Why do some silouettes not show sometimes? Example...BAW3577 (B748)
Started by CYYZGUY, September 22, 2013, 01:21:01 AM
CYYZGUY
Sometimes I get some aircraft which to do not populate the aircraft silouette...
For example right now... BAW3577 Showing as a Boeing (B748)
and AFR6732 Showing as a Boeing (B77L)
and ACA022 Showing as a Boeing (B77L)
I am pretty sure I have all the latest updates installed in terms of silouettes.....Are these not common aircraft?
Jason
40" LED Monitor
40" LED Monitor
Jason,
Check your silhouettes folder and see if you have them if not download and install
CYYZGUY
Thanks guys, I will check......As I approach 40....my memory is starting to fail me!  I could have sworn I downloaded them.
regards,
40" LED Monitor
40" LED Monitor
