Started by orkney, January 27, 2014, 05:29:14 PM
orkney
Hello Ingo
That one is added.
Andrew
Kenny
#1576
886282 HS-XTB Airbus A330-343X c/n 741 ex 9M-XXM   op Thai Asia X
TAX700 VTBD RKSI
TAX701 RKSI VTBD
Route TAX11, TAX162 and TAX82 belongs to previous airline using TAX which can be removed
Kenny
ANRB 3km north of VTBD
M
Some routes (the first and last route are amendments to the database, the other ones are new additions):
WZZ1009 EVRA ENBR
WZZ1220 ENBR EVRA
NAX5916 EFHK LBBG
NAX5917 LBBG EFHK
KKK840 LTAI ESPA
KKK841 ESPA LTAI
FIN4KD EFHK LGSA
FIN6XA LGSA EFHK
SCW75B ESNU ESSB
SCW98R ESSB ESNU
FCM3RQ EFOU EFHK
FCM2MP EFRO EFHK
OHY2189 LTAI ESNS
OHY2190 ESNS LTAI
KZU1403 LTFJ EETN
KZU1404 EETN LTFJ
CAI551 LTAI ESSA
CAI552 ESSA LTAI
TAY937Y EETN EBLG  via EFTU
mikek
Not populating
76CEC6
Should be 9V-SVF, B772 with Singapore Airlines on return from Royal Brunei
Mike
paul tricker
#1579
Alan/Andrew
Had this twice today..
4C1D82  YUHMC                                                          2014/05/04 14:55:41
heights (between 1800 & 900) would suggest a helicopter or light aircraft. I have drawn a blank on Google.
Over to you two
Paul
orkney
Hello Paul Mike M and Kenny
M, Mike and Kenny - Al your ones are added.
Paul - YU-H implies that it is a Serbian helicopter  but it isn't on the Official register of Serbia yet.
Thank you
Andrew
flygfantast
Alan/Andrew
440712 OE-DIP, Cessna 182P Skylane, c/n 18264384
Niklas
Cable: Ecoflex-10 (10m+1m)
orkney
Hello Niklas
That one is added.
Thank you
Andrew
Evening, unknowns from Saturday:
   38C0FC  FJVLQ                                                          2014/05/03 14:06:40
* 3C498F        2014/05/03 11:47:10
* 3D07A1  DEBDH                                                          2014/05/03 10:40:45
   3D0FA3  DEEED                                                          2014/05/03 14:02:56
   3D0FA3  DEEED                                                          2014/05/03 15:18:39
   3D1075        2014/05/03 10:16:36
* 3D1111        2014/05/03 09:04:43
* 3D2F2E        2014/05/03 10:10:50
* 3D2F2E        2014/05/03 12:52:10
   3D34BC        2014/05/03 14:36:10
* 3D3D5E        2014/05/03 09:57:07
* 3D3D5E        2014/05/03 15:47:56
   3D3F16        2014/05/03 14:08:18
   3D3F16        2014/05/03 16:53:47
   3D4831  DEZOZ                                                          2014/05/03 11:17:48
* 3E6440  DKDDW                                                          2014/05/03 13:21:30
* 3EAAF8  GAF402                                                         2014/05/03 10:48:50
* 3EAAF8  GAF402                                                         2014/05/03 13:42:46
* 3EAAF8  GAF402                                                         2014/05/03 16:50:18
* 3EC8FD  DKRBP                                                          2014/05/03 14:10:28
* 3EF0D2        2014/05/03 13:09:25
* 3EF7C4        2014/05/03 12:06:23
* 3F0678        2014/05/03 11:24:01
* 3F0678  D9697                                                          2014/05/03 14:10:45
   3FEEE6  DMMSD                                                          2014/05/03 11:20:38
* 3FEEF5  DMRDI                                                          2014/05/03 10:39:16
   3FF0C5  DMFLH                                                          2014/05/03 10:58:17
   3FF0C5        2014/05/03 12:33:06
   3FF209  DMGCL                                                          2014/05/03 10:34:22
   3FF233        2014/05/03 10:15:32
   3FF233  DMURF                                                          2014/05/03 12:32:04
* 3FF2FA  DMRPD                                                          2014/05/03 10:26:01
* 3FF2FA        2014/05/03 13:58:12
* 43E9FA  MSPBM                                                          2014/05/03 02:55:42
   484F64        2014/05/03 11:23:53
   49D134        2014/05/03 09:51:06
   4B8422        2014/05/03 12:43:12
   4CA642        2014/05/03 21:00:38
Unfortunately to slow web speed for investigating myself.
Regards Ingo
itestoo
#1584
Hi Paul
YU-HMC SA-341 Gazelle AH1 -  ex G-KANE
https://www.flickr.com/photos/23231169@N06/4739642591
Laurent
Michel
Alan/Andrew,
TRA1521 EHAM-LTFE
TRA21N EHAM-LICJ
TRA469 EHAM-LTFG
TRA1201 EHAM-LTAI
TRA307 EHAM-LTFG
AFR152M LFPG-EDDW
KLM1830 EDDT-EHAM (I guess it's in the d/b, but didn't show it's routing)
Michel.
jim_stockwell
Andrew/Alan
Not sure what is going on, but a balloon has just drifted by reg G-LLGE on the canopy but G-BZDE appears on the flight table. The canopy of 'GE' is of the same design as 'DE'
Could be using their old box I suppose without re-setting the hex.
Jim
orkney
Hello Ingo
The only ones I can find are:
3D07A1  CTLS
3D2F2E  P28A
3D34BC CP30
3D3D5E p28a
3D4831  e300
3E6440 dg60
3FEEF5  MD3 Rider
3FF2FA   COY2
43E9FA CL60
484F64 DG80
Thank you
Andrew
Hi Kenny,
780B2A was added last night as B-8271 Gulfstream Aerospace GIV-X (G450) c/n 4271 and will be in todays Navdata download or via the populate function
886282  was added to the database last night as HS-TXB and will be in todays Navadata download or via the populate function.
orkney
Hello Laurent and Michel
That is your ones added
Andrew
