New AirNav RadarBox 5.00.62 Beta Upgrade
Started by AirNav Development, December 01, 2013, 09:34:22 PM
shouriken
Liviu
A.net JetPhotos.Net
RadarBox
There hasnt been a further beta release since that post Liviu.
donburrows
I presume that it is 64 bit drivers you are looking for, if thats the case they are on the support page here http://www.airnavsystems.com/download/ANRB/drivers/ANRB64bitDrivers.zip
Some (minor) issues:
As in V4 alert sending stopps after a couple of days. I tested it with alert on D-ABY*. As soon as each airframe containing D-ABY (the B748's of DLH) was received one time, no further alerts were sent although an airframe was received again. After clearing the ALERTS Log list the alert function is working until each airframe is back in the list again. Maybe it's wanted to work that way, but I would appreciate if alerts were working regardless how many times an airframe was received.
About database updates: We have an encrypted db now and I can live whith it, but regarding to my slow net connection I would appreciate, if the db updates would be delivered in a compressed style. Downloading 67000kB with less than 1MBit is torture.
Is it possible to add a re-start button to the update submenu to avoid the procedure: manually shut down SW, waiting until ANRB process has really stopped and than re-starting SW by clicking on RB SW ICON. In my opinion it would be more comfortable to have this done by one simple click.
Regarding errors on remote Access:
I noted that ANRB SW is producing errors while clicking on menu buttons, if an established remote connection forces windows to switch the colour theme from Aero to Standard and back. If colour theme stays on Aero or (XOR) Standard no problems are showing up.
That's it for now!
Merry Christmas!
Regrads Ingo
tommyg
Is anyone else having trouble downloading the routes database? I can download the acft db with no problem, but if I try the routes db I get error ' invalid file received from server'. I only found this out when I couldn't to a mass download of all files in the db.
Merry christmas to all the long suffering users.
tommyg
Tommyg
#36
Tommy, I downloaded the lot about an hour and a half ago to my two computers with no problems, routes included.
Just did it again to check as per attached shot.
Confirming, download and install successful on my end.
tommyg
Thanks Guys.
Have had to do a complete uninstall/install to cure the issue. Aaargh!!
tommyg
Tommyg
Looks like you had a corruption in your Navdata Tommy
Don,
As we havent heard from you further, have you got it working?
NigelR
I upgraded in early December and everything has been running smoothly until this morning. My Radarbox is working fine (plenty of aircraft in my log) but nothing on the display. If I try to modify the display I get a continuous cascade of the following error message ' List index out of bounds (359)' Can anyone help please and suggest what might have happened?
Probably just a coincidence but yesterday I signed up to be a feeder for Radarbox24. Everything seemed to be working fine yesterday after doing that.
Many thanks
What happens if you close down and restart Nigel.  I wouldnt think signing up to RB24 will have anything to do with it as you say a coincidence.
NigelR
Hi Alan
just the same when I close down the program, also when I shut down my pc and reboot.
Many thanks
Nigel
#44
Hi Nigel,
Its to techy for me.  I would suggest you contact support direct on [email protected]
