AirNav Radar => AirNav Radar Discussion => Topic started by: AirNav Development on December 09, 2009, 11:25:53 PM
Title: RELEASED - AirNav RadarBox 2010 - 3.13 - Comments
Post by: AirNav Development on December 09, 2009, 11:25:53 PM
All comments regarding the release of AirNav RadarBox 2010 Non-Beta should be placed on this thread. Again a special thank you to all the beta testing team.
Title: Re: RELEASED - AirNav RadarBox 2010 - 3.13 - Comments
Post by: Aerotower on December 10, 2009, 12:04:54 AM
Hi, this problem has been resolved in this final version, see date? (see attachment)
Post by: Fenris on December 10, 2009, 12:16:50 AM
I would not expect it to be if you saw it while running 3.13 beta, the lack of change of version number should indicate that the code did not change.
Good to see it released Airnav, I think everyone will find it a significant improvement over 2.01 if they are still running that.
I'm sure that bug fixes will appear in future, but you have to put a stake in the ground somewhere.
Title: version 3.13
Post by: 73TORANA! on December 10, 2009, 01:55:24 AM
So far so good but it still doesnt remember color changes.
Title: Re: version 3.13
Post by: Aerotower on December 10, 2009, 01:57:43 AM
http://www.airnavsystems.com/forum/index.php?topic=3963.0
Post by: RodBearden on December 10, 2009, 02:05:53 AM
You're right, 73TORANA!, but if you export your colour scheme as Default.mcl AND as Real Radar.mcl, the problem goes away. One day they'll fix it ... possibly ;-)
Post by: 73TORANA! on December 10, 2009, 02:32:14 AM
Hey thanks  Rod I'll give It a try.
Post by: Levery on December 10, 2009, 04:51:47 AM
Hi everyone,
I did a full install of ANRB 2010 -3.13 on my LP - os Vista, had a few hickups along the way too, but everything is working fine now. Just one problem, i tried to copy/past and cut/past my old database but it just does not overright the new one, i noticed that this new database has a few new entries added to it, so am wondering if this is what is causing my grief, really don't want to type all that info again, is there any other way that i can import my old info into this new database?
Larry
Curacao N.A.
Post by: daelight on December 10, 2009, 10:20:07 AM
Can I be the first to convey very positive results from using this version. Even from 3.08 the most striking change has been the opening up of an area to the west of me and for which I never could work out why I was getting such poor reception. In some cases I am seeing small increase in coverage, its most welcome.
I would seem from the changelog that there was some kind of 'blindspot'  but can report in this case at least it is resolved.
Thank you
Post by: leading light on December 10, 2009, 10:56:18 AM
I have endeavoured to install using the upgrade from V3.xx and I get the message 'the application failed to start because rb.dll was not found'.
I am currently running 3.06 beta
Do I therefore have to do a full install and will it overwrite my data eg photos and log?
Thanks LL
Post by: AirNav Support on December 10, 2009, 10:59:01 AM
If your doing the upgrade using the exe file. You need to place the exe manually in your RadarBox 3.06 folder.
Post by: leading light on December 10, 2009, 11:05:39 AM
Air Nav thanks for the prompt reply.
Excuse my ignorance if I had read it properly the Manual bit should have given me the clue.
Thanks again
Embarrassed LL
Post by: westie v8 on December 10, 2009, 11:30:00 AM
i updated from 2.10 to 3.13 this morning and i lost my network live ( which i have 6 months left)now says i have a 5 min delay and my polar diagram is now half size...any ideas
Post by: Tailwinds on December 10, 2009, 11:30:58 AM
I'm still using the Airnav 2009 version 2.0. Do I just download the version 2 upgrade which brings it up to date? No need for me to download the full install of 3.13? Just checking, thanks.
Post by: johnacoles on December 10, 2009, 11:44:11 AM
Westie v8, I have the same problem (my system says i have a 5 min delay as well) - very annoying as i pay monthly!
John Coles
Post by: westie v8 on December 10, 2009, 12:01:23 PM
i've also put it on my laptop and the same thing has happened, my main pc has windows 7 and the laptop has vista 32 bit...here's abit more..the scanner and rb antenna are fitted on the roof of my house, now both systems run on a line of sight but the scanner has a miles longer range, between 50 and a 100 miles even before the upgrade ?
Post by: AirNav Support on December 10, 2009, 12:11:44 PM
westie v8,
Not sure what you mean, Version 2 could not show Live network. The network was delayed in Version 2.
Version 3 now allows Live network, and hence will tell you whether you have Live or Delayed network access.
Post by: westie v8 on December 10, 2009, 12:19:21 PM
i had the 2009 2.10 then updated to 3.13
Post by: AirNav Support on December 10, 2009, 12:20:05 PM
Any version 2.xx couldn't display Live network. It had the delayed network.
Post by: westie v8 on December 10, 2009, 12:26:46 PM
so updating to 3.13 what i've i got now ? have i got the 3.13 but it tells me the network has a 5 min delay
Post by: AirNav Support on December 10, 2009, 12:32:43 PM
There are two network subscriptions: Live & Delayed.
Live only works in Version 3.xx and was recently added a month back. Live subscription costs more than delayed. Customers get free one years delayed access when purchasing a RadarBox.
Version 3.xx will therefore notify you whether you're on the delayed network or live network.
Post by: johnacoles on December 10, 2009, 12:34:35 PM
I've accidently installed the full version instead of upgrading from my 2009 version, any ideas what to do?
John Coles
Post by: westie v8 on December 10, 2009, 12:36:03 PM
thanks, that clears it up..... now back to my polar diagram, how come it's only half size
Post by: Tailwinds on December 10, 2009, 12:39:00 PM
This is why I asked the question further up but it's now getting buried! I'm still using ANRB 2009 Version 2.0. Should I install the upgrade from version 2.xx or the full 313 install?
Post by: AirNav Support on December 10, 2009, 12:43:38 PM
Upgrading:
If you want to use your current database then install the upgrade. If you want to start clean you can do the ful install. We would advise in each case to backup your databases before upgrading.
westie v8,
Give it some time, polar diagrams can only be compared after a days of usage, different weather conditions will affect your diagram as different approach patterns for runways will be used as well as affects on the signals.
Version 3 should actually improve coverage for some users, it won't decrease coverage.
Post by: johnacoles on December 10, 2009, 12:52:05 PM
Have now subscribed to the Live version and everything is fine...
Thanks to all for your help
John Coles
Post by: Tailwinds on December 10, 2009, 02:10:03 PM
I was just about to install the upgrade from ANRB 2009 Version 2.0. This is what the installer says.......
"Setup is now ready to begin installing Airnav Radarbox 2010 - upgrade from 2xx to 3xx beta on your computer."
I thought this was no longer a beta. I thought this upgrade was going to bring my software up to date to version 2010 version 313.
Post by: AirNav Support on December 10, 2009, 02:13:17 PM
If you downloaded it from this thread then don't worry, its probally a mistake in the installer text. Once installed it shouldn't say beta.
Post by: HKG on December 10, 2009, 02:34:55 PM
Greetings from Hong Kong!
Have just installed the full v3.13 onto a new PC. Everything went fine. Started up the programme and ran into problems.
When asked to input details of home station, I put in exactly the same details from my old PC. Lat/long, name, city, e-mail and hit OK but no response at all... have tried restarting the programme and the PC.
Without my home location, it won't show the map or allow me to do anything else. I am picking up flights from the network and my box.
Is there a file which I can copy across from my old PC which will allow it to recognise my location?
Many thanks for any help
Dennis (HKG)
Post by: AirNav Support on December 10, 2009, 02:45:04 PM
HKG,
On what Operating System is this occuring on?
Sounds like a permissions issue is blocking RadarBox saving to the registry. Are you admin on your machine?
Post by: HKG on December 10, 2009, 02:48:53 PM
I am running the latest version of Vista... I am the only one on this PC so shouldn't be an admin problem. In fact during the installation it did ask for admin permission and it got through without problems
Post by: AirNav Support on December 10, 2009, 02:50:52 PM
Trying installing in a different location as mentioned here:
http://www.airnavsystems.com/forum/index.php?topic=1570.0
Post by: HKG on December 10, 2009, 02:54:57 PM
Have already done that... it's currently in
C:\\Program Files\AirNav Systems\AirNav RadarBox
I even have anti-virus/firewall etc. turned off...
Post by: Southwest on December 10, 2009, 03:21:32 PM
As someone who is not PC savvy I would like to ask a quick question.
I have just bought the AirNav Radar box about three weeks ago and (if memory serves me right, I'm at work) my version is 2.01?  My question is can I just click on the upgrade link and let the magic of technology do it's thing?
Post by: Southwest on December 10, 2009, 03:43:26 PM
I forgot to say in my previous post, my PC's OS is XP 32 bit
Post by: bearcat on December 10, 2009, 04:00:06 PM
If I were you Iwould download the full version at
http://www.airnavsystems.com/download/anrb/313/ANRB313Setup.exe
It should have the latest logo and flag files.
Post by: Southwest on December 10, 2009, 04:06:58 PM
Do I have to delete anything first or do I just click on this link and go from there?
Post by: bearcat on December 10, 2009, 04:12:06 PM
All I have done in the past is download and installthe new version. It will install into a different directory.
You can then copy your old Mylog and NavData files from V2 into V3.13
When I'm happy after a few days I have then unistalled the old version in the normal way
Post by: EK01 on December 10, 2009, 04:25:24 PM
Quote from: HKG on December 10, 2009, 02:54:57 PM
HKG,
Instal into C:\AirNav Systems\AirNav RadarBox. Omit 'Program Files' because if you are running a 'Vista' machine the program goes into the virtual folder and all hell breaks loose.
Also better to install the full 3.13 program and then copy over any files from your old version such as logos,maps,etc.
Post by: oubliettehoggle on December 10, 2009, 04:26:53 PM
I've just subscribed for real time network but still get the message about the 5 minute delay. Have I forgot something, do I need to do something to get it to work.
Post by: Airwaves32 on December 10, 2009, 05:20:18 PM
Hi all !!! i recieved an email from Airnav saying that i could download the 2010 for free, So i did that and when i opened it up to were you have to put in your password and user but dosent reconise it and it works on the 2009 one just fine.
do i have get a new  password ? or what
anyone any ideas ? bought it a few months back and havent much time to use it the last month or so. Can anyone help me please..
Airwaves32
Post by: Allocator on December 10, 2009, 05:58:41 PM
Same password and user name that you were using before.  When I got my RB, it was on the cardboard CD cover.
Post by: AirNav Support on December 10, 2009, 05:59:55 PM
Airwaves32,
You need to use the same registration codes for RadarBox 2010. They are the ones which came on a label on the RadarBox CD.
oubliettehoggle,
Contact us via the methods in our signature with your order details and we will check.
Post by: phil zech on December 10, 2009, 06:21:45 PM
Evening All,
Just want to say that I have just dowloaded Version 3.13, previously only had Version 2.1.(pain free I might add!!)
Everything seems to be working well, nice to see Flybe,Loganair, Eastern Airways showing on My Flights (logos, flight numbers)
A big thank you to all the beta testers who have spent many a long hour, no doubt, testing the beta versions (you know who you are) and also to Air Nav for producing an excellent product.
Cheers guys and keep up the good work.
Phil
Post by: CarlosAbreu on December 10, 2009, 08:09:24 PM
Hi to all
I'm testing this new version and until now I'm satisfied with it, however I have a very important doubt: the new database obviously doesn't have the data manually inserted in version 2009, my question is simple: can I copy the the file that has the 2009 database to the new version ? There's hundreds of new aicraft and flight numbers there !!! how to deal with it ? I'm going to loose all work made ?
Brgds
CA
Post by: RodBearden on December 10, 2009, 08:38:19 PM
Carlos - assuming you have still got them, just copy your old Navdada.db3 file from your old Radarbox folder to the new one. If you want to keep your old log too, also copy the old MyLog.db3 file to the new folder, overwriting the "new" one.
Post by: Allocator on December 10, 2009, 08:38:55 PM
Yes easy!
The NavData.db3 file is the master (source) database.
MyLog.db3 is the record of all the aircraft you have detected with your antenna.
Post by: Southwest on December 10, 2009, 08:45:31 PM
Just installed the update from 2.XX to 3.13 and it works perfectly.  Many thanks for all your responses to my question.  The only downside was having to wait about 30 minutes for it to download but hey, them's the breaks!!
Post by: besty on December 10, 2009, 08:49:56 PM
I've just upgraded from 3.13 beta to 3.13 and now all I get is the software asking for home station data, on entering the data nothing happens. I first copied the exe file into the folder but got the home data problem so I thought I'd try the full install same trouble.
If I click on the free forum registration button it opens up IE but won't accept the data on pressing OK.
The box is working I can see a number of aircraft on my flights but it is showing network tab and won't allow any change until data is accepted.
Anyone any ideas?
Stuart
Post by: Pinza on December 10, 2009, 09:35:18 PM
Hmm - just decided to go for a full install of version 3.13 (despite having slowly upgraded from 2.? to 3.13beta).
Painless exercise, having made copy of MyLog.db3 and NavData.db3 (having taken a gamble that my version of the latter was more up-to-date than newly installed version).
Backed up and copied across my own updated sillhoette and outline files too.
Only annoying issue was wasting an hour turning my flat upside down in the search for my initial CD as I assumed new installation would ask me for Username and Password.
Eventually found the required CD (and necessary codes). Installed new full version and found the new software installed perfectly WITHOUT need for my password that I'd searched so hard for - AARGH!
Guess my details are saved in some registry setting?
Seem to have copied across all my needed data from previous versions and new version running rock steady.
Many thanks Air Nav for this latest version - great!
Chris
Post by: CarlosAbreu on December 10, 2009, 10:00:21 PM
Hi Rod
Thanks for your coment, my idea was basicaly the one you sugested, however I was not sure if it was possible to do it. A second opinion is a good advise and always very important.
I have backup of all data.
Brgds
CA
Post by: CarlosAbreu on December 10, 2009, 10:14:09 PM
Hi to all
Could you please provide information how to get the add-on 3D software ?
Brgds
CA
Post by: RodBearden on December 10, 2009, 10:15:50 PM
Carlos - you  can't! It's still in closed Beta testing.
Post by: CarlosAbreu on December 10, 2009, 11:48:16 PM
Thanks for information.
New Airnav version stills working perfect after database files copy !!!
Brgds
CA
Post by: Airwaves32 on December 10, 2009, 11:49:09 PM
Thanks lads, got it back up and running. i did put the same user and password in but didnt work so i ran 2009 and had it running for 10mins,turned it off and loged into 2010 and worked.yeepee :)
Post by: HKG on December 11, 2009, 01:04:58 PM
Quote from: EK01 on December 10, 2009, 04:25:24 PM
HKG,
Thanks Ian. Have re-installed into C:\AirNav Systems\AirNav RadarBox as you suggested
But same problem with the programme not responding to input of home station data. Looks like I am not the only one having this problem either...
I used the "remove programme" function in Vista to uninstall. Are there any other files which need removing before a clean re-install can be done? The re-install (full version) I did took a lot less time than the original (full) install. So perhaps Vista is re-using something from the first install which still causes the problem?
Many thanks for any help.
Dennis (HKG)
Title: Network flights missing in 3.13?
Post by: John Hargreaves on December 11, 2009, 01:14:09 PM
At the moment I am running two ANRBs side by side but on two computers. One is updated to V3.13 and on a roof mounted aerial, the other is still on version 2 and on the aerial provided with the kit. Until now the numbers of flights 'My Flights + Network Flights' was roughly the same on both screens. The roof aerial mounted box was up to 50 flights higher due to the increased reception range pulling in a lot more non ADS-B flights.
Now, however, the figures no longer add up.
Roof aerial on V3.13   97/896 My Flights/Network
Small aerial on Version 2  23/1271 My Flights/Network
Some 200+ network flights appear to be missing! At least two problem areas are Brazil and Egypt - more flights showing on version 2 than v3.13. Can anybody explain this?
Post by: EK01 on December 11, 2009, 01:35:48 PM
Quote from: HKG on December 11, 2009, 01:04:58 PM
HKG,
Dennis (HKG)
Dennis,
I am not particularly computer savvy but I would have thought that doing an unistall would not have been necessary because if you install the version 3.13 into just C:\AirNav Systems\AirNav Radarbox it installs into a separate location anyway. It did take around 30 minutes or so to do the full install. As for the problem of not responding to home station data, not quite sure what you mean. Do you mean you are not receiving any 'My Flights' info in the grid or are you referring to your home location on the map. If it is the latter, I seem to remember reading a post somewhere that your home coordinates had to be entered in a special way.
Sorry, I can't be of further assistance. Over to the more computer literate amongst us !
Post by: HKG on December 11, 2009, 01:54:37 PM
Thanks again Ian. I entered the home location co-ordinates just like they appear on my laptop which is running version 2.xx. After entering name, town, country, e-mail etc. I click OK and no repsonse at all.
I am seeing flights from my own box and the network... but without the programme accepting my home location I cannot do anything else...
Stuart (reply #48) is having exactly the same issue.
Post by: tarbat on December 11, 2009, 02:08:48 PM
The problem with RB locking up when trying to setup your home location, etc. is most likely caused by registry keys pointing to old folder locations:
HKEY_LOCAL_MACHINE\SOFTWARE\AirNav Systems\ANRB\1\General\edit1text
HKEY_LOCAL_MACHINE\SOFTWARE\AirNav Systems\ANRB\1\General\MapColorpath
HKEY_LOCAL_MACHINE\SOFTWARE\AirNav Systems\ANRB\1\History\map1-9
HKEY_LOCAL_MACHINE\SOFTWARE\AirNav Systems\ANRB\1\RadarBox\edit1text
Post by: HKG on December 11, 2009, 02:20:22 PM
Quote from: tarbat on December 11, 2009, 02:08:48 PM
Thanks. Where do I find these keys and what should I do with them to correct the problem?
Post by: tarbat on December 11, 2009, 02:33:08 PM
Quote from: HKG on December 11, 2009, 02:20:22 PM
If you're confident in your abilities using Windows Registry Editor.
Windows - Start - Run - regedit
Then navigate to the relevant key, and see if any are pointing to an old folder location.
Post by: Fenris on December 11, 2009, 03:54:04 PM
Anyone else updated the drivers to those supplied in the v3.13 installer and now finds that they have the Safely Remove Hardware icon in the system tray which gives a Remove Airnav RadarBox safely option?
I wasn't expecting that.
Vista Home Premium 32bit SP2 if it makes a difference.
Right, a bit of Googling seems to show that this is a feature of the 2.6.0.0 FTDI driver version.
Post by: viking9 on December 11, 2009, 04:29:57 PM
Airnav, I have a problem.
I left V3.13 running. On returning to it after about 3 hours I find that no aircraft are shown in the table in My Flights, but they are shown on the map. (1st pic)
If I hover the mouse cursor over an aircraft on the map its photo and details actually appear.
When I click on 'Tools'/'Interface' and move the interface to the other side I get the one aircraft repeated in MyFights. This time, when I hover the mouse over an aircraft on the screen its details beside the photo appear but not the photo. (2nd pic).
I have no sorting selected.
Post by: Dermot on December 11, 2009, 06:39:08 PM
I'm having a problem registering for Live Network. I subscribed last night for the 7 day trial and got a notice about an error with communications between Plimus and Paypal. I cancelled the subscription just now and re-subscribed again just now and got the same error!!
Am I doing something wrong?
Airnav I think you better look into this, I'm sure it will start costing you money if people can't subscribe for your services...
Post by: Silver Doctor on December 11, 2009, 08:20:12 PM
Just upgraded from 3.13 Beta to released 3.13...no problems. thanks for the updat....
Post by: besty on December 11, 2009, 08:53:03 PM
Thanks Tarbat for the registry advice worked a treat now up and running again.
Stuart
Post by: tarbat on December 11, 2009, 09:34:21 PM
Quote from: Stuart on December 11, 2009, 08:53:03 PMThanks Tarbat for the registry advice worked a treat now up and running again.
Glad it worked.  I did suggest to Airnav that they change their installer to remove old folder references as part of the installation process, but eveidently they can't because these folder references are created when the program runs, rather than during installation.
Post by: GlynH on December 12, 2009, 12:08:27 AM
Interesting to read posts from HKG & Stuart as I have just installed 3.13 on my MediaPC, Laptop & Netbook and on both of the portable devices where ANRB hasn't been installed before they only let me get as far as the Home Station Data page in Preferences and no further - I can't even close the damn window down!
I run ANRB and enter my details when prompted, hit OK and the window just sits there and doesn't go away.
ANRB is still working in the background but of course I am unable to do anything with it because of the Preferences windows refusal to close.
As I mentioned the MediaPC had a previous installation of ANRB 3.01 Beta that I uninstalled prior to installing 3.13 final and this doesn't exhibit the problem but both the laptop & netbook have not had ANRB installed before and share this common 'fault'.
I have had a look at the registry keys on both the Laptop and Netbook I see;
HKEY_LOCAL_MACHINE\SOFTWARE\AirNav Systems\ANRB\1\General\MapColorpath which is pointing to the correct directory
I don't see \edit1text but I do have an entry for HKEY_LOCAL_MACHINE\SOFTWARE\AirNav Systems\ANRB\1\Registration
Neither do I see \History\map1-9 or \RadarBox\edit1text possibly because the program hasn't initialised properly and I have to close it with TaskManager or there may be an issue with the installer that doesn't write the correct registry keys when installing on a clean machine where no previous ANRB has been installed?
I do have a \Registration key entry on both portable computers though...and there are dozens & dozens of extra keys on the MediaPC which did have a previous install including the edit1text entry Tarbat referred to although that is pointing to a previous Beta folder which doesn't exist any more.
The MediaPC does allow me to use the program though...
If I was a betting man I might put money on both HKG & Stuart installing to a PC that hasn't had a previous ANRB iinstallation maybe?
Seems to be the common factor on both of the portable machines I am having problems with.
Any ideas Dev?
Thanks & regards,
-=Glyn=-
Post by: HKG on December 12, 2009, 01:06:07 AM
Glyn,
Yes. I have been trying to install ANRB onto a new Vista PC with no previous installation.
And having had a look in the registry, I have exactly the same lines as you have listed.
Will try installing onto another PC tonight (also without previous installation) to see if that really is the issue. I think Stuart was trying to do an upgrade and seems to be working fine now.
Dennis (HKG)
Post by: besty on December 12, 2009, 09:42:04 AM
Well I thought my problem was fixed but looks like it has reappeared since I closed laptop down last night, on starting up this morning it only gets to location data and then runs in the background as GlynH says. Only way to close down is CTRL ALT DEL and shut down with task manager. The laptop has had previous versions of the beta's on.
I deleted the registry to see if it would replace it with a new one and the one that is there now looks a lot larger and more complete, it has the history section.  One thing that does stand out is the ANRBpath has no data in it.
Post by: cray725 on December 12, 2009, 04:09:57 PM
@ GlyH
I had the same problem. Just select autodetect location and it will fill in lat long, ignore whats there and click ok.
Restart Airnav software and edit home location to your lat and long.
Post by: besty on December 12, 2009, 04:38:40 PM
Tried autodetect and it gives me 'unable to return valid location data from the internet' message and goes back to manual data input. Have formatted Hdd and restored back to factory settings. Back to where I was before the formatting, looked at regedit and nothing in the ANRBpath still. box running in the background so not a box fault.
Post by: HKG on December 12, 2009, 04:49:01 PM
Have just tried the full installation on another PC with no previous ANRB installation. Exactly the same problem as with my other PC and as Stuart mentioned above. Cannot get valid location from the internet but manual entry followed by OK gives no response...
Post by: Allocator on December 12, 2009, 04:50:45 PM
Quote from: HKG on December 12, 2009, 04:49:01 PM
You are using decimal degrees with a negative figure for South or West?
Post by: besty on December 12, 2009, 04:54:20 PM
Just using negative for west and south, same as original setup for version 2
Post by: Allocator on December 12, 2009, 04:56:31 PM
And decimal degrees like:
51.1234 -2.4567
Post by: besty on December 12, 2009, 04:58:05 PM
54.7630 and -1.3286
Post by: Allocator on December 12, 2009, 05:00:22 PM
Hmmm..... no idea why RB isn't accepting your position.  Maybe a Vista 'thing'?
Post by: besty on December 12, 2009, 05:04:52 PM
Got it to work once last night, restarted today and back to same problem must be something to do with the registry but no idea not really up on them. Very annoying though. Thanks for trying though.
Stuart
Post by: Allocator on December 12, 2009, 05:18:22 PM
OK, I run XP Home on my PC's and I haven't see this problem, so that's me fresh out of ideas.  I've certainly never had to muck about with the registry settings.
Whenever I do a fresh install, I always rename the OLD folder and accept the RB default for the new install.  I can then copy any files over that I want from the old renamed directory - but ONLY after I've made sure the new install runs OK first.
Post by: John Hargreaves on December 12, 2009, 05:49:00 PM
Am I the only one with missing network flights? No comments have been forthcoming. At the moment version 2 showing 1128 and v3.13 only 755! The missing flights are from all over the world and altitude is not a factor. Last night for instance around Kuala Lumpur version 2 showing 9 and v3.13 only 2. This morning SAS9146 on delivery over Norway with G-EZTN on his port side. Both on version 2, neither appearing on v3.13. An Emirates and a Eurocypria side by side on version 2, only the Emirates on v3.13.
Has anybody else noticed a reduction in network flights being received or am I on my own with this one. Any comments please AirNav?
Post by: besty on December 12, 2009, 06:12:11 PM
I think I've cracked the location data problem for me, I started the program in demo mode then entered the location details, closed down the program then restarted it in normal mode and all seems ok for now.
Post by: GlynH on December 12, 2009, 07:27:43 PM
Quote from: cray725 on December 12, 2009, 04:09:57 PM
@ GlyH
If only it were that easy.
Clicking Autodetect is unable to autodetect...:-(
Thanks & regards,
-=Glyn=-
Post by: GlynH on December 12, 2009, 07:29:41 PM
Quote from: Allocator on December 12, 2009, 05:00:22 PM
Hi Gary,
Using XP here...
3.13 only seems to install correctly if ANRB has been installed before?
Waiting for something from AirNav...
Kind regards,
-=Glyn=-
Post by: AirNav Support on December 12, 2009, 07:37:22 PM
GlynH,
Not quite true, we have had almost 500+ installs of 2010 so far and we have had no one emailing support with the the issue mentioned. It does seem as if there is spyware, antirvirus software running which may be blocking the creation of these certain reg keys. We are investigating.
John Hargreaves,
Firstly regarding your earlier post, network flights are only shown if your not receiving them locally. Therefore you cannot compare two machines running different versions if they are on different antennas. The software will download the same amount of flights but depending on your what your picking up, network flights will be cut down.
Post by: besty on December 12, 2009, 08:07:46 PM
Glyn try starting in demo mode then go to location data on the preferences. I input my data in there and it was accepted. Once you've done that close the program down and restart, mine worked fine after that. Even closed laptop down and it started first time again.
Hope that gets you up and running
Stuart
Post by: John Hargreaves on December 12, 2009, 08:19:09 PM
Airnav,
Thanks for the reply but maybe I am 'being a bit thick here'. Both machines are now on the supplied aerial and the figures are - version 2 6/1039 (My Flights/Network) and v3.13 6/772. Some 250 flights appear to be unaccounted for. I am in the UK so missing flights off v3.13 flying over Malaysia, North Africa, and Syria for example are not going to appear in my flights. There are two Qatar A320s active at the moment 06A087 and 06A088 - they both appear in version 2 but only one has ever appeared in v3.13 .
John Hargreaves
Post by: AirNav Support on December 12, 2009, 08:21:20 PM
Are you on using one machine with the Real Time network and the other with Delayed? Are the timeout settings the same?
Post by: John Hargreaves on December 12, 2009, 08:37:06 PM
AirNav,
All settings are identical. I only subscribe to the 5 minute delayed network.
Post by: GlynH on December 12, 2009, 09:47:33 PM
Quote from: AirNav Support on December 12, 2009, 07:37:22 PM
GlynH,
Sorry...what's not quite true?
You might not have had any support emails yet but you have 3 users in this thread reporting the same problem.
In any case I would think that most users would have had a previous installation of ANRB and so not be affected by this issue.
As I said previously on the two machines where I had ANRB installed I don't see this behaviour as it picks up the location data from that same previous install.
On the two machines where I have never installed ANRB I do see the issue.
And I always disable my AV before I install anything...
-=Glyn=-
Post by: AirNav Support on December 12, 2009, 10:09:36 PM
Yes we know its been mentioned by 3 people on the forum but nothing else where. We have have installed on machines without a prior install and it has installed fine, thats why its not quite true.
We are still investigating it.
Post by: GlynH on December 12, 2009, 10:37:09 PM
Quote from: AirNav Support on December 12, 2009, 10:09:36 PM
Well its true for me and two others! ;^)
Good luck.
-=Glyn=-
Post by: cray725 on December 13, 2009, 01:21:15 AM
I did a fresh full install on a Windows 7 Laptop into a C:\Airnav directory
Installs ok but the inputting of home location info prevents any further progress.
I manually enter my lat long and other home data and clicking ok, nothing happens the input box stays open and wont close.
I was connected to the internet at the time, if I then pushed autodetect location button it put in where it thought I was located and then the input box would close and Airnav started with my home location in the Wirral. (I'm in East Anglia)
I then edited my home location with correct data from preferences and all ok and has ben running for 12 hours.
Post by: RodBearden on December 13, 2009, 01:26:25 AM
Thanks for the input, Cray725 - at least it proves that the Autodetect Location button has some use - it puts me in London, 200 miles from where I am. Apparently that's pretty accurate by some people's experience!
Post by: cray725 on December 13, 2009, 01:30:24 AM
GlynH were you connected to the internet at the time you were installing Airnav 3.13. I think you have to be connected to the internet for autodetect location to work.
Post by: cray725 on December 13, 2009, 01:46:08 AM
I guess a poll is required to ask those that did a complete fresh install of Airnav Release 3.13 who had problems with entering manually their home location detail and progressing any further! Detailing operating system etc
Most people here I guess would be doing upgrade process from 2.10 or just replacing the ANRB.exe on a 3.XX beta.
Post by: neroon79 on December 13, 2009, 06:30:21 AM
As previously mentioned before the fact that there was no version change between the 3.13beta release and the final 3.13 drives me to the same conclusion, that there was no code change between this to releases.
That's why I decided to report the occurred problem here.
After seven and a half day of flawless non-stop running version 3.13beta of the RB software crashed on my Samsung NC10 Netbook running Windows XP(Home) SP3. Unfortunately all the usual XP crash reporting mechanisms also failed.
I did a full Install with copying back my Databases. I will check back again if the problem reoccurs.
Post by: HKG on December 13, 2009, 08:03:21 AM
I have finally got v3.13 to work on my Vista PC... Here is what I did:
Installed v2.xx first. Full installation and my home location was accepted. Everything worked fine
Then installed the full version v3.13 and started that up. No need to enter the home location and it's up and running. Have copied across the navdata and mylog files, shut down and restarted ANRB a few times and all works fine! But I have noticed fewer network flights compared to v2.xx on my old PC as others have mentioned. Am using the same (supplied) aerial and box at the same location.
But an earlier installation attempt with 2.xx first and then the upgrade exe did NOT work.
Hope this helps anyone with the issue of not accepting the home location
Dennis (HKG)
Post by: John Hargreaves on December 13, 2009, 08:55:59 AM
Quote from: HKG on December 13, 2009, 08:03:21 AM
Dennis (HKG)
At last someone is saying the same as me about there being fewer network flights!
John Hargreaves
Post by: Runway 31 on December 13, 2009, 10:20:12 AM
I am using XP and had version 2 installed.  I installed V3.13 in a seperate directory and on starting up all my settings including home location are already populated and ready to go.
I will say that when inputting my location in version 2 I couldnt get it to accept, maybe wasnt using decimal. to get it accepted and I had to go to my location on the map, right clicked and set it to home location that way.
Post by: Brisbane on December 13, 2009, 02:43:50 PM
I have V3.0 beta installed, what's new in the 3.13 version that is different.
Post by: Allocator on December 13, 2009, 03:00:54 PM
V3.13 is an official release, rather than being a Beta (test) version of the software.
Post by: YXUphoto on December 13, 2009, 03:12:26 PM
I have encountered an interesting issue.  I'm receiving a mode-S code of 503147 which is a wrong code for N202FR Frontier Airlines A320.  I have updated my DB manually, but I still keep getting this code without the info being filled in.  Any ideas why that is?
Post by: johnboy on December 13, 2009, 03:17:34 PM
I too are missing some network flights, yesterday the network count never went
above 800 over a 3hr. period, On first installing V3 i couldnt get any network flights at all, im also finding my live flight numbers going up then the total dropping down by approx 15%. Also noticed a lot with no reg. showing especially
Easy Jet.
Post by: Runway 31 on December 13, 2009, 03:22:33 PM
I am showing 1010 network flights at this time.
Post by: AirNav Support on December 13, 2009, 03:30:27 PM
Network flights are never the same across everyone system as they depend on what your seeing and your time out settings.
Nothing regarding the network settings has been changed since the earlier 3 betas. It seems its mainly customers who are moving from 2 to 3 that are seeing this.
There was improvement of the way transitions between Live and the network which may be causing some people from earlier versions to think there are less flights.
Post by: YXUphoto on December 13, 2009, 03:36:26 PM
Quote from: johnboy on December 13, 2009, 03:17:34 PM
Easy Jet.
If this was in response to my post, I have no problem receiving network flights (I used a filter to isolate just that single flight).
My problem is with RB not using the info inside the Database.
Post by: ANDREJ767 on December 13, 2009, 04:24:36 PM
Does the database has any influence at all on apperance of the airline logo on the screen and aircraft silhuette?If it does what should I change while for example for many LOT polish airlines Embraers 170 just airline logo don't appear???
Post by: RodBearden on December 13, 2009, 04:29:03 PM
Andrej - the database doesn't apply to logos - they are set by the Flight ID. The database does affect the silhouette - that is set by the short aircraft type in the database (for example B738, A346, E170).
If the LOT E170's don't show a proper Flight ID like LOT365, the logo won't appear, and if they haven't got the correct E170 code in the database, the silhouette won't appear.
Hope that helps.
Post by: ANDREJ767 on December 13, 2009, 04:36:58 PM
Thanks.The aircraft code E170 as well as its registration is correct displayed while flight number cell is empty .... thats is why.
Post by: EK01 on December 13, 2009, 08:21:13 PM
I am sure the previous versions used to show the local time at the bottom of the screen alongside the coordinates where you had placed your cursor  at any given country you went to on the map. For example if you had displayed a map of the USA and you were in the New York area it would show the local time as being 5 hours behind the UK time. The v3.13 does not seem to be doing this or is there something in Preferences that I have failed to tick.
Post by: RodBearden on December 13, 2009, 08:41:48 PM
It was decided to remove the local time as it was too complicated to get it right for everywhere on Earth - tricky things, time zones!
Post by: EK01 on December 13, 2009, 09:02:44 PM
Rod,
Thanks for the quick reply. Thought maybe I had just missed out on doing something.
Cheers,
ian
Post by: DaveReid on December 13, 2009, 11:56:25 PM
Quote from: RodBearden on December 13, 2009, 08:41:48 PM
That's a pretty defeatist attitude - the airline industry has been coping with time conversions between UTC and local for the last 90 years without any problems.
Post by: MIKE.UTD on December 14, 2009, 03:40:13 PM
Just tried the update from version 2xx to 3.13 and get the following error :
Application failed due to rb.dll not found.
Anyone any ideas ?
Mike.
Post by: dudbaker on December 14, 2009, 04:47:24 PM
Airlines use Zulu for Flight Planning and Tech Log enteries.
Post by: Allocator on December 14, 2009, 07:46:21 PM
Quote from: MIKE.UTD on December 14, 2009, 03:40:13 PM
Anyone any ideas ?
Mike.
Mike, did you copy the new anrb.exe file to your Radarbox directory to overwrite the old file?  This error message occurs when you try to run anrb.exe without all the other files that are needed.
Post by: jannuh on December 14, 2009, 08:00:56 PM
Quote from: dudbaker on December 14, 2009, 04:47:24 PM
z = Zulu = UTC = GMT (on earth at least)
Post by: MIKE.UTD on December 14, 2009, 09:58:11 PM
Hi Allocator,
Yes but after trying gave up and did a full install and all is working okay.
Thanks for your help.
Mike.
Post by: DaveReid on December 14, 2009, 11:03:27 PM
Quote from: dudbaker on December 14, 2009, 04:47:24 PMAirlines use Zulu for Flight Planning and Tech Log enteries.
Indeed they do.
Though not, fortunately, in their timetables and online booking sites  :-)
Post by: CarlosAbreu on December 15, 2009, 12:43:30 PM
Hi to all
After I instaled the new version, I copied the files from my old database (MyLog.db3 and NavData.db3) in order to keep all data, may routes and aircraft type were manually updated, it seems everything was fine but a few time later the data returned to it's original form !!! I don't know how to explain this, but probably an auto populate function made this.
There's a lot of incomplete data that I manually correct, but after the aircraft being detected again all corrections are cleaned...Does anyone knows how to stop this ?
Other question I have is the validation date for new rotes, aftre I introduce the new route may I insert date or keep it blank ???
Many thanks in advance and best regadrs
CA
Post by: EGNXR on December 15, 2009, 02:08:53 PM
Quote from: CarlosAbreu on December 15, 2009, 12:43:30 PM
Hi to all
CA
Hi Carlos,
Just one question. Did you copy the photo  pholder over as well?
If you did not then as you repopulate the photo's it over writes the data.
Just an idea.
Cheers John
Post by: EGNXR on December 15, 2009, 02:19:34 PM
Hi All,
Came home off nights to this one.
Had TF-CIB in MYFLIGHTS repeated 220 times. From the log it must have been on screen all night from about 8:30pm till 5:30am. For some reason could not capture a screenshot to show but the below was also showing on map EI-EFA etched onto the screen but not in myflights. Unchecked Process Hardware Flights and rechecked and problem cleared.
Apart from above glitch all seems good so far. Well don AIRNAV.
Cheers John
Post by: HKG on December 15, 2009, 02:46:24 PM
Hi all,
Have been running v3.13 for a few days and noticed an issue with TWO aircraft coming up on the my flights list with the same flight ID at the same time. Obviously one of them is incorrect. Only one of the two aircraft (the correct one) appears on the map.
Just had two Cathay aircraft come up as CPA905 - 7801CC (B-HNP B773) and 78014C (B-HUJ B744). The 773 is the correct one. The two had very similar altitudes but the"wrong" one had no v/s, speed etc... displayed.
It's very annoying as the flight ID gets recorded in the aircraft history for the "wrong" aircraft as well as the correct one.
Also had problems with 78018F and 7801AF coming up as a pair, and a pair of Air Macau aircraft as well...
Dennis (HKG)
Post by: CarlosAbreu on December 15, 2009, 02:51:55 PM
Hi EGNXR
In fact I didn't copy the photos folder, just the two other folders, I'm going to do it and see the results.
Brgds
CA
Post by: Allocator on December 15, 2009, 03:01:26 PM
Quote from: EGNXR on December 15, 2009, 02:19:34 PM
Hi All,
Cheers John
John,
I've replied to this in the other post with the same screenshot.
Post by: Allocator on December 15, 2009, 03:04:20 PM
Quote from: HKG on December 15, 2009, 02:46:24 PM
Hi all,
Dennis (HKG)
So, do you think that this is a RB issue, or is it the crew setting the wrong the Flight ID?
Post by: HKG on December 15, 2009, 03:13:32 PM
It's not the crew... looking at the two flights mentioned...
B-HUJ actually departed 15 minutes earlier on a different flight so I believe it's a problem with RB decoding the Mode S.
It's happened several times in the last couple of days with aircraft coming up as "a pair" on the same flight at the same time. Picked them up on "my flights" at the same time on take-off from HKG and both aircraft displayed very similar altitudes on the climb out but the "wrong" aircraft had no other info displayed, and was not tracking on the map. Both remained on the my flights list until out of range and disappeared at the same time
7801CC and 78014C came up together... as well as 78018F and 7801AF... very similar Mode S codes. So possibly a decoding issue with the box.
Post by: CarlosAbreu on December 15, 2009, 03:57:08 PM
Changes were made but database stills with a lot of missing data, specially routes that I manually introduced.
There must be a way to update data without interference of downloaded photo, why fields became always blank and data is loose ?
Brgds
CA
Post by: DaveReid on December 15, 2009, 04:36:24 PM
Quote from: HKG on December 15, 2009, 03:13:32 PM
This is a known problem when pairs of aircraft with almost identical 24-bit addresses are being picked up simultaneously.  7801CC/78014C and 78018F/7801AF are each only one bit apart.
There have been several previous posts about this problem.
Post by: Witchfinder on December 16, 2009, 04:06:42 PM
I have upgraded to the new version and for some reason my area of coverage has diminished severly. I have an outdoor aerial and my range went almost to Scotland on a spike and good coverage of most of france. Now id say its range is Bristol to the west, the coast of france to the south, east just about to London and North is probably just up to Gloucester. Im in Andover Hants. So could someone help on this matter please?
Paul
Post by: RodBearden on December 16, 2009, 04:15:11 PM
Hi Paul
I think we need a bit more information - have you upgraded from an earlier version 3 Beta? And are you using the real-time network?
There was a problem with RB versions around 3.06 (I think) where we were getting astonishing ranges in spikes that were caused by some sort of interference from live network flights. This has now been resolved. If that's the case, then your current polar diagram is likely to be realistic.
Hope that helps
Post by: Witchfinder on December 16, 2009, 04:30:32 PM
Hi Rod
Thanks for getting back to me so quickly. I did a full install of the new version from V.2.01 (the version that came with the radar box 09) and no I do not use the real time network. I am only interested in the myflights part of this bit of kit.
I also use to have about 100 planes in myflights but im getting a max now of about 50:-(
Post by: RodBearden on December 16, 2009, 04:49:47 PM
Sorry, then Paul. I can't help - your polar diagram will probably increase with time, but perhaps someone else has an idea...
Post by: AirNav Support on December 16, 2009, 04:50:56 PM
If you have just installed it, give it a few days. A few people contact us as soon as they install and mention the reception is less then a few days later they say its the same just traffic or reception that day were lower.
Post by: bratters on December 16, 2009, 04:51:59 PM
Quote from: Witchfinder on December 16, 2009, 04:30:32 PM
Hi Rod
Have a read of this thread - seems familiar ground.
http://www.airnavsystems.com/forum/index.php?topic=3769.15
Post by: chrisp on December 16, 2009, 05:42:35 PM
Hi I have downloaded the latest full upgrade and appear to be experiencing issues with aircraft altitudes . Aircraft on final approach to EGSS are showing altitudes of 37000 when their actual altitude is 3700 and when switching to the earlier version is correctly showing 3700 is anyone else suffering similar issues
Post by: darkskies74 on December 16, 2009, 06:34:41 PM
Anyone else had probs with the polar diagram returning to a smaller size once RB is exited and re-launched?
It seems to 'forget' new areas covered
Post by: bratters on December 16, 2009, 07:14:18 PM
Not heard that one before.
Post by: darkskies74 on December 16, 2009, 07:16:43 PM
Have just tried 'record desktop' prior to exiting.....seems to have worked, so far!
Post by: Paulc on December 17, 2009, 06:29:46 AM
Installed 3.13 last evening - downloaded the file to desktop, overwrote existing ANRB file with no problems.
Post by: Hawkeye on December 17, 2009, 01:10:10 PM
Ref Reply #138
I did a full 3.13 install last weekend and had the same problem after every shutdown/restart. Been ok now since Tuesday after I clicked 'Clear/Reset Polar Diagram'.
It seemed to be that the outline was the same as on shutdown but at a smaller scale/range.
Prior to 3.13 I was running 2009, and hadn't installed any of the 3 beta versions.
Syd
Post by: raflec on December 17, 2009, 03:06:39 PM
One very small problem I have noticed.
All aircraft flying over the North Sea are shown as flying over the Atlantic.
Something that I can live with, just slightly irritating.
Graham
Post by: phil zech on December 17, 2009, 04:33:46 PM
Afternoon All,
Installed V3.13 last week after using v2.1 since Oct 08.
Everything working great, thanks to all.
One little thing however, has anyone else noticed the font is different for the aircraft details in My Flights as against the font in everything else in My Flights listings and Network listings.
A little thing I know but I noticed it and thought it couldnt just be me
Phil
Post by: Stetter on December 18, 2009, 10:29:56 AM
3.13.Windows 7 x64, has established 3.13, start with rights Admin., in an input window station data key OK is not active, by pressing it occurs nothing, paternal such problems? I enter the necessary information.
Post by: RodBearden on December 18, 2009, 12:19:04 PM
Stetter - see Reply #86 in this thread.
Post by: tailplane on December 19, 2009, 08:36:51 AM
Hi! I am enjoying RD very much.
Anyone else had problems with rotes in v3.13?
The Flight ID exists in my local routes table, but the TO and FROM columns are blank.
I tried
1. Turn network off.
2. Turn "Process Hardware Flights" off.
3. Turn "Process Hardware Flights" on.
but route not appear.
Some Flight ID's ok, but
NH303,NH342,NH1733,NH604,NH159,NH1790,NH145,NH164 are not displayed.
I will wait if there is some information.
thanks
Post by: RodBearden on December 19, 2009, 11:11:25 AM
Tailplane - If I have ynderstood your points correctly:
Not all aircraft broadcast an ID, and therefore RB can't display a route or a logo, both of which come from the ID.
Even when there is a valid ID, the AirNav server doesn't always have the details - there are large gaps in their database - it's quite good for Europe and the USA, but the rest of the world is somewhat patchy. Also existing routes are constantly changing.
Post by: Tramline on December 19, 2009, 02:51:54 PM
I'm building myself up to upgrade from v2.01 to v3.13 as I'm computer techno-challenged.
1. I've looked at the previous posts and I'm wondering what is the safest and easiest method - a complete install or the upgrade link?
2. What material difference does it make if I don't make copy and paste of my current MyLog.db3 and NavData.db3?  What would I actually lose.
3. Is there anyone who is totally technophobic as me and actually been running 2.01 and upgraded to 3.13 - can someone PM me how they did it without suffering a mental breakdown?
Thanks very much everyone,
Post by: carras320 on December 19, 2009, 03:28:50 PM
Alerts, sometimes work and sometimes doesn´t. In my case sometimes I need to select the flight to activate the alert, and others simply when the aircraft is tracked the alert appears and works ok.
I also have some planes going backwards, quite frequently.
Anyone with the same problems??
Thanks.
Post by: tailplane on December 20, 2009, 02:26:06 PM
Hi! RodBearden.
Thank you for the answer.
The phenomenon has been generated by the case that the airplane has Flight ID, and is registered in a local data base.
I added all of my country's flight rotes to local DB by SQLite Database Browser.
(It was very a quite a job. )
I understand that it is difficult to make data complete.
I am enough if software refers correctly to local DB.
Perhaps individual problems if there is not a similar phenomenon.
thanks
Post by: RodBearden on December 20, 2009, 02:41:00 PM
Tailplane - I'm wondering if this thread might help you: http://www.airnavsystems.com/forum/index.php?topic=4029.0 (http://www.airnavsystems.com/forum/index.php?topic=4029.0).
Post by: Pinza on December 20, 2009, 08:25:20 PM
I had a problem with Air France's new A380 (detailed in reply #47 in now-locked ANRB 2010 3.13 beta thread) whereby said aircraft would appear in MyFlights but never in Aircraft History.
I recorded F-HPJA on the 5th/6th/7th Dec and yet 'Flights for Selected Aircraft' in MyLog/Grids merged these three separate recordings into one very long flight!
RodBearden agreed in reply#49 in the old 3.13 beta thread.
AFR006 flew over the Midlands again this afternoon - about 3 hours late.
Version 3.13 (final - ie not beta) worked like a dream:
a) I got a pop-up alert that the plane was airbourne
b) tracked seemlessly between the network and then when I could 'see' it locally (in MyFlights)
c) Plane showed correctly in Aircraft History
Great - but I have two questions:
1) I had ANRB 2010 3.13 running locally and pretty certain that I wasn't processing network flights at the time I got my alert. I was, however, connected to the internet at the time. Is that right that my alerts still work for network traffic even if not processing them at the time? Brilliant if so - I can turn it on for the alerted traffic!
2) Problem with AFR006/F-HPJA solved - was that something that changed between 3.13 beta and full version?
Long post but am impressed and interested!
Happy Christmas all
Chris
Post by: ANDREJ767 on December 22, 2009, 05:45:22 AM
Network is down for two days now - or is something else wrong?I recive home traffic well while I have no network flights at all - network-not connected .....
Post by: AirNav Support on December 22, 2009, 08:07:52 AM
Check your firewall settings andrej767, the network has been fine.
Post by: Allocator on December 22, 2009, 08:59:03 AM
Yes, I can confirm that the Network has been 100% as I'm at home on holiday and RB has been running whenever I've been awake :-)
Post by: tailplane on December 22, 2009, 01:31:44 PM
Hi RodBearden
Thank you.
Post by: ANDREJ767 on December 22, 2009, 02:11:48 PM
I have FW disabled,internet works OK as you see,RB works for my local traffic Ok,but RB network icon is red.I don't have idea what could cause that then....
Post by: Jeremy on December 22, 2009, 03:21:24 PM
Make sure 'Get Flights from network' box is ticked bottom left.
J.
Post by: ANDREJ767 on December 22, 2009, 03:23:24 PM
One more thing - when I open "tools" and the choose "network account information" theres a problem displying page "HTTP 500" .If I tick on www.airnavsystems.com the page is shown normally , but I don't know how to set this to show automatically my network acount informatin.
Post by: ANDREJ767 on December 22, 2009, 03:25:51 PM
Jeremy it is ticked also ....
Post by: Allocator on December 22, 2009, 03:26:55 PM
Quote from: ANDREJ767 on December 22, 2009, 03:23:24 PM
Again, this must be a Firewall issue preventing the RB software connecting to the outside world?
Post by: ANDREJ767 on December 22, 2009, 03:50:11 PM
FW is off and it works internet and it also works torrents up/down traffic - maybe I should reinstall the programme?
Post by: ANDREJ767 on December 22, 2009, 04:00:12 PM
I notice that after "welcome" page when I start RB ant thick on "account" theres an error displayed - probably thats the reason why I cant get network traffic.I will now make a full 3.13 reinstall and see if then the RB will work....
Post by: ANDREJ767 on December 22, 2009, 04:25:57 PM
... and IT WORKS!!! :)))))) I did completely reinstall of the software and my account info appear while network also started to work!Only one minor thing - on the map I see runways but no more 4-letter airport codes.Do I need to setup something so they will be displayed?Thank you in advance.
Post by: RodBearden on December 22, 2009, 04:33:13 PM
Andrej
Map Menu...Aviation Signs...Station Labels...Name
Post by: ANDREJ767 on December 22, 2009, 04:42:07 PM
Thank you it is now perfect!
Post by: Tramline on January 15, 2010, 07:57:59 AM
Post by: klm on January 15, 2010, 09:39:29 AM
Don't have a box myself yet butt i know there are some versions of win 7 and vista have problems to right/back to the c drive.
This has to do with the admin rights, altough there is one user on the pc, vista and win 7
sign the rights to Trusted installer/ hidden admin on the setup.
Its easy to check if you have the full rights.
Click on the c:/ drive with right mouse button and choose propertie's.
Then go to security.. highlight youre account and select advanced.
Select the tab where its say owner (3rd tab).
If you see TrustedInstaller, then you have not all the rights but the hidden admin have.
What you must do is to gain the full rights.
This take away a lot of problems with installed prog.
Post by: Allocator on January 15, 2010, 09:50:33 AM
Quote from: Tramline on January 15, 2010, 07:57:59 AM
What operating system are you using - XP or Vista?
With XP the 'upgrade is easy' but don't actually go for the upgrade, download the full install version of the RB software.  V3.13 will install into a completely separate directory, so you don't need to uninstall V2.01 - so all your old files are there for you when you need them.
If you don't copy across your MyLog.db3 then you will loose the historic record of what you have already detected - depends how serious you are about records.
I copy across my NavData.db3 file too, as this is the one that has the source aircraft details that are autopopulated, updated whaen you use Database Explorer, and give you the details in the aircraft lists and on the screen.
It's really easy with XP.
Post by: Tramline on January 15, 2010, 10:51:49 AM
Hi Allocator,
Thanks for responding. i've XP on my Netbook and Vista on my Laptop.  Does the Vista system for 3.13 cause any issues?  Would you suggest as AirNav that I just click on the link that just 'updates' V2.01
Thanks again,
Post by: tarbat on January 15, 2010, 11:35:44 AM
Best advise with Vista is to NOT install in the default folder, but instead install in somewhere like C:\Airnav, for example.  You will then avoid the problems of Vista's Virtual Store.
Post by: Southwest on January 15, 2010, 05:06:00 PM
When my PC went Pete Tong (not long after I bought ANRB), I installed the basic software version onto my partners laptop.  It has Vista as OS.  I then uploaded the 3.13 upgrade (not full install) and everything worked perfectly.
Post by: Aerotower on January 22, 2010, 12:13:01 AM
Hi Airnav,
This problem continues, what could it be?
Post by: tarbat on January 22, 2010, 08:40:27 AM
Aerotower, some possible reasons:
1. Power cut
2. PC put into standby or hibernate
3. ANRB crashed
Anything that would have stopped ANRB detecting the end of a flight.
Post by: Aerotower on January 22, 2010, 03:13:35 PM
Quote from: tarbat on January 22, 2010, 08:40:27 AM
1. Power cut
3. ANRB crashed
Hi Tarbat,
Most likely ANRB crashed, so I was looking at MyLog, there are some planes with different dates.
Post by: Aerotower on January 22, 2010, 07:17:33 PM
What is this AIRNAV? It is not the first time it happens, and it's always when I have the network connected.
Rgrd
[attachment deleted by admin]
Post by: Jonathan.G on March 03, 2010, 12:49:48 PM
need 3.14 =) with bug fixed ... FTP transfert auto-stop....Log report auto-stop...
BUG BUG BUG BUG again and again ! :s
Post by: AirNav Support on March 03, 2010, 03:27:55 PM
Jonathan.G,
Sorry can you explain that again?
Post by: Jonathan.G on March 05, 2010, 09:48:04 AM
We need a new version ! with bug Fixed !
Post by: AirNav Support on March 05, 2010, 10:38:31 AM
Can you explain the bug again please with detail?
Post by: Jonathan.G on March 05, 2010, 12:13:27 PM
The auto-FTP transfert stop again and again ....No hardware aircraft when the Network is actived...
Post by: Jonathan.G on March 05, 2010, 12:17:40 PM
(http://img138.imageshack.us/img138/6051/sanstitre2s.png)
FTP TRANSFERT STOPED....software reboot fix the bug....
Post by: Jonathan.G on March 05, 2010, 12:26:26 PM
ANRB is connected to the FTP......and no transfert !! wow !
(http://img148.imageshack.us/img148/8416/sanstitre1qz.png)
Title: Re: RELEASED - AirNav RadarBox 2010 - 3.13 - Comments
Post by: jannuh on March 05, 2010, 12:39:51 PM
Has probably to do with your FTP hosting provider.
RadarBox renames ftp uploaded images, not all hosting providers support this.
Tarbat has explained this more times, try a search on ftp upload in this forum!
Post by: Jonathan.G on March 05, 2010, 12:59:08 PM
no, the provider work...
Post by: tarbat on March 05, 2010, 01:25:30 PM
Well, you got it working before by sorting out your firewall.  What's changed since then?  A different ftp provider?  ftp upload works for many of us, so it's not a Radarbox fault.
http://www.airnavsystems.com/forum/index.php?topic=3870.msg38802#msg38802
Post by: Jonathan.G on March 05, 2010, 01:33:46 PM
An other bug !!
(http://img15.imageshack.us/img15/3617/sanstitre1tvt.png)
Post by: jannuh on March 05, 2010, 01:43:31 PM
Quote from: Jonathan.G on March 05, 2010, 01:28:31 PM
ARNB BUG !!!!!!!!!!!!!!! ....
Better explain before shouting!
Post by: viking9 on March 05, 2010, 02:13:20 PM
It's obvious. Fog!
Post by: Jonathan.G on March 05, 2010, 02:24:59 PM
-____-'
Post by: Jonathan.G on March 05, 2010, 02:25:25 PM
ANRB are buged =) ! Good luck !! 3.14 SOON please
Post by: AirNav Support on March 05, 2010, 02:32:08 PM
Jonathan.G,
If you have issues which you think are bugs then email us with all the details.
If we don't have the exact details we won't be able to rectify anything.
Post by: tarbat on March 05, 2010, 02:33:41 PM
Quote from: Jonathan.G on March 05, 2010, 02:25:25 PM3.14 SOON please
v3.14?  Don't you mean v4.03?
Post by: Jonathan.G on March 05, 2010, 07:25:37 PM
v3.13 actually, (NOT 3D!)
Need V3.14 with all bug fixed !
500€ = radarbox = software bug = Nice !!! pfffffffffffff
Post by: tarbat on March 05, 2010, 07:33:14 PM
v4.03 operates in 2D as well - just use /2D as a startup parameter.
Of course, without a clearer description of the bug you've found, we can't tell if v4.03 fixes it.
Post by: Jonathan.G on March 05, 2010, 10:26:28 PM
Ok thanks
Post by: rnsavage on March 23, 2010, 09:26:21 AM
Appologies if this question has been asked and answered before, but not been on the forum for a while
Running V3.13, and have been for a while. Currently not too interested in 3D, as involves me spending some money! Also for what I use RB for - a spotting tool - does not provide too much extra value for me at the moment (however hats off to AirNav for developing it).
However, now that V4.X is out, will all development on bugs etc be on that version, or will AirNav continue to fix any bugs etc on V3.13 as well
From my side, I would like to continue on the latest software, and benefit from any bug fixes. So does that mean upgrading to 4.X?
Is it possible to upgrade to 4.X without paying for it, and then later down the line just add in 3D as an option and pay the required monies?
Rick
Post by: AirNav Support on March 23, 2010, 09:29:38 AM
Don't worry, 3.13 will still be updated.
3.13 is actually the base of the 3D version, so any changes to base code will mean both versions are updated.
Post by: rnsavage on March 23, 2010, 10:21:59 AM
Thanks, thats good news
