Author Topic: Windows 7 to Windows 10 on ANRB PC?  (Read 35527 times)
shouriken
Re: Windows 7 to Windows 10 on ANRB PC?
« Reply #60 on: August 18, 2015, 05:20:00 PM »
I did update to Win 10 Home my Acer Aspire E15 laptop from Win 8.1 Bing (64 bit) 5 days ago. It is used 24/7 for RadarBox, PlanePlotter, Mil-mode-s and fr24.
Everything is working ok (no need to install/reinstall any driver). I've setup updates to "Notify to schedule restart" and I didn't experience any ANRB freezes.
It seems that the shutdown/startup is slower than in Win 8.1, but it might be just a subjective impression...
Liviu
A.net JetPhotos.Net
RadarBox
« Reply #61 on: August 21, 2015, 06:51:49 PM »
It seems that I figured out what was causing the RB software freeces.
For some reason Win10 decided to activate the run in Win7 compatibility mode. That had caused a huge strain on system resources and led to the software freece. I deactivated the compatibility mode and re-started the software. No more freeces since then. Further the CPU load was reduced by about 60%.
Seems that the old version virtualisation is not capable to run 24/7.
Ibgo
