I have installed v3.07 and all OK but no photos!
Can you tell me please what I am doing wrong.
I have the relevant boxes ticked.
Terry
There is an issue with the server at the moment. We are working on it.
I am having the same problem, is this server issues still?
Also when you try to populate in the My Log window nothing is happening.
I thought everything was okay but after your post I checked and I only get a small % photo showing up
I got easyjet air lingus no problem so their an outstanding issue but airnav did say their was an issue with the server
puddy
I have just checked as it is the first time that i have used Radarbox on my new computer and have only 128 pics out of 281 aircraft recorded.
Weather airport not available. Problem server?
Just started 3.07 and have 74 ADS-B a/c in My Flights and only one is displaying a photo. Status says All Photo Requests Done and Preferences is set to Download Aircraft Photo.
Maybe I've got a setting wrong or the photo requests aren't being serviced?
Mike,
Same here, also Metar not working but we where told not back to 100%. Just glad the main network aircraft are showing
We are fiddling the will the last few things, don't worry we are aware hence we didn't say everything is fully up.
It would be sensible for the software to indicate when it can't get the connection/information it wants.
Or if one had the option to turn off each of the network services - Shared data, photos, routes, registration and weather. Or are there more?
It would seem that the flight list population delay might well have been associated with some of the network services being down.
What happens if the ANRB customer goes mobile without an internet connection?
The internet based services wouldn't work.
Quote from: MikeC on November 10, 2009, 05:11:07 PMWhat happens if the ANRB customer goes mobile without an internet connection?
ANRB works fine when mobile - I regularly go mobile with my netbook, and ANRB works just fine. Obviously, its best to set a QNH manually, and be aware that any new aircraft won't have photos.
Quote from: AirNav Development on November 10, 2009, 06:00:51 PM
Obviously, but that wasn't the thrust of my post.
I don't know for sure, but things may be different if a connection attempt returns host unreachable (so not network available at all) rather than a connection being accepted by the remote server and then doing nothing.
I suppose the server could simply do a RSET on the socket to avoid this, if it's present but not actually serving requests.
The difference was our server was online, but the requests through the last few days it was waiting for a response for the data.
When your not connected to the internet it failis to connect straight away and doesn't try again.
Quote from: tarbat on November 10, 2009, 06:35:40 PM
What does the QNH mean and what setting should I have it set to?
Puddy
Take a look at this for starters:
http://en.wikipedia.org/wiki/QNH
I do this regularly Mike. Basically, it just means that you don't get any Network traffic or updates, but everything that has already downloaded/populated onto your PC will still be available.
So, you will get all the existing aircraft details in NavData.db3, all the routes, all the thumbnail pictures, all the outlines. Quite frankly, if you've been running your RB for a while and don't go too far from your home location, you're going to see all your 'normal' traffic and you won't notice too much of a difference.
Why don't you just switch off your modem and see for yourself.
