Author Topic: RTL-SDR Dongle  (Read 55835 times)
Re: RTL-SDR Dongle
« Reply #60 on: January 16, 2016, 03:56:14 PM »
I don't use the version myself by have been advised of the following
1. Some aircraft icons not pointing in the direction of travel, occasionally they correct themselves.
2. A number of ADSB plots on the list but not on the map.  Sometimes double clicking on the list entry reveals the plot on the map
Re: RTL-SDR Dongle
« Reply #61 on: January 16, 2016, 08:36:36 PM »
Andrew, No, haven't tried that.  Direct connection with a 5 metre USB cable.
Re: RTL-SDR Dongle
« Reply #62 on: January 17, 2016, 07:46:41 PM »
That's interesting Chris, I found my RB would not work with a 5M USB lead, that's why I went for the Lindy extension booster lead which solved my problems (voltage drop I assume?) and gave the RB full power.
GreekSpy2001
    • Graham's Aircraft Photos
Re: RTL-SDR Dongle
« Reply #63 on: January 19, 2016, 09:44:08 AM »
Using my RTL USB dongle thru a USB2.0 port.  Would there be any benefit to the Radarbox system by adding a USB3.0 port into my system and plugging the dongle thru that?
graham
Re: RTL-SDR Dongle
« Reply #64 on: January 19, 2016, 11:54:49 AM »
No, as the dongle is usually a USB2.0 type. Word case you will have a compatibility problem,  if the USB2.0 dongle is used with a USB3.0 port. Has not a high possibilty,  but such things happen.
GreekSpy2001
Re: RTL-SDR Dongle
« Reply #65 on: January 19, 2016, 10:46:45 PM »
thanks Ingo.  Did look on the dongle's website for USB compatibility but couldn't find anything.  So won't go down that route for now.
Graham
carras320
    • My Airliners.net Pictures
Re: RTL-SDR Dongle
« Reply #66 on: February 08, 2016, 09:16:51 AM »
Hi All,
In my case reception of the dongle compared from the radarbox improved a lot, now I get flights from far distance and strong signal, it´s really noticeable.
Once the bugs are corrected this will be a great software, but we need options to manage ports in order to have other programs feeded.
Cheers,
Antonio
airbus340
Re: RTL-SDR Dongle
« Reply #67 on: February 08, 2016, 10:51:25 PM »
I am trying to get my dongle to work with version 6 but it is impossible to get it to start... I see other had the same problem too, when I try to start it say "Checking Device" forever... I am sure I have tried 10 times and been waiting sometimes for 15 minutes to I hit Ctrl + C to close it...
Any solutions for this problem?
I use Windows 7 and my dongle is a NEWSKY RTL2832U R820T and it is working perfectly with Dump1090.
GreekSpy2001
Re: RTL-SDR Dongle
« Reply #68 on: February 13, 2016, 01:08:34 PM »
I had similar when my ZADIG driver wasn't running. Have you got this installed on your system?
Graham
airbus340
Re: RTL-SDR Dongle
« Reply #69 on: February 14, 2016, 04:06:05 PM »
Hi Graham, thanks for your reply! My dongle is working with Dump1090 on same computer so doesn´t that mean that the Zadig is installed properly? Or do I have to install Zadig in Airnav software somehow?
Re: RTL-SDR Dongle
« Reply #70 on: February 14, 2016, 04:16:22 PM »
airbus, from earlier on in the thread, If RTL1090 or dump1090 is already running, ANRB.exe won't detect the dongle.
airbus340
Re: RTL-SDR Dongle
« Reply #71 on: February 14, 2016, 06:44:18 PM »
Thanks Alan, none of them has been running when I tried it and I also restarted PC and tried right away, but it didn´t help.
airbus340
Re: RTL-SDR Dongle
« Reply #72 on: February 21, 2016, 04:30:28 PM »
Nobody else that have the same problem? Now I have tried with and without USB extension cable and 2 different dongles of same brand but no luck...
CYYZGUY
Re: RTL-SDR Dongle
« Reply #73 on: February 21, 2016, 06:54:18 PM »
Hi Airbus, I got the NooElec SDR dongle and it started up on the first try got me with Version 6.  I have had no problems.  Still testing and doing some comparisons with the original RB.
Jason
40" LED Monitor
40" LED Monitor
Re: RTL-SDR Dongle
« Reply #74 on: February 26, 2016, 08:03:14 PM »
Information for all those who have V6.00.000 Version running with SDR dongles. It seems that there are different builds available. The latest seems to be from November 11th 2015. I haven't tested if there are bug fixes or improvements between the different builds.
You may consider to go to http://www.airnavsystems.com/download/ANRB/ and dowload the install or upodate .exe again anyway.
