New AirNav RadarBox 5.00.62 Beta Upgrade
Started by AirNav Development, December 01, 2013, 09:34:22 PM
CYYZGUY
Alan do you know what the fixes were in the .63 version?  Or was it just a date extension?
regards,
Jason
40" LED Monitor
40" LED Monitor
Jason,
The NDB problem is resolved and flights flashing out and in with very low time outs is resolved
CYYZGUY
#122
NDB problem meaning it would not save the setting if you had the NDB markers turned on?
If so, I can confirm that is working now....
Jason
40" LED Monitor
40" LED Monitor
Michel
If you want to navigate direct from RB to this forum, you can do this via Community-> Forum-> General Discussion. In v.63 after Community-> Forum, all you can see is a white field. You have to point your cursor in this field to see the content (General Discussion, Screen Shots, etc). In v.62 you could see the content in Community-> Forum directly.
Judwin45
Just to say I am getting the 'white circle' which seems to come and go for no apparent reason.
Keith
5 miles south of EGDY
Michel,
I have  Community/Foruim/General Discussions/ as before
The reason for the white circle that some see has been identified and a fix is being progressed.  The same with the PZP flight ID's that some experience.
Michel
Alan,
Ignore. Did a restart and no problems anymore with Community.
Michel.
Judwin45
Hi Alan
Thank you for your patience with us, you are probably having to answer the same question time and again.
We do appreciate your help
Best Regards
Keith
Keith
NigelR
After using upgrade .063 for a few days now,  I increasingly getting multiple  instances of data elements not displaying for aircraft, for example often missing are the flight ID, airline and route or just one of these. Some have the Mode S symbol missing when I know they are mode s. Interestingly the log files are complete though. I've also noticed a progressive deterioration in the 'white circle' problem. It occasionally flashed on when first upgrading but it has now become an almost permanent feature if I attempt to use radar rings.
Any thoughts/suggestions gratefully received.
Nigel
Nigel,
Do you still have it as the upgrade or did you do as suggested and do a complete install.  I have however been using the 5.00.63 upgrade for a couple of weeks with no problems and others dont appear to be have it either.
Also regarding the white circle the cause has been identified as detailed last night and a fix will be progressed.
Starburstdave
Nigel/Alan
I have been running the software now for 2 days and I have found that as long as I leave Trail Lines toggled to on  I have not had a problem with the  white circle. If I toggle them off then after a few minutes the white circle appears as soon as I highlight an aircraft within the radar rings at various zoom levels, so I just leave trail lines on which I can live with until a fix is available. I have trail lines set to remove after 10 seconds. Hope this of some use to you Nigel
Dave
Just for Info: Although I'm using 10mins long trail lines I dad several white circle flashes (<500ms) shortly after SW start-ups. During normal operation no white circles. As Alan stated earlier: The problem causing white circles is indentified and shall be recified within the next release.
Further I noticed an increased occurance of freeced aiframes staying there for hours. Toggling "process hardware flights" off and on removes them. Privously to .63 I hadn't this problem. Although other users have stated that they have had this problem too.
No further misbahviours indentified.
CYYZGUY
#134
Interesting issue with the white circle.....Just happened to me for the first time.
I clicked on a ground return at the very top of my flight list and my entire radar range went white...
FDX150 Coming up as "Air Madagascar" logo.  Mode S = A36ED2 is what caused the white circle when clicking on that flight...
Also N917FE "Morningstar Air Express" for the life of me I cannot get a logo to display for that aircraft.  it is FOR SURE in my logos folder and I restart airnav every day....See below screenshot for N917FE logo..
Any ideas about that one?
FDX150 Air Madagascar by CYYZGUY, on Flickr
40" LED Monitor
40" LED Monitor
