Started by orkney, November 07, 2013, 02:30:03 PM
Out of XFW as CSN17 is 780B74 B-9960 Airbus A321-231 c/n 5890 China Southern Airlines assumed from Skyliner info
Evening, the unknowns from Wednesday:
about 20 mins earlier there was another delivery out of XFW:
88530B A320-232SL, Thai Smile, D-AVVL, HS-TXK (MSN 5892)
let's start with one from the X-files:
* 0000C4        2013/12/04 14:33:21
* 0002C4        2013/12/04 09:57:10
* 0003C4        2013/12/04 12:39:26
* 0003C4        2013/12/04 13:31:07
* 0003C4        2013/12/04 14:45:58
39E4AC (France, flight id: CCM951, CCM: CCM Airlines, http://www.flightradar24.com/data/airplanes/f-hzfm )
3E4BBB (Germany, flight id: DITWL, D-ITWL no luck with the details)
I've had to surrender, maybe due to the storm my mobile web-speed is half of nothing so the rest as a copy and paste from my LOG report:
   470D43        2013/12/04 03:10:25
* 4B17BD        2013/12/04 10:07:52
   4B19E2        2013/12/04 12:23:21
* 4F01F4        2013/12/04 14:22:40
MIL:
* 3EA435  LK01B                                                          2013/12/04 13:39:51
* 3EBEFC  GAF926                                                         2013/12/04 13:40:22
* 3EBEFC  GAF926                                                         2013/12/04 15:18:00
   3EBFFA  GAF189                                                         2013/12/04 08:22:30
* 3F4567  POISON                                                         2013/12/04 13:47:32
* 3F5A69  SHOCK1                                                         2013/12/04 18:59:56
* 3F646F  HG01B                                                          2013/12/04 11:27:38
   3F9974  GAF038                                                         2013/12/04 08:05:14
* 3F9C73  GATOR                                                          2013/12/04 09:11:33
* 3F9C73  GATOR                                                          2013/12/04 10:12:32
3FA4DE
Whish you a nice evening!
Regards Ingo
Hi Ingo,
Yes got the Thai Smile
Nothing on the X-files on miscoding lots of errors
39E4AC F-HZFM, A320 on delivery, its in the d/b
3E4BBB D-ITWL 425-0048 Cessna 425 Corsair Konstage GmbH
Many thanks again and have a good night as well.
John Racars
Alan,
at this moment FHY757 from LTAI in landing at EHAM
d/b says LTAI ENGM???
what should I suggest? Better no report FHY flights anymore? There are verry much FHY flights in the d/b Are they all actuell or correct?
Did or does RadarBox delete flights not actuall any more?
For exemple I still see a high number of COA and NWA flights all long time no longer exist!
I do not understand why this flights are still in the d/b COA is UAL and NWA is DAL for longer time...
13 NM East of EHAM
ANRB:
Version: 3D - 5.00.072
PC: Windows 7 SP 1 - 64 bit
RadarBox24 station: EHAM4
Michel
John (and Alan ofcourse),
All FHY flights to and from EHAM are:
FHY711 LTAI-EHAM
FHY719 LTBJ-EHAM
FHY757 LTAI-EHAM
FHY721 LTAI-EHAM
FHY712 EHAM-LTAI
FHY720 EHAM-LTBJ
FHY758 EHAM-LTAI
FHY722 EHAM-LTAI
Michel.
The COA and NWA are in the d/b John as I would have to delete them one at a time indivdually and I just dont have the time to delete them.  It takes me enough effort just keeping the current ones up to date without worrying about ones that are no longer used.
FHY are a charter airline and as such re-use the same flight ID's throught out the year for the summer and winter scedules.  Keep sending them in and they will be changed as required.  FHY757 has been amended and the return FHY758 is already correct in the d/b.
Thanks Michel.  All were in apart from the 719/720
John Racars
Thank you for explane this. All clear and I will still report to you ofcourse!
13 NM East of EHAM
ANRB:
John Racars
Alan,
verry sorry but I stopped looking up flights this evening because I discovered most of all my reported yesterday flights are not processed for any reason. What happens with my yesterday report I am asking me. Is it processed or not and if not, why not. For exemple all the TAY flights are not processed. They are all in my report of missing flight again while they where in my post #741.
If you don't agree with my reported "new" ones I would like to know so I do't have to look to them every day.
No problem at all but please let me know if my reports will not procesed for any reason.
13 NM East of EHAM
ANRB:
John,
The routes are processed before I offer my thanks to each contributor.
All routes notified have been processed but the Navdata updates do not appear to have had these applied for the last few days.  See http://www.airnavsystems.com/forum/index.php?topic=7959.msg99615#msg99615 and my reply.  Additionally a few hundred routes have been added or amended by myself since yesterday in addition to the ones notified via this thread.  The same applies to any other table not just routes.  Airnav were advised yesterday and I am awaiting the the defect to be corrected to bring the Navdata up to date with all the changes made,
If you click on an aircraft with the route applied which is not in the Navdata but you have advised me of it, it will be updated via autopopulate.
CYYZGUY
40" LED Monitor
40" LED Monitor
Its another Travel Service B738 going on lease with Sunwings Jason.
The Navdata updater facility of databse explorer is not working due problems on the server routine. Airnav are aware and are working to rectify.  Autopopulates are still working.
Morning Alan,
Currently arriving at Alicante is a Jet2 flight from Leeds/Bradford using a flight ID of LS271Q instead of the usual EXS271Q. First time I have seen one using that flight ID with the result that the logo will not display. Is there something you can do at your end which will allow this logo to display for any future flights using this flight ID instead of the regular one.
Michel
Alan,
DAL32 KATL-EHAM iso KATL-KMIA-EHAM
BLX659 EFHK-GCRR iso ESSA-GCRR-LCLK
MPH74 SEQM-KMIA-EHAM iso SBKP-SEQM-SEGU
Michel.
