Server Problem?
Started by Aerotower, July 31, 2015, 12:10:34 PM
Manuel,
As no one else is reporting this problem and on checking here everything is working fine, it may be that the problem is at your end some how either on your computer or on your internet connection.
A new high number just now 2920 - when'll we break the 3000.............?
tommyg
Guys.
Has there been a server issue today? 9H-AEO flew over my place and it shows a picture on an Emirates 777!!. Tried to logon to the forum and kept getting error message try again later.
Tommyg
Tommy,
I had a look at what was on the server and the first photo is captioned on Airplane Pictures correctly but is showing the Emirates photo. http://www.airplane-pictures.net/photo/592218/9h-aeo-air-malta-airbus-a320/.  It looks like the problem is at the Airplane Pictures end not the server.
The second photo is correct so I have deleted the first one and placed the second as first to see if that does the trick.
You will need to remove the 777 from your photo folder.
As you have now posted to the forum I take it whatever was stopping you has now been sorted.
tommyg
Alan.
Yes. I tried posting at the time I got the incorrect photo whilst the Air Malta aircraft was still on my box, hence my thoughts there was a server issue.
Tommyg
Undertaker
Server appears down although Website says not, unable to update database at this time 1705L UK time
Tony
Cant see any issues with it Tony, the download is working OK and the network is up and running
Undertaker
Thanks Alan, still Invalid Data Received From Server on the Updates and access violation EEFFEE01 on the Weather
Tony
Undertaker
Shut down and restarted, now seems ok, updating and weather working, probably all those Windows updates recently !?
Tony
