Started by orkney, January 27, 2014, 05:29:14 PM
flygfantast
Not populating 485091 using c/s HSV150, should be an ex Direktflyg aircraft I suppose. (PH-OCJ??)
Niklas
Cable: Ecoflex-10 (10m+1m)
Hi Niklas,
I added it into the d/b around 30 minutes or so ago.
485091 PH-RCI British Aerospace Jetstream 3212 c/n 848 AIS Airlines ex SE-LHH
CYYZGUY
Hi Alan, any info on this flight?  A first for me in this area..
SVW39VV (Globaljet Luxembourg)
Mode-S 4D020F
A319
Charter?  No route showing..Just wondering if you know what it might be?
Jason
40" LED Monitor
40" LED Monitor
X
#273
VABB unknowns...Guess what?.... mostly follow me and fire vehicles, I would suggest from the sequencing that 80087A thru C are possibly Followme 3,4 and 5. Also 8007DC VTKPL was doing very odd things and unairplane up and downs so might actually be a test hex as I was advised.
* 800151        2014/02/14 09:45:19
* 800653        2014/02/14 10:12:33
* 80070C        2014/02/14 10:32:12
   8007DC  VTKPL                                                          2014/02/14 10:00:54
* 800877  APRNCT01                                                       2014/02/14 14:37:20
   800879  FOLOWME2                                                       2014/02/14 14:16:34
   80087D  FOLOWME6                                                       2014/02/14 15:19:38
* 800881  FIRETEN1                                                       2014/02/14 13:48:35
* 800882  FIRETEN2                                                       2014/02/14 15:14:28
* 800883  FIRETEN3                                                       2014/02/14 11:19:47
* 800884  FIRETEN4                                                       2014/02/14 15:27:47
   800887  ILSMUM01                                                       2014/02/14 00:00:00
* 80088E  DUTYOFIR                                                       2014/02/14 15:25:13
X (back in sandpit)
X
#274
One ANZ delivery? and one overnight sandpit unknown......plus A6-EEQ was finally delivered.
* C820F4  ANZ6397                                                        2014/02/14 19:11:08
* 770451        2014/02/15 02:38:44
* 896190  UAE7380  EDHI-OMDB       A6-EEQ     A388  Emirates             2014/02/15 02:20:01
the ANZ is possibly ZK-OXD A320
The Sri Lankan is probably 4R-ABQ (ex A7-ADX) which was to be delivered ex DOH
X
Morning, Routes:
WZZ67S (HA-LWI)
EZS73LG (HB-JZQ)
WZZ4LN
Hi X
VT-KPL is most definately a valid registration see http://www.dgca.nic.in/caris/know_regn.asp?regn=KPL  Its actually as you can see got a Dubai owner
800151 used previously by A310 VT-AIH which became D-ALAD and is now b/u
800653 and 80070C both unknown to me
Jason,
The A319 is a business jet and yesterday it flew KLAX-KJFJ https://flightaware.com/live/flight/LXGVV
X
C820F4,ZK-OXD,5962,Airbus A320-232,Air New Zealand added to the d/d yesterday and flew LFBO-LCPH-OOMS on delivery
I cant definately confirm that 770451 is 4R-ABQ however Skyliner shows it for delivery today OTBD-VCBI and it look a good bet.
Ingo,
WZZ67S EPKT-EDLW
WZZ4LN EPWR-EDLW
I have no concrete info on EZS73LG, looks like I shall need to get up very early one morning so look for these flights
Michel
Alan,
TRA753Z EHAM-GMMX
TRA6G EHAM-LPMA
TRA85K EHAM-GCRR
TRA951Q EHAM-LPPT
TRA611M EHAM-LEMG
TRA591A EHAM-LOWS
TRA131R EHAM-LEBL
TRA357M EHAM-LPFR
TRA117A EHAM-LEMG
TRA133V EHAM-LEBL
TRA87R EHAM-LPFR
TRA581F EHAM-LFMN
TRA143C EHAM-LEAL
TRA1E EHAM-LPPR
TRA135P EHAM-LEBL
TRA601Z EHAM-LOWI
TRA423N EHAM-LIRP
TRA61L EHAM-GCLP
TRA61R LOWI-EHAM
TRA592J LOWS-EHAM
TRA332A LEVC-EHAM
TRA132J LEBL-EHAM
TRA952P LPPT-EHAM
TRA116C LEMG-EHAM
TRA86W GCRR-EHAM
TRA750C GMMN-EHAM
TRA868A LGAV-EHAM
TRA118C LEMG-EHAM
TRA88J LPFR-EHAM
TRA66K GCLA-EHAM
TRA74W GCTS-EHAM
TRA424L LIRP-EHAM
TRA2V LPPR-EHAM
Michel.
Morning Alan,
VLG1241 : LEAL-EGFF
Many thanks Michel, much appreciated
#284
Alan,
MON846L : EGGW-LEAL
VLG4204 : LEZL-LEIB
