Started by orkney, January 27, 2014, 05:29:14 PM
Hi Michel,
Thanks again, BTW Cambridge is EGSC
M
VKG167 ESSA HEGN
VKG168 HEGN ESSA
Michel
Alan,
Two more for EGSC ;)
BCY322 EGSC-EHAM
BCY323 EHAM-EGSC
Michel.
Afternoon Alan,
Just a general query. I have been noticing in some cases full flight information appearing on the grid but no route showing. When I go into d/b explorer the route information is showing but the date stamp shows 2012 or 2013. It would appear that the system is not picking up route details which are this old. Is this correct and is there anyway technically that this can be overwritten thus avoiding asking you for 'missing' routes which are actually there.
#1746
Hi Ian,
It was asked for by users that routes are expired after a time period, something like 3 months I think to ensure they are updated and show the correct route.
The only thing I can do is to press the button to put them through again once advised and after checking they are still correct to update the CH date.
Cheers Alan,
It's only been a few instances. You are doing enough. If there are further instances, I'll just update the date stamp myself and put through again. Once done, would changing the auto update from 'Y' to 'N' stop it from happening again ?
I wouldn't think so Ian the date is the factor here, continue to pass them on to me, its not problem pressing the button again, I do it plenty in a day.
Evening, unknowns from Monday:
* 120000  N62080                                                         2014/05/12 13:03:01
* 3C493C        2014/05/12 17:58:23
   3C4A20        2014/05/12 05:16:30
   3C4DDE        2014/05/12 08:53:54
   3C5EFB        2014/05/12 09:44:33
* 3E82A7  WEASL22                                                        2014/05/12 06:55:52
* 3E85E2        2014/05/12 07:37:14
* 3E8851  GAF123                                                         2014/05/12 06:12:33
* 3E8851  GAF123                                                         2014/05/12 16:23:06
* 3E9EDC  GAF120                                                         2014/05/12 08:31:23
* 3E9EDC  GAF120                                                         2014/05/12 10:07:42
* 3EA9AC        2014/05/12 15:30:27
* 3EAB46  PANTER15                                                       2014/05/12 07:12:11
* 3F4B82  TA145                                                          2014/05/12 11:51:50
* 3F5FF4        2014/05/12 12:18:36
* 3F5FF4        2014/05/12 13:11:43
* 3F65BF        2014/05/12 12:18:38
* 3F65BF  MOJO34                                                         2014/05/12 13:08:26
* 3F72A6  MOJO31                                                         2014/05/12 12:18:04
* 3F72A6        2014/05/12 14:01:58
   3F7B35  GHOST61                                                        2014/05/12 07:23:59
   3F7B35  GHOST11                                                        2014/05/12 12:01:57
* 43E80E        2014/05/12 14:07:20
   4681F8        2014/05/12 09:03:38
* 4681FD        2014/05/12 09:01:06
* 4681FD        2014/05/12 09:57:53
* 46826A        2014/05/12 09:01:40
* 46826A        2014/05/12 09:57:58
* 478774        2014/05/12 07:06:52
* 4B82B4        2014/05/12 07:25:16
* 4B82B5        2014/05/12 07:25:03
* 4B82BC        2014/05/12 07:24:46
   4CA63E  EIN37X   LBBG-EIDW                                             2014/05/12 21:24:47
* 506F65        2014/05/12 12:28:07
Regards Ingo
Evening Ingo,
120000  N62080 Thrush S2R-H80 c/n H80-156DC Thrush Aircraft on delivery noted in Wick, not being added to d/b
3C493C doesn't decode
3C4A20 doesn't decode
3C4DDE doesn't decode
3C5EFB doesn't decode
43E80E unknown to me
4681F8 unknown to me
4681FD unknown to me
46826A unknown to me
478774 unknown to me
4B82B4 unknown to me
4B82B5 unknown to me
4B82BC unknown to me
4CA63E not current
506F65 unknown to me
Michel
Alan,
CFG2EC GCRR-EDDH iso GCTS-EDDL
Michel.
An Airbus delivery thanks to John Hargreaves
Out of XFW as TCX53UG is 406AE0  G-TCDG  Airbus A321-211 c/n 6122  Thomas Cook Airlines
