Main Menu
Why no photos?
Started by gzerovti, November 09, 2009, 05:24:40 PM
gzerovti
I have installed v3.07 and all OK but no photos!
Can you tell me please what I am doing wrong.
I have the relevant boxes ticked.
Terry
G0VTI - On the flight path to EGNM
There is an issue with the server at the moment. We are working on it.
dunc8543
I am having the same problem, is this server issues still?
dunc8543
Also when you try to populate in the My Log window nothing is happening.
puddy
I thought everything was okay but after your post I checked and I only get a small % photo showing up
I got easyjet air lingus no problem so their an outstanding issue but airnav did say their was an issue with the server
puddy
Radar Box & AOR8200 mk3 scanner
South Lincolnshire near Boston (UK)
dunc8543
I have just checked as it is the first time that i have used Radarbox on my new computer and have only 128 pics out of 281 aircraft recorded.
jorgev
Weather airport not available. Problem server?
MikeC
Just started 3.07 and have 74 ADS-B a/c in My Flights and only one is displaying a photo.  Status says All Photo Requests Done and Preferences is set to Download Aircraft Photo.
Maybe I've got a setting wrong or the photo requests aren't being serviced?
Roadrunner
Mike,
Same here, also Metar not working but we where told not back to 100%. Just glad the main network aircraft are showing
We are fiddling the will the last few things, don't worry we are aware hence we didn't say everything is fully up.
Fenris
It would be sensible for the software to indicate when it can't get the connection/information it wants.
MikeC
Or if one had the option to turn off each of the network services - Shared data, photos, routes, registration and weather.  Or are there more?
It would seem that the flight list population delay might well have been associated with some of the network services being down.
What happens if the ANRB customer goes mobile without an internet connection?
The internet based services wouldn't work.
Quote from: MikeC on November 10, 2009, 05:11:07 PMWhat happens if the ANRB customer goes mobile without an internet connection?
ANRB works fine when mobile - I regularly go mobile with my netbook, and ANRB works just fine.  Obviously, its best to set a QNH manually, and be aware that any new aircraft won't have photos.
MikeC
Quote from: AirNav Development on November 10, 2009, 06:00:51 PM
Obviously, but that wasn't the thrust of my post.
