AIRNAV box died/new box or Dongle ?
Started by MIKE.UTD, August 04, 2016, 03:45:35 PM
MIKE.UTD
Yes mini 2+.
Downloaded the airnav 6000 update and the zadig software, a box comes up with the zadig:
Sorry what do i do next ie create device ?
Mike.
Once you have donwloaded and installed zadig plug in the stick.
- open zadig software
- go to option and switch on "list all devices"
- look for RTL2838UHIDIR device
- lookup and install driver in the attached picture
- update ANRB.exe from V5.00.072 to V6.00.000
I did the list from my (brain) memory. Unfortunately it's quite a time since I set up my dongles. So maybe I forgot something.
MIKE.UTD
Items showing are :
MASS STORAGE DEVICE,
BULK IN INTERFACE(INTERFACE0)
BULK IN INTERFACE(INTERFACE1)
USB MULTIMEDIA KEYBOARD
USB RECIEVER(INTERFACE0)
WNDA3200
USB MULTIMEDIAKEYBOARD(INTERFACE1)
USB RECEIEVR (INTERFACE1)
Mike.
Have you plugged any other receiver to your PC?
If not: Try USB Receiver (Interface0). After the WinUSB driver is installed, it shall be renamed to RTL...
MIKE.UTD
Sorry found now with RTL2838UHIDIR(Composite Parent) .
Do I click replace driver now ?
Mike.
Could you make a screen shot of Zadig window (Select zadig window and press ALT + PRINT keys, open ms paint press CTRL+V, save and upload) and upload it here. Will make things (remote diagnostics) easier for me.
MIKE.UTD
Although it may not be required it's a good idea to re-boot the system after the driver was changed.
MIKE.UTD
Also what Windows version do you have
MIKE.UTD
