Started by orkney, November 07, 2013, 02:30:03 PM
The server updater software is playing up again. Error message being given, Airnav advised.
M
Here's some route updates anyway.
GWI2J   EFHK   EDDT
SAS2716   ESSA   EFTU
NWS3511   ULLI   MMUN
NWS3512   MMUN   ULLI
AEG7003   EETN   EFHK
AEG7004   EFHK   EETN
WZZ40Y   EPGD   EFTU   (not LEBL-LRCL)
TSO517   UUWW   CYYZ   (not UUDD-CYYZ)
TSO518   CYYZ   UUWW   (not CYYZ-UUDD)
TSO558   KLAX   UUWW   (not KLAX-UUDD)
Many thanks M
Autopopulate is working OK
X
Two C130T's are/were in the area. 165379 which should have just ended its stint and was due to go home and 164998 which has just arrived and as I have not picked it up so far so I suspect it is the latter
   924924                           VARIOUS    N/A   Being used by bot... 2013/12/16 10:31:32
   924924                           VARIOUS    N/A   Being used by bot... 2013/12/16 11:35:32
   924924                           VARIOUS    N/A   Being used by bot... 2013/12/16 14:31:19
   924924                           VARIOUS    N/A   Being used by bot... 2013/12/16 15:47:12
X
Thats at least 2 C130's and an E6 using that miscode.  Jacobite picked it up over Newcastle direction at the end of last week so that must have been it on its way to you.
Xon
A1C53D N213G PC12 c/n 1260 ex SP-NPC
mikek
Took my laptop on an adventure to Auckland airport and got the following not populating. They are all ground codes.
Unsure if you do anything with them. Type is based on their 'callsign'.
C87E00   Ground   Airport Vehicle
C87E07   Ground   Airport Vehicle
C87E09   Ground   Airport Vehicle
C87E0A   Ground   Airport Vehicle
C87E0B   Ground   Airport Vehicle
C87E0D   Ground   Airport Vehicle
C87E14   Ground   Sweeper
C87E20   Ground   Airways Corp Vehicle
C87E28   Ground   Airways Corp Vehicle
C87EE0   Ground   Unknown
C87EE1   Ground   Unknown
C87EE2   Ground   Unknown
Thanks,
Mike
Thanks Mike, all marked as GND
Off Toulouse as GIA9721 is 8A03C1 PK-GPS Airbus A330-243 c/n 1474 Garuda Indonesia
Another of Toulouse on delivery is 750333 9M-AJA Airbus A320-216 c/n 5897 AirAsia heading to Sharjah for fuel
Michel
Not sure what Transavia is up to, but it looks like they changed a lot of callsigns again....
TRA100L GCLP-EHAM
TRA101R EHAM-GMMX
TRA115G LEVC-EHAM
TRA12SM EHAM-GCLP
TRA124L GCLA-EHAM
TRA18GR EHAM-LEVC
TRA286J LGAV-EHAM
TRA354M EHAM-LEBL
TRA368A GMAD-EHAM
TRA371Y GCTS-EHAM
TRA40QM EHAM-LIRP
TRA42BT EHAM-GCRR
TRA42QP GCRR-EHAM
TRA50ZB EHAM-LOWI
TRA52PZ EHAM-GCLP
TRA55BM EHAM-LPPR
TRA593R EHAM-LPPT
TRA60J LPMA-EHAM
TRA61KP EHAM-GCRR-GCTS
TRA61TL GCLA-GCTS-EHAM
TRA654N EHAM-GMMX
TRA663Y EHAM-LPMA
TRA72SE EHAM-LPFR
TRA77RH EHAM-LIMF
TRA772Q EHAM-GCLP
TRA780P LPPT-EHAM
TRA78RR EHAM-LFMN
TRA89JN EHAM-LEAL
TRA949U LPPR-EHAM
TRA953T LOWI-EHAM
TRA985Q LEBL-EHAM
TRA99JQ LEMG-EHAM
Could be some of them are in the d/b already.
Michel.
Many thanks for those Michel
CYYZGUY
40" LED Monitor
40" LED Monitor
Xon
