Started by orkney, January 27, 2014, 05:29:14 PM
paul tricker
Morning Alan
another route needs tweeking I'm afraid
CPA067   EDDF-VHHH-EGCC  first two need swapping around
Paul
CYYZGUY
Hi Alan, can you take a look at this flight for me?
Flight ID: RV1807 Comes up as (Air Canada Rouge)
Mode-S (C0405A)
The logo appears as "Caspian Airlines"
Is this in fact an air canada plane?
Jason
40" LED Monitor
40" LED Monitor
M
Didn't populate:
* 4406DE  AUA1471 <- B772 OE-LPE (ex VN-A147)
AE2209 C30J is in database as 08-0602, should be 08-8602.
paul tricker
A couple of non-populators..
4A91AB  KMF007                                                         2014/03/06 11:35:58
drawn a blank here
4B12D0  PCH22R                                                         2014/03/06 11:26:38
possibly HB-HDG, it was a few minutes behind 4B12CF  HB-HDF PCH21B which did populate
Paul
superspotter
Good Morning once again from Lagos;
Alan, the Airnav Db has UK hexcode 406193 as a Jabiru G-EHIH. Five or six times now I have had this pop up here in Lagos and I have just managed to nail it as G-FABO CL604, called it's reg as usual upon landing. Callsign was "express 604", regards clive.
Good morning Clive,
406193 G-EHIH now deregistered as sold in  the Netherlands
G-FABO is allocated 406983 and is in the d/b as such so would appear to be miscoding.  Have added the miscode to the d/b
Paul.
4A91AB decodes to SE-DMK, this became YA-KMZ with Kam Air.  Given that KMF is Kam Airs ICAO identifier, looks like it is miscoding its old ID.
4B12D0 HB-HDG Pilatus PC-7 II c/n 722 on delivery to become P133 with the Indian Air Force.  HB-HDF is to become P132
Thanks M OE-LPE was delivery to Manchester in basic Vietnam Airlines livery for repainting
Jason,
RV is the IATA identifer for Air Canada Rouge, the low cost arm of Air Canada aimed primarily at the leisure travel market.  RV was in the d/b as the IATA identifier for Caspian but I have changed it to the correct IV
The route you refer to is in the d/b under the ICAO identifier ROU1807 MROC-CYYZ
Paul,
From what I can see CPA67 is flying today VHHH-VOMM-OMDB-EDDF.  It sometimes flies via VIDP instead of VOMM and misses out Dubai.
paul tricker
Thanks for the info Alan.
I admire your persistence with freight flights!
BTW
Cathay have moved their freight services to OMDW (effective 01/02/14) on a permanent basis & not just for the runway closure period at OMDB
Paul
Cheers Paul,
8963BE A6-ANW Airbus A320-214 c/n 6000 Air Arabia has done a UK airspace visit and is heading in your direction now.
superspotter
One to keep an eye on Alan!
Nigerian hexcode 0640DA which is 5N-BMP Be350. As I was on the flightdeck of my 767 today, I had tower on and "NGR-039" departed. This would equate to a registration of NAF-039. I noted the time and when I returned to the hotel I checked Airnav and the only Be350 transmitting at that time was 5N-BMP. So maybe a reg/owner change?
regards clive.
I dont have any other info over here to add to what you have Clive,.  Is there a flight ID against 5N-BMP in mylog/reporter
superspotter
Yes there is Alan but I am unable to read it all because the column isn't wide enough. It says "Presidential Impl...."
regards clive.
