Started by orkney, January 27, 2014, 05:29:14 PM
Hi Clive,
It doesn't look like it has been in the d/b previously as it is showing as the hex was first picked up on the network 16/09/2012
A85C88 N638MA Raytheon Hawker 900XP c/n HA-0194 WFBN/M Ada Ojo/Midway Airlines
superspotter
Something not right there Alan, I first saw this frame here back in 2012 and I am absolutely sure I have seen it every trip here in the Airnav Db?? regards clive.
Evening Niklas,
I remember deleting it but cant remember were I got the info, possibly the February AMCAR, but it is to take up PH-HCI. I have however just looked at the Dutch register and it is not included yet so looks like it has still to take place,
As it would appear to be still on the Norwegian list I have added it back in,
Many thanks
I can only go with what the updater is telling me Clive, the record was blank apart from the hexcode and the timestamp on the date detailed.
I just searched the registration instead of the hex code and it is in the database using a miscode of 113A15.
Jason,
AC411 is in the d/b under its ICAO ACA411 CYUL-CYYZ
superspotter
Ah, OK, that would explain it then and confirms to me that I am not going totally daft! Not yet anyway....
Looks like 2 years later they have the box sorted, well at least one of them!
superspotter
Just re evaluating my initial mail about N638MA and now I see the Russian miscoded hex, I realise that is the one I have been seeing every trip and not the correct US hex, I apologise Alan...
CYYZGUY
SWG9567
No route
regards,
Jason
40" LED Monitor
40" LED Monitor
superspotter
Good morning from Lagos;
Hexcode 0640E5 is 5N-BMX Bristows Nigeria S-76. I was watching this one ping all day yesterday on the ground so I assume they were readying it for service. It has just departed now on an air test callint the reg as it's callsign as per usual for Bristows, regards clive.
Good morning to you Clive,
Many thanks, now added
Morning Jason, SWG9567 routed CYYZ-CYYC assume on a positioning flight.
CYYZGUY
#973
Hi Alan, can you check AC1121, AC1037
SWG9072 No Route
ROU1794 No Route
No route.  Is there anyway I can check the ICAO's to see if they are in the database myself?
I am not the best with the database part of this software..
Jason
40" LED Monitor
40" LED Monitor
Hi Jason,
They will be in database explorer under routes but it is no bother for me to check them.  I wonder why Air Canada  have started using the IATA code as much now instead of ACA.  The two detailed are in the database under their IACO code.  I have raised it as an issue with the developer to see why the IATA code doesn't show the route
ROU1794 these require to be checked these online as ACA and it is CYYZ-TNCC.
SWG9072 is C-FRZG routing CYYZ-EGGW returning to Thomson off winter lease.  Route will not be entered into the database.  All SWG9*** are positioning flights.
