New AirNav RadarBox 5.00.62 Beta Upgrade
Started by AirNav Development, December 01, 2013, 09:34:22 PM
Dave,
I presume from your reply that you didnt change the circle colour?
Kenny
Just relised this from email alert from AN, that my radar was absent for 24 hr.  And that was some time already.   Luckily that I still have remote control ability since I was 600 km away from the PC unless BKK will blackout for the whole week.
If possible, please release next beta before the current one expired.
Thank in advanced.
Kenny
ANRB 3km north of VTBD
Starburstdave
Yes I changed the colour of the radar rings back to the default colur and still got the big white circle but I have now changed the map back to the "real radar " default scheme and things are running ok after I toggle the trail lines option in the map menu.
Dave
Just had to do the same thing here. Trail lines were off and the white circle was there. Switched them on and the circle has disappeared !
Wierd, I can toggle my trail lines and only thing that happens it the trail lines disappear or come back.  What colour are your trail lines?.  Mine are at the default setting of purple.
I have passed all this on into the task system for the Developers info.
Starburstdave
My trail lines are the default colour of purple also but I choose not to display them so I just toggle the setting on then off again and this appears to do the trick but when I close down the software and restart I have to toggle the trail lines on and off again.
Dave
Starburstdave
Thanks again for taking the time to help.I think I will call it a day for today.
Happy new year to you
Dave
By setting the trial line length to one sec I was able to generate the white circle for a few seconds, but it has disapeared by itself.
By the way: The populate button under MyLog is still working only one time after software start. After that: nothing.
Thats correct as the fix for this is still to be progressed.  Now that we have daily Navdata updates available along with autopopulation we are now require to discuss whether it is still needed and if so how it should work
Ingo,
Good tip regarding the white circle which is now starting to become a nuisance. I had the trail lines set at 10 seconds but have now reduced to 1 second so will wait and see what happens.
Have a good New Year.
CYYZGUY
Ok, I am home and did the upgrade...Interestingly enough, I have NO problem with the radar rings.
regards,
Jason
40" LED Monitor
40" LED Monitor
My trail lines are the default 300 seconds to remove and I dont have any problems but then again I have never seen a white circle either.
I tried to force a re-appearence of the white-dish, but hadn't any succes with it. I performed a re-do of the procedure that has resulted in the appearence in the first time. But no success this time. Seems that my system configuration is one of the lucky ones that isn't affected.
