Trouble reinstalling. Help please?
Started by BrunoBL, November 04, 2025, 03:25:07 PM
BrunoBL
Hi All,
My RB Feeder has erratically been on/offline for some time and finally went offline for many days. My internet connection is fine, wifi signal is strong. I decided to replace the Raspberry hardware, get a new microSD card and start anew (I do intend to keep my original share key).
So I burned the new microSD card with Raspberry OS Lite (32-bit) as suggested by the video tutorial, configured username, wifi settings and SSH interface, rebooted and can access the Raspberry from the PC. So far, all good.
Then I copied the bash script line from the AirNav site:
When running the script, those are the last two lines returning from the installation:
bash: line 27: apt-key: command not found
Don't know how to install for a distribution named
It does seem that the last line was truncated, but that was all that was displayed onscreen.
From this point on nothing works, RBFeeder can't run as it seems something wasn't installed.
Any ideas where to go from here?
Thanks,
Bruno
#1
Bruno
I would assume that you have installed the new Trixie version of the o/s.  The Trixie version of the RB feeder has not been done yet
See this workaround from abcd123 https://forum.airnavradar.com/index.php?topic=109561.0 but note it only works on the 64bit o/s
So you can either downgrade to a previous version i.e bookworm or go 64bit
BrunoBL
Many thanks. Will redo with the 64-bit version.
BrunoBL
Update:
Installed again with 64-bit Bookworm, and that did the trick, all went smoothly.
Feeding again, finally.
Many thanks for the tip, Alan, greatly appreciated.
All the best,
Bruno
Glad to help and thanks to abcd for the work round
