowed the route to be shown.
Regarding N9012, The Mig is a previous user of the registration N9012 and while there a re photos of it in Airliners there are unfortunately there are no photos of the Airbus on Airliners yet.  The photo not available link is now in place in the lk and lk2 fields but for some reason this is not being read by the software.  Airnav are aware and are working on a fix.
Morning Alan,
TCW505A : LEAM-EBCI
CYYZGUY
AMX003
No route
I also keep getting UPS1066H every morning, no route, but I guess they are playing around with the flight ID's again.
regards,
Jason
40" LED Monitor
40" LED Monitor
#562
Hi Jason,
AMX003 is in the d/b as AMX3 so it should show OK and I have it on screen just now showing MMMX-LFPG over New Brunswick this time.  I will keep an eye on it when it comes over this side of the pond.
I cant find anything on UPS1066H.  UPS1006 operates KDSF-KBDL but dont know if its the same flight with an additional prefix signifying some operational reason.
Michel
QuoteThe routing Michel give is incomplete and should be:
WSSS HKJK EHAM  VOMM WSSS
No it's not. Complete route is SQC7344 WSSS-FAOR-HKJK; SQC7343 HKJK-EHAM-VOMM-WSSS.
Michel.
Michel
Another SingCargo:
SQC7369 EHAM-VOBL-WSSS iso EHAM-WSSS-VOBL
Michel.
John Racars
#567
Hi Michel / Alan,
things can be changed from the one on the other day. It looks Michel's report is correct in this case. Alan, I think you are free to dicide how this flight's to add in the d/b. SQC7344 looks no problem... SQC7343 needs to make choises.
It will be a discussion all the time when more than 3 entries are needed.
Thank you Michel for the update about SQC7344/3! Highly appreciated.
13 NM East of EHAM
ANRB:
Version: 3D - 5.00.072
PC: Windows 7 SP 1 - 64 bit
RadarBox24 station: EHAM4
Evening, the unknowns from Monday:
   3C4936        2013/11/25 10:21:29
   3C5460        2013/11/25 06:45:39
   3C658A  DLH863   ENGM-EDDF                                             2013/11/25 18:53:01
   3E19F6  DIBAK                                                          2013/11/25 12:18:50
* 3E1F4F        2013/11/25 14:50:25
   3E835B  HG01A                                                          2013/11/25 07:14:11
* 3E8441  HAMMER2                                                        2013/11/25 13:37:32
* 3E85AC  HAMMER1                                                        2013/11/25 08:38:44
* 3E85AC  HAMMER1                                                        2013/11/25 13:27:53
   3E92DD  SMASH                                                          2013/11/25 13:24:54
   3EA131  LK01A                                                          2013/11/25 09:38:52
   3EAEC0  BU24T                                                          2013/11/25 14:07:17
   3EAEC0  BU24T                                                          2013/11/25 15:18:50
   3EB67F  GAF914                                                         2013/11/25 10:11:24
   3F486E  LK01B                                                          2013/11/25 09:43:01
* 3F5271  GAF236                                                         2013/11/25 09:23:55
* 3F5271  GAF236                                                         2013/11/25 11:21:41
   3F6A89        2013/11/25 08:18:07
* 3FB455  SW81                                                           2013/11/25 18:48:01
   3FB645  GAF101                                                         2013/11/25 12:04:29
   3FBA56  HG01B                                                          2013/11/25 10:38:07
   3FF295  0K                                                             2013/11/25 12:56:46
   3FF295  0K                                                             2013/11/25 14:09:30
* 4242EB        2013/11/25 09:30:59
   445566        2013/11/25 09:08:38
   445566        2013/11/25 17:01:10
* 44CDCF        2013/11/25 16:42:02
   471EA0        2013/11/25 11:37:57
* A6B7BE        2013/11/25 12:00:04
Regards Ingo
John Racars
#569
And my today's made homework:
FN NO ND
New:
ADR34A LJLJ EHAM
ADR35A EHAM LJLJ
BGA121 LFBO EDHI
GWI4M EDDK LGAV
GWI9A LSGG EDDH
NVR144 GCRR ENGM
PRI529 EKCH GCFV
PRI635 ESSA GCFV
PRI636 GCFV ESSA
VKG4851 EKBI GCLP
VKG4852 GCLP EKBI
VKG5621 ENGM GCLP
VKG5877 ENGM LPMA
VKG7834 GCLP EFHK
13 NM East of EHAM
ANRB:
