Connect to EuroScope ??
Started by LiveATC, May 08, 2008, 02:11:38 PM
Little point in repeatedly posting these screen shots if it's not possible to use EuroScope with RadarBox!
Is this some sort of marketing campaign for Euroscope.  I still can't work out what I'd use it for?  Has anyone worked out what it does, and does it even work with Radarbox?
LiveATC
Why not be possible to use Radarbox Euroscope??? All that is shown here, and provides links where everything is written, read carefully. RadarBox and Euroscope works through port 30003
Yes, but WHY would I want to use it - tell me that!
LiveATC
Ok, we go to the site VATSIM http://www.vatsim.net/, you need to register and get an ID and password.
Go to the download and http://www.euroscope.hu/ Euroscope v.31d
then we go to the site and downloads a sector that is right for you your location http://www.vatsim-uk.org/downloads/index.php
You are still missing the point.  Why would I want to run EuroScope.  As far as I can make out, it is an ATC simulator using SBS data?  I've done all that for real thanks :-)
LiveATC
#36
This alternative network for users Radarbox using data through the port 30003 on the network Vatsim. To connect, you must download a file ready SBStoFSDproxy.
http://rapidshare.com/files/391786063/SBStoFSDproxy.rar.html
http://photofile.ru/users/aviation/115663193/135118135/full_image/
In the server settings introduce
Server ip: 127.0.0.1 port: 30003. To show the air situation need to download the client program Euroscope, http://euroscope.hu/install/EuroScopeSetup31.msi, and still need a sector-file
where the route will be displayed, closed areas, border, airport.
link where you can download sector-file as above.
EuroScope and FSD uses port 6809 for server/client communication. If you run EuroScope on the same machine then simply select the same server (127.0.01 or localhost), fill in all the required fields (the actual values are not important at all). Then click connect.
If you would like to share your server then let port 6809 opened for incoming calls.
Euroscope just open and connect. Fill in all the fields in the connect dialog. Select Direct to VATSIM and connect. It really does not matter what you enter to the fields. The only important thing is to select your server. That should be "localhost" in your case.
ukv1290
Hmm odd when I click connect on euroscope using local host or 127.0.01 it says 'tower listener failed to start' - Any ideas how to sort this out? - I can see a lot of benefits on the SBS data being in EU scope
Tom
LiveATC
When you start the connection, I also published this message, click OK
