Windows 10 Not Work ! !
Started by gonz33, September 06, 2016, 01:12:51 AM
Hi, All
Just had the dreaded Windows 10.1 downloaded and as per various comments, AN is no longer working. Tried the fix from Judwin on which I commented in reply #8 above and can't get it too work. Therefore, until AN get the Windows 10 drivers signed off, there will be no further coverage from this area. Apologies for that. I did have AN working perfectly on Windows 10 so why an update to 10.1 is causing it not too work I don't know. Does this mean if Microsoft do future updates to 10.2, 10.3, etc the same problem is going to occur ?
I will contact you to come up and try and fix Ian.  10.1 requires signed drivers, previous versions didn't.  Further updates should not cause any additional problems but depending on what Microsoft do there cannot be any promises on that.
Siddy
Hi Alan done the fixes we did before but wont work this time, the log they sent me was 1437 on the email link
Hi Im Siddy from Leeds, West Yorkshire, Uk
Siddy
I take it 1437 is the auto reply ticket number.  When was it you emailed them, however I don't think even they will be able to help until the signed drivers become available.
Siddy
Yea I gathered that but it p!$$ed off saying dropping by membership for there error, remembering how much we paid for the rb and paying for network each month the feathers came up lol.
If you want I will be able to get you back on Elite
Siddy
Yes if you can as I use it at work as the web site isn't block (yet lol)
Hi guys,
Quick question.
Does anyone know if AN works on the Apple operating system. I've had enough of Microsoft downloading updates which I haven't even asked for and then having to wait God knows how long to get drivers signed off in order to get programs working again.
Ian,
It works on Apple IOS but needs Windows emulation so you would be no better off as it would still need the Windows drivers.
Don't worry though as I will get you online no problem on Tuesday and Windows 10 will no longer impact on you.
Cheers Alan.
I'd better retrieve the box from the skip !
CYYZGUY
Did I miss the discussion somewhere or has Airnav obtained the 10.1 signed drivers from Microsoft yet?  If so, where are they?
Jason
40" LED Monitor
40" LED Monitor
jim_stockwell
Hi All
I had the same problem but overcame it by unplugging my box and then starting AirNav.
It then went through the start process to the end when it showed 2 red boxes against process hardware flights and network. I then plugged in the Radar Box and low and behold everything worked OK
When closing down for the night I have to unplug the box otherwise it hangs.
I should add that I am using the windows 8 drivers and do not have network connectivity.
Hope this helps
Jim
Col
Has there been any update on the certified drivers as my RB has been idle for months now and I would like to get it working again!
Colin
Colin
Wokingham, Berkshire
