1000 up
Started by Canonjohns40D, May 14, 2009, 10:30:39 PM
GlynH
I am creeping ever closer to that elusive 3000 mark as my RB clocked 2838 unique aircraft yesterday.
I am tempted to move it to the loft so I can dispense with the 5m extension that I had to fit to reach into my office to see if that might make a difference.
Either that or waterproof it in a sealed Tupperware box and attach it directly to the antenna like some sort of 'Frankenstein' masthead pre-amp - only then I would need a 15m USB lead or an external PC! :-)
When I have some spare time I must dig that UBox out of retirement...
-=Glyn=-
atcukmatty
hi GlynH, what type of external antenna are you using for radarbox? is that an GP1090? how does it compare to the DPD?
also whats the difference in range between the standard supplied aerial compared to your setup?
thanks
GlynH
Quote from: atcukmatty on June 06, 2009, 05:16:26 PM
thanks
Hi atcukmatty,
If you take a look on the previous page you will see exactly what I use - I have even posted a picture.
It came from a supplier who I can't recommend in a soft plastic, yellow 'bag' with a clear front and I suspect although it was badged Watson might be a 'badge-engineered' generic type as I  have seen similar antennae supplied in the same packaging badged differently.
Here are a couple of links to the same product;
http://www.radioworld.co.uk/~radio/catalog/radarextender-external-antenna-radarbox-p-5965.html?osCsid=f5d30bd04af72b245a5a02266d2cdb4b
http://www.airbandonline.co.uk/viradac_radarextender.htm
I don't know how it compares with the standard supplied aerial because I only used that for one day on the window sill before I put the Watson up but these guys have experience with both;
http://www.airnavsystems.com/forum/index.php?topic=2553.0
I also have no idea how it compares with the DPD either although someone around here might have an idea...try the Search function! ;^)
Kind regards,
-=Glyn=-
Hi Glyn, I'm convinced the Watson and Diamond antennas are manufactured by the same company.   There's a number of identical features and common parts.    Whether Watson maufacture for Diamond or vice versa, or a common manufacturer for both I do not know.     That yellow sleeve for each type all seem to be from the same maker, and ditto instructions.
GlynH
Hi Jon,
Yup...Diamond was the 'other' make I couldn't think of when writing my earlier post.
Depending upon which dealer you go to you will usually see one or the other but they look identical especially hanging up in their yellow sleeves.
Kind regards,
-=Glyn=-
John Racars
Hi Support and All,
After following this tread the last days I am asking me or questions with the subject "SQL" and making reports from out the RB databases, are here on the right place.
Now the discussion goes about antennes more and more. That is no problem ofcourse!
Maybe there can be opened a subforum about "RB Database-Management" where all questions about this subject can be put in? It is only a thought...
13 NM East of EHAM
ANRB:
Version: 3D - 5.00.072
PC: Windows 7 SP 1 - 64 bit
RadarBox24 station: EHAM4
Thats a intresting idea, we will look into it.
