Hi all,
I am aware that there are always some planes that the system doesn't have the registration for. With the previous version when clicking on the mode S most registrations were then added. However using this new 3.0 version I seem to have many more planes without registrations showing. Just had 823 network flights with 90 without registrations. Clicking on the mode S seems to no longer be retrieving the registrations. Am I the only one struggling or is this as others are finding it? Look forward to any help or comments.
Chris,
I would leave the auto populate function for the moment as it probably requires the server to be working properly in order to carry out the various checks. Having said that, not being computer savvy, I'm not sure.
Cheers,
Quote from: chris kelham on July 31, 2009, 12:47:05 PM
Hi all,
You can click anywhere in the data line for the aircraft, not just on the Mode S code - I tend to click on the Flight ID if there is one :-)
Autopoulate is certainly working for me this morning, so maybe your problem was to do with the server maintenance.
Quote from: Allocator on August 01, 2009, 08:18:02 AM
Hi all,
Allocator,
As with you everything seems to be ok this morning so far with the network up and running and auto populate working.
