TRIXIE- How to Install rbfeeder and mlat-client on Raspberry Pi OS Trixie
Started by abcd567, October 03, 2025, 10:28:16 PM
Raspberry Pi OS Trixie (Debian 13) was release on Oct 01, 2025. The image can be downloaded from here:
https://www.raspberrypi.com/software/operating-systems/
The Trixie image is included in Raspberry Pi Imager also, which can download and write the image to microSD card in one go.
Please see next post for method to install rbfeeder & mlat-client on Raspberry Pi OS Trixie.
The standard method to install rbfeeder on Raspberry Pi is to run following command:
However as the Radarbox24 feeder is NOT (yet) available for Trixie, the above installation script fails on Trixie.
Following is the workaround for installing rbfeeder on RPi running 32-bit & 64-bit OS Trixie. This workaround is valid till such time RB24 makes their script & package avaiable for installing rbfeeder on Trixie also, in which case above noted installation command will succeed in installing rbfee der & mlat client.
Temporary Workaround for Installation of rbfeeder on 32-bit (armhf) and 64-bit (arm64) Raspberry Pi OS Trixie
(TESTED , Works OK)
(a) Install tools
sudo apt install dirmngr gnupg
(b) Set apt
Note: Following three (3) commands are very long. Scroll right to see and copy these in full
gpg --keyserver keyserver.ubuntu.com --recv-keys F2A8428D3C354953
gpg --export --armor F2A8428D3C354953 | sudo gpg --dearmor -o /etc/apt/keyrings/rb24.gpg
echo "deb [signed-by=/etc/apt/keyrings/rb24.gpg] https://apt.rb24.com/ trixie main" | sudo tee /etc/apt/sources.list.d/rb24.list
(c) Update apt and install rbfeeder:
sudo apt update
sudo apt install rbfeeder
(d) After installation is completed, signup as follows:
After a few seconds, RBFeeder will connect to the AirNav servers and you can view your sharing-key with this command:
sudo rbfeeder --showkey
If you already have a sharing-key from a previous installation, you can set the same key using this command:
sudo rbfeeder --setkey ‹your sharing key›
(e) Activate decoder dump1090-rb
If you are not able to install a decoder such as dump1090-fa or readsb etc, no problem, the rbfeeder installation as above, includes installation of its builtin decoder dump1090-rb. You can check it's existance by following command
ls -l /usr/bin/dump1090-rb
By default this decoder is inactive. However you can activate it by following method:
Open file "rbfeeder.ini" for editing by following command:
sudo nano /etc/rbfeeder.ini
In the file opened,  at top you will see this line:
network_mode=true
Change true to false, so the line becoms like below:
network_mode=false
Save the file (Ctrl+O)
Reboot RPi
sudo reboot
After reboot, check sttatus
(f) Install mlat-client
The installation of mlat-client from RB24 repository by command sudo apt install mlat-client   fails with following error message:
mlat-client:arm64 Depends python3 (< 3.12) but this is not installable (Trixie apt provides python 3.13)
Solution: Build & install mlat-client using source code
Install build tools & dependencies:
sudo apt install git build-essential debhelper dh-python python3-dev python3-setuptools
sudo apt install python3-pyasyncore
Build & install mlat-client:
git clone https://github.com/mutability/mlat-client
cd mlat-client
sudo dpkg-buildpackage -b --no-sign
cd ../
sudo dpkg -i mlat-client_0.2.13_*.deb
sudo apt-mark hold mlat-client
VERY IMPORTANT:
The trixie uses python3.13, in which module "asyncore" has been replaced by module "asyncio".
During runtime, the current version (0.2.13) of mlat-client requires the module "asyncore". As this module is missing, rbfeeder gives following error during runtime:
from mlat.client.net import ReconnectingConnection
File "/usr/lib/python3/dist-packages/mlat/client/net.py", line 25, in <module>
   import asyncore
ModuleNotFoundError: No module named 'asyncore'
SOLUTION:
To make python3.13 backward-compatible to software which are still using "asyncore" (such as mlat-client), debian developers have provided a package "python3-pyasyncore". This package provides the missing module "asyncore". This package must be installed on user's RPi . For this reason, I have already included it under installation of dependencies in above method.
ADDITIONAL SETTINGS (OPTIONAL)
If setting is "network_mode=false", it makes rbfeeder to start and use dump1090-rb. All settings of dump1090-rb are hard-coded in rbfeeder.
By default dump1090-rb is run with automatic gain control, which is very good. This is done by rbfeedr by passing folowing arguments to dump1090-rb:
--adaptive-range
--adaptive-burst
This setting for most purposes is very good. However if user wants to manually set a fixed gain, then this can ne done by adding following 3 lines under [client] section of file /etc/rbfeeder.ini
dump_gain=28
dump_adaptive_range=false
dump_adaptive_burst=false
Note: replace 28 in line "dump_gain=28" by gain value you want to set.
Save file and restart rbfeeder.
Please see screenshot attached.
RZEE
The feeder part works, addition of the MLAT unfortunately not.
Jan 06 16:32:26 zero2w rbfeeder[1916]: Tue Jan  6 16:32:26 2026 Lost connection                               to mlat1.rb24.com:40900
Jan 06 16:32:56 zero2w rbfeeder[1916]: Tue Jan  6 16:32:56 2026 Connected to mul                              tilateration server at mlat1.rb24.com:40900, handshaking
Jan 06 16:32:57 zero2w rbfeeder[1916]:         location: https://github.com/adsb                              exchange/mlat-server
Quote from: RZEE on January 06, 2026, 06:00:28 PM
(1) You have to add your location (latitude, longitude, altitude above sea level in meters) in file /etc/rbfeeder.ini under [client] , as shown below:
lat=xx.xxxx
lon=yy.yyyy
alt=zzz
(2) Mlat client seems to work ok, issue is connection failure to RB24 mlat server.
What is output of following command:
sudo systemctl status rbfeeder | grep python3
If mlat-client is working OK, you will get an output shown in attached screenshot.
RZEE
pi@zero2w:~ $ sudo systemctl status rbfeeder | grep python3
             ├─1439 /usr/bin/python3 /usr/bin/mlat-client --input-type dump1090 --input-connect 127.0.0.1:32457 --server mlat1.rb24.com:40900 --lat 52.244300 --lon 4.825800 --alt 9 --user EXTRPI002506 --results beast,connect,127.0.0.1:32004
pi@zero2w:~ $
Yeah, The MLAT started working next day.
