problems with latest version help required
Started by 2E0BTX, February 22, 2017, 10:29:45 PM
superspotter
Hi Ala;
In the upper window there are four options: Touchscreen, RTL2838UHIDIR, Intel wireless bluetooth and HP wide vision camera. Underneath that window are two further boxes, the left one has: Driver RTL2832UUSB (v64.....etc. then a green arrow to the next box that has: WinUSB (v6.1.7600.16385).
Does that help?
rgds clive.
superspotter
OK, good news....I managed it all by myself!! :)
Well, not strictly true, both Ingo and Alan helped because I found a previous thread I was looking for started last year by MikeUTD and followed what was said there and all is well.
One thing I am not impressed with though in this version 6.01 is the fact that every time I log on, I have to input password and log in details, something that was always saved on my old laptop.......
kind regards clive.
As long as you are up and running Clive.  I would go back to V6.00.00 and you will not have the problem with log in I believe http://www.airnavsystems.com/download/ANRB/ANRB60000Setup.exe
superspotter
Thanks Alan, so I could just click on the link you sent and I assume that will overwrite 6.01? and all my setting up will remain?
regards clive.
It will over write OK but don't know about your settings
superspotter
Sorry, I meant all the things I have done with Zadig, that should remain?
#21
Yes drivers are left untouched. But you should download an install http://www.airnavsystems.com/download/ANRB/ANRBUpgradeto600.exe Will save you much time.
Will not cause any problems with the Zadig drivers
superspotter
Thanks Ingo but that link you sent me is version 5.074 or something similar, regards clive.
superspotter
Thanks once again guys, all back to v.6.00 and working fine.
kind regards clive.
Well I used it to downgrade from V6.01.000 to V6.00.000. I didn't read what it stated during install. After install ANRB showed V6.00.000 during start up.
#26
Hi Clive,
good to hear, that you got it to work and you are right,
the upgrade to V6.00.000.exe does indeed state V5.00.072 but it does install V6.00.000 anyway. One of Airnavs small mysteries...
2E0BTX
dont think i ever seen so many replys not related to my original post ever ...
#28
Other than starting the post Peter we have had no further contact from you until your last comment, have you resolved the issue or is it still giving problems?
Clive was having a problem with the latest version as well so it is relevant to the topic.
