Started by orkney, January 27, 2014, 05:29:14 PM
#330
Shouriken, this is a known bug, that has been fixed and will come with the next release, as Alan told me on Saturday.
By the way: populate does only work one time after a re-start of the sw. If you launch it  the second time after sw start it will do nothing.
shouriken
Yes, I know. But I always get confused about it :(
Liviu
A.net JetPhotos.Net
RadarBox
It's a pain in the... The alternative: Downloading a new DB every day isn't fun either. But enough about this...
If you click on it before I have it in the database it doesnt populate until next time picked up or you restart, same as previous versions
As far as we are aware it is fixed but I am sure you will let me know if it isnt!!, It worked for me when trying it out.  It should only need one press of Populate to get your unknowns downloaded especially if you regularly download a new NavData and only populates your mylog unknowns now.
I tend to run populate before I close down if I have any unknows and before sending my log.  Thankfully for most downloading a new Navdata is a non-event and for me is preferrable to Populate as all the updates are in the database and not just the mylog unknowns.
X
735282 EP-TTB A320 picked up today in service
X
X
Todays unknowns and miscodes
* 3C4ADD        2014/02/17 21:16:30
* 4E540A        2014/02/17 20:15:55
* 591000        2014/02/17 15:37:01
* 896369        2014/02/17 17:55:49
* CE546C        2014/02/17 20:15:58
Miscoder A57FCE c/s AAAA5252 is a Sharjah Police Bell 412 that was buzzing about while at SHJ but could not read it in dark.
X
Thanks for the Atrak Air A320
They like their miscodes over there.  Looks like they put anything they want in for a hex code going by some of those ones.  Nothing on any of them apart from-
896369 my d/b gives as A6-DBY A109E c/n 11626 Dubai Air Wing
CYYZGUY
#337
UAL1024
CHQ4980
JAI9003
No route
regards,
Jason
40" LED Monitor
40" LED Monitor
Jason
UAL1024 KPDX-KIAH-KORD, today but yesterday may be different
CHQ4980 KCLE-KPVD
JAI9003 is the delivery flight of VT-JFR B738 of Jet Airways through Toronto from Boeing Field
Xon
4B065B SP-CKP C152 c/n F15201944 (prev HB-CKP)
45D04B SP-TBK P28R c/n 2844043 (prev OY-TBK)
Michel
One more Alan,
TRA751A EHAM-GMMX
Michel.
diddyboy
Hi Alan
Unknowns so far today, which are not populating.
38371A is test reg from Airbus
The Aeroflot should be VQ-BRW A320 on delivery from TLS today, and the Air China should be B-5912 A330 also on delivery today out of TLS.
* 376300  7000                                                           2014/02/18 15:01:38
* 3835BA        2014/02/18 13:10:10
* 38371A  AIB02TV                                                        2014/02/18 13:09:50
* 3B7B46  FDO7522                                                        2014/02/18 13:16:03
* 3F9F20  GAFW29                                                         2014/02/18 10:02:06
* 42458C  AFL7611                                                        2014/02/18 10:59:33
* 4CA560        2014/02/18 14:28:43
* 780BF9        2014/02/18 09:46:09
Neil
Evening, the unknowns from Monday:
   3C0CA5  TUI8276                                                        2014/02/17 08:28:38
* 3C5C4E        2014/02/17 16:52:46
   3D3873        2014/02/17 14:12:26
   3E8890  GAF626                                                         2014/02/17 10:43:14
   3EAABF        2014/02/17 13:05:31
* 3F81CC        2014/02/17 07:37:03
* 3FAC9F        2014/02/17 11:20:56
   400574        2014/02/17 13:52:17
   400C46        2014/02/17 21:22:22
* 440012        2014/02/17 09:59:17
   445566        2014/02/17 07:53:47
   445566        2014/02/17 16:41:30
* 45C94B        2014/02/17 07:41:14
* 47240D        2014/02/17 09:57:10
   473413        2014/02/17 18:37:05
   484C55        2014/02/17 17:06:38
   49D2BB  NTF58A                                                         2014/02/17 07:29:14
   49D2BB        2014/02/17 20:59:03
   980000        2014/02/17 08:45:31
* AC7774        2014/02/17 16:20:42
Regards Ingo
unknowns routes from Monday:
QTR3258
BER211M (D-ABDU)
BER158M (D-ABFE)
BER311P (D-ABKS)
DLH5UC (D-ACKA)
DLH5YF (D-ACKB)
DLH5UV (D-ACKK)
DLH2VR (D-ACNJ)
DLH4HR (D-ACNL)
DLH4WY (D-ACNW)
BCS7476      D-AEAE
BCS811      D-AEAI
BCS947      D-AEAM
BCS873P      D-AEAP
BCS6903      D-AEAS
GMI242      D-AGEN
GWI2F      D-AGWO
GWI518N      D-AGWQ
GWI25BT      D-AGWW
BER647      D-AHXC
BER863      D-AHXE
DLH9921      D-AIRR
DLH2FL      D-AIZD
DLH5KW      D-AIZF
GWI2HC      D-AKNK
GWI6901      D-AKNM
GWI6900      D-AKNP
BCS6921      D-ALED
BCS810P      D-ALEG
BCS6824      D-ALEI
ISK350K      D-ANFC   AT72
ISK351K      D-ANFC   AT72
ISK356K      D-ANFC   AT72
ISK357K      D-ANFC   AT72
SXD2LP      D-ASXG   B738
AFR163H      F-HBXN   E170   Hop!
WZZ872      HA-LPI   A320   Wizz Air
WZZ890      HA-LPS   A320   Wizz Air
WZZ1XU      HA-LPV   A320   Wizz Air
WZZ206      HA-LPW   A320   Wizz Air
EZS73LG      HB-JZQ   A319   easyJet Switzerland
VIM8136      LZ-MDR   A320   Air VIA
VIM8137      LZ-MDR   A320   Air VIA
ISK300B      OE-LIB   AT76   Intersky
ISK370H      OE-LID   AT76   InterSky
CSA7321      OK-KFO   AT45   CSA Czech Airlines
CSA7322      OK-KFO   AT45   CSA Czech Airlines
SUS16      OY-NCT   J328   Sun-Air of Scandi...
SUS01D      OY-NCW   J328   Sun Air of Scandi...
SUS03D      OY-SVB   JS32   Sun-Air of Scandi...
KLM808      PH-BVI   B77W   KLM Royal Dutch A...
KLM18S      PH-KZD   F70   KLM Cityhopper
TRA833W      PH-XRC   B737   Transavia Airlines
TRA923N      PH-XRY   B737   Transavia Airlines
BGY2505      SP-ADK   A320   Bingo Airways
SXS9AG      TC-SNN   B738   SunExpress
WAU97P      UR-WUA   A320   Wizz Air Ukraine
WAU761N   UR-WUD   A320   Wizz Air Ukraine
GLP9984      VP-BQF   B738
BTI2GY      YL-BAJ   DH8D   Air Baltic
BTI9802      YL-BBQ   B735   Air Baltic
Hi Neil,
You are correct in your assumtions on the AFL and CCA
376300  unknown to me
3835BA  F-WWTk Airbus Test Registration
38371A  F-WWTV Airbus Test Registration
3B7B46  unknown Alpha Jet
3F9F20  tactical
4CA560 unknown to me
