Author Topic: Why do some silouettes not show sometimes? Example...BAW3577 (B748)  (Read 2857 times)
CYYZGUY
Sometimes I get some aircraft which to do not populate the aircraft silouette...
For example right now... BAW3577 Showing as a Boeing (B748)
and AFR6732 Showing as a Boeing (B77L)
and ACA022 Showing as a Boeing (B77L)
I am pretty sure I have all the latest updates installed in terms of silouettes.....Are these not common aircraft?
Jason
40" LED Monitor
40" LED Monitor
Re: Why do some silouettes not show sometimes? Example...BAW3577 (B748)
« Reply #1 on: September 22, 2013, 09:36:18 AM »
Jason,
Both of these silhouettes are there on Rod's download page :
http://www.rodbearden.com/RadarBox/Downloads.htm
« Reply #2 on: September 22, 2013, 11:44:28 AM »
Jason,
Check your silhouettes folder and see if you have them if not download and install
CYYZGUY
« Reply #3 on: September 22, 2013, 04:01:08 PM »
Thanks guys, I will check......As I approach 40....my memory is starting to fail me!  I could have sworn I downloaded them.
regards,
40" LED Monitor
40" LED Monitor
« Reply #4 on: September 22, 2013, 05:22:37 PM »
Good  grief !
Approaching 40. If only, if only !
« Reply #5 on: September 22, 2013, 05:39:52 PM »
Just a lad!!
